(Topic ID: 218168)
Official "HARDTOPS" thread
By Skypilot
5 years ago
  • 3,342 posts
  • 506 Pinsiders participating
  • Latest reply 13 days ago by Skypilot
  • Topic is favorited by 284 Pinsiders
Topic poll
“If we produce a Hardtop for this game would yo purchase it?”
  • High Speed 174 votes
    13%
  • Firepower 128 votes
    10%
  • Silverball Mania 62 votes
    5%
  • Time Warp 30 votes
    2%
  • Mata Hari 55 votes
    4%
  • Blackout 94 votes
    7%
  • Tri-Zone 26 votes
    2%
  • Swords of Fury 74 votes
    6%
  • Space Station 79 votes
    6%
  • Fathom 70 votes
    5%
  • Pinbot 134 votes
    10%
  • Eight Ball Deluxe 124 votes
    9%
  • Strikes and Spares 56 votes
    4%
  • Kiss (Bally) 71 votes
    5%
  • Supersonic 52 votes
    4%
  • Grand Lizard 80 votes
    6%
(Multiple choice - 1309 votes by 789 Pinsiders)
5 key posts have been marked in this topic (Show topic index)
There are 3,342 posts in this topic. You are on page 51 of 67.
#2501 1 year ago
Quoted from radium:
What was causing it to get stuck?
I'm not there it fix someone else's pin, plenty at home for that! It was clearly related to the hardtop as you could see deformation of the surface.
I moved on to another title, the Rollergames next too it played sweet.
10
#2502 1 year ago
20220429_142151 (resized).jpg20220429_142151 (resized).jpgI installed one on my Blackout and I'm happy with results. Took my time and made sure the playfield was perfectly clean before I applied it. Once it was down for the few holes that were off I just took an old soldering iron with a fine tip and melted the plastic directly above the screw holes in the playfield so they were back in line.
20211111_151720 (resized).jpg20211111_151720 (resized).jpg23194 (resized).jpeg23194 (resized).jpeg20220324_122544 (resized).jpg20220324_122544 (resized).jpg
#2503 1 year ago
Quoted from gdonovan:
I would not be inclined to buy one before due to past negative experiences, my experience with this title just reinforced it further.
Never had a ball get stuck in an inlane before. Had to shake the hell out of the pin to shake it loose.
Not cool.
I'd like to buy one for the Space Shuttle I have here, each time I have an interaction with a hardtopped pin its a negative experience.
Am I to ignore what I have seen with my own eyes and buy one anyways? No thanks. Maybe its just bad luck on my part having run across three bad examples in a row, nothing I want to gamble a few hundred bucks and a few days labor to find out in person.
Yeah that does suck. I'm getting ready to put one on my Comet, which I'm happy to have after many years of no options. But I also have a Flash Gordon hardtop here and I keep thinking I should just wait for a CPR run... especially since I'm going to sell it after restore.
#2504 1 year ago
Quoted from SantaEatsCheese:
Xenon and Space Shuttle seemed to play perfectly to me.
I played them as well. Even though the Xenon looked horrible IMO with the colored LED's, it played very similar to mine which has a NOS clear coated PF.
#2505 1 year ago
Space Station soon please!
11
#2506 1 year ago
My Blackout Hardtop made it onto the tournament stream at Allentown. Pretty neat.
#2507 1 year ago
Well, my Gorgar plays awesome with the Hardtop and looks perfect. Can't wait to do another. Then again, I didn't screw up the installation.
#2508 1 year ago
Quoted from ChrisPINk25:
Another +1 on Space Station. I just threw some halfway decent decals on the cab after a lot of resin work, and I would love to really save the playfield. Everywhere I don't have mylar is pretty bad off.
#2509 1 year ago
+2 on Space Station. What is it, the only pin on OE's original "teaser" survey that HASN'T been released some 4 years later? Even as other distractions and C titles see the light? Sheesh... well beyond time to show it some well-deserved belated love already! Or else for OE to finally say "Not EVER gonna happen because [reason]" and quit stringing us along...
#2510 1 year ago
Elektra is out! Just ordered a set for my game. First hardtop for me. Will be nice if they decide to do partial sets too with just the small upper and lower playfield hardtop sections.
#2511 1 year ago
What are you guys considering a bad or good install?
Is it really that much more than sanding and clear coating the inserts?
#2512 1 year ago
Quoted from jcar302:
You have to do it right! Too much clear on inserts is not good (high spots). Over sanding is not good (low spots). Replacing bad inserts is required (no raised, cracked or damaged inserts) and restoring your shooter lane properly is important. Aligning the Hard Top properly and making all the adjustments to get mounting holes correct is important (they're almost never a perfect match). You get one shot once Hard Top goes down. Then you need to trim off excess plastic on edges where required. More to it than one might think if you want a good job. If you're in a hurry, don't do it.
#2513 1 year ago
Quoted from Mr_Outlane:
Yeah this is a good summary!
Yes Hardtops are less expensive than a repo playfield but they are NOT CHEAP products and will last a really long time
Yes Hardtops are quicker and easier than a swap but that does NOT mean if you're doing a hardtop that you should be careless and cut corners
Its a bummer because someone says it costs less and is time saving gets misinterpreted as CHEAP and EASY. People need to stop thinking like this with Hardtops.
If you treat a hardtop resto the same way as you would any other high end resto you are left with an amazing looking machine with a playfield that has no chance of dimpling, or ghosting, is flat as glass, and plays smooth as butter, and will look brand new inevitably as long as you care for it like you would any other clear coated game. (Change the ball when needed and wax it after X amount of plays). And you get all the hours back from not having to touch up playfields and risk cancer from 2-part clear coating. AT LESS THAN HALF THE COST OF A REPO.
Love my Hardtop Restos:
https://pinside.com/pinball/forum/topic/thruster-i-just-met-her-xenon-restoration-/page/8#post-6595405
https://pinside.com/pinball/forum/topic/i-thought-she-was-a-dirty-girl-before-i-stripped-her-down/page/6#post-5310350
-5
#2514 1 year ago
Quoted from mrm_4:
LOL, hardtop and high end restro should never be compared.
#2515 1 year ago
Quoted from pinballizfun:
I'll take a Hard Top any day over a modern Stern playfield or anything made by Mirco. I wouldn't be surprised if the future of playfields is some form of Hard Top rather than digital printing and clear coating. It would solve the problem of pooling and chipping. This would allow manufacturers to crank out pins with no curing time!
Furthermore, at current prices for classic pins, a repro playfield is out of the question! Even a Hard Top job for a restoration project can put you over budget by the time you finish with everything! Hard Tops are going to save a shit load of pins! Or would you prefer to pay far more for a restored original with the entire playfield silk screen shifted off center? Which is common.
b9b2f69c38b9cdb2ee928a85a541d1ad9b6f5c38 (resized).jpgb9b2f69c38b9cdb2ee928a85a541d1ad9b6f5c38 (resized).jpg
#2516 1 year ago
Hell, my Deadpool came with an extra NIB playfield because the previous owner had a couple chips. I have it hanging on the wall. The original playfield has thicker clear coat. Ya, that was their solution to pooling and chipping. Rather than longer curing time, we got thinner clear coating! If I run my finger over the new PF, I can feel every ridge of the art print and inserts. My Hard Top is glass smooth! Also I'll never get raised or cupped inserts affecting ball action much.
#2517 1 year ago
Hell, my Deadpool came with an extra NIB playfield because the previous owner had a couple chips. I have it hanging on the wall. The original playfield has thicker clear coat. Ya, that was their solution to pooling and chipping. Rather than longer curing time, we got thinner clear coating! If I run my finger over the new PF, I can feel every ridge of the art print. My Hard Top is glass smooth! Also I'll never get raised or cupped inserts.
And yet stubborn ways will keep us painting over cheap wood and clearing thinner coats and bitching about dimples and pooling and wear because “that’s the way we’ve always done it!” Even though we aren’t doing it the “way we’ve always done it” it’s a watered down, rushed, horrible quality, cost cut so bad it’s not even funny new way that some how we are being asked to pay more for.
Hell, I can walk up to a machine now and with in a second of the first glance I can tell it’s CPR because it looks like the clear was applied in top to bottom strokes with a paint brush from Ace Hardware.
#2518 1 year ago
Quoted from mrm_4:
Yup, perfect example of paradigm thinking!
Also, I have read many times that the new digital playfield printing does not bond to the wood as well as the silk screen method of yesterday? Supposedly a reason for the paint lifting with the CC pool chipping.
#2519 1 year ago
Quoted from mrm_4:
Hmmm… I don’t think the quality of factory playfield clear has ever really been as amazing as you’re making out.
I’m happy to have hardtops available but wood playfields are king for me and I’m happy they are still around.
#2520 1 year ago
Products like hard tops, flat packed cabs and yoppsicles have me excited about the future of pinball resto. As much as I like CPR, the last title I purchased (BOPP) had all 10 rollovers completely overflowing with clear coat. Piss poor quality control that took hours of my time to correct. The judges of machines at the last TPF put out a call for maintaining originality in machines. And as much as I can embrace the concept of purity in a resto I am also all for embracing new tech. (Been building gaming systems for years and it took me no time to go from physical hard drives to SSDs. A terabyte on a stick of gum? Yes please!) The whole concept of my company(Third Coast Pinball) is to help regular folk to build a dream classic pin of their own. And thanks to companies like Outside Edge it is more affordable than ever. I have a collection of wrecked classic Bally and Stern playfields I will be hard topping in the near future. Threads like this help us all to learn lessons through others' pain and progress. Keep it up all y'all!!
Shawn
-6
#2521 1 year ago
Lol, they made plastic fields, it was a failure. They don't do it anymore. It's more expensive. Bonding the ink to the base will fix the chipping, is not a clear failure, that's a substrate bonding issue, not a top coat issue.
#2522 1 year ago
Clears were thin. Then people got stupid and started demanding super shiny thick clear so manufactures gave them what they wanted. But paints and clears have actual spec'd thicknesses they are to be applied to. Make them too thick they fail.
#2523 1 year ago
What do you mean plastic playfields were a failure? The Middle/main playfield on Elektra is covered in thick plastic and is fine. My issues are with the upper and lower playfields that were never protected. The upper on mine is really awful. There wasn’t a replacement playfield set available from anyone. It’s awesome there is now a hardtop available. The games I’ve run across that had hardtops were well done and played well.
#2524 1 year ago
This plastic playfield is almost 30 years old snd still looks new. Not sure why they didn't catch on more.
1652530904485492758965115450362 (resized).jpg1652530904485492758965115450362 (resized).jpg
#2525 1 year ago
I think I had the same experience on that machine
The ball was getting stuck between the shooter lane switch wire arm and the clear hardtop tab that was installed too far over
The owner needs to put a bevel on the edge of the plastic, guiding the ball to the center of the switch arm, not along side it
#2526 1 year ago
Quoted from vid1900:
Nope, I got stuck on the left return lane twice and the inline drops once.
It had a card on it proudly claiming it was restored.
I'll stop here.
#2527 1 year ago
I'll stop here.
Ahhh...they forgot to shim up the inlines with a plastic strip...If the drop tops are not level, the ball's going to hang
4991897d86a6219d50e1bc89ad8dc2ba92460356 (resized).jpg4991897d86a6219d50e1bc89ad8dc2ba92460356 (resized).jpg4d130ec61e3c0bf6e5340be22a3067bced1a8405 (resized).jpg4d130ec61e3c0bf6e5340be22a3067bced1a8405 (resized).jpg
#2528 1 year ago
Quoted from gorgar007:
Saw my first hardtop in the wild (flash gordon). Quality was absolutely fantastic and the game played great - I forgot the hardtop was on after starting to play.
I'm sure this has been said in this thread already, but I am surprised no current pinball manufacturers are shipping with a hardtop. All of the incentives seem to be there.
This one uses a plexiglass type top on it's playfield.
#2529 1 year ago
New Canista has a plexi top over a MDF playfield too.
It will never wear out
#2530 1 year ago
Quoted from Robotworkshop:
They failed, I didn't say the fields themselves failed and were trashed. The business model failed. They were too expensive, harder to machine, and harder to repair if anything did get messed up.
#2531 1 year ago
I can see that. But since they hold up well I think that a Hardtop can be a great solution to fix up a lot of games that otherwise would remain trashed. I'd take one over the thin overlays.
#2532 1 year ago
The original post I replied to said he wouldn't be surprised if plastic fields became the norm. That was a failed idea already for the reasons above, plus many think they do not play right. A hardtop is an acceptable last resort of a trashed field. The issue is too many people put one on, then post what the game looked like originally and it had minimal wear. That is just a waste.
#2533 1 year ago
And many do think they play right including me as my Gorgar plays fantastic with the Hard Top. And where are you getting this "failed idea" data from? Lets see your sources?
Did you even watch the video above?
#2534 1 year ago
I totally agree on the point that hardtops get installed when they shouldn't. I've seen a few people that installed a hardtop on a playfield that actually looked pretty good as it was or could easily be touched up and restored. That is a waste. But for playfields like mine it is needed and I really doubt there is any difference in play for a properly installed hardtop or cleared original playfield. Once waxed they should play the same.
#2535 1 year ago
Not quite sure why it's a waist?
Cupped inserts are a constant on these old playfields. Few people have the skill or interest in restoring a playfield and paying somebody else to do it is cost prohibitive for most. If you wish to purchase and install a Hard Top, that's your business! I enjoyed the whole process and will do it again. And it will look and play better with a smooth, new playfield surface than one with an old surface full of cupped inserts.
#2536 1 year ago
All I know is that I have a Space Station playfield out of the cabinet right now. It lived a couple of years with no glass on a porch, so everywhere the mylar didn't touch, the paint is crumbling. I can live with it and just lay down a playfield protector and watch it get ground to dust underneath, or hard top this bad boy and not worry about it for the rest of this century.
I know which one I would prefer, but I have to reassemble this beast at some point...
#2537 1 year ago
LOL!
So you're saying that playfield manufacturers abandoned tried and true manufacturing methods to appease some customer demands for thicker clear coat at their own peril resulting in this catastrophe of pooled and chipped playfields they had to replace?
Where is your evidence that this is actually what happened?
AFASK, it was the reduced clear coat curing times so they could pump out playfields fast enough to keep up with demand.
Or possibly changing the CC formula?
Or perhaps less than ideal conditions when applied?
I don't claim to know for sure! How do you??
#2538 1 year ago
Hmm they tried it and stopped, that would be a failure. if it was better and cheaper it would have been used more, not stopped, its a pretty darn simple dichotomy.
#2539 1 year ago
If it is just cupped inserts then it seems better and cheaper to just get a playfield protector. Accomplishes the same thing if you mainly just have cupped inserts. You get a smooth play surface but at least down the road if someone does want to restore the playfield they can and that option is still open.
It totally is up to the owner of a game and they can do whatever they want. But if it is a pretty nice playfield then sanding off original artwork that many people would be happy with as is then it is a waste. Save the hardtop for games that really need it. I like hardtops. The ones I've played were well done and looked great. I bought one myself and will be installing one. Just have a different threshold than you on when I think a Hardtop is justified or needed.
#2540 1 year ago
How to you you know it wasn't because they didn't want to wait for the clear to cure longer? So they decided to put it on thinner?
Seems like a darn simple dichotomy.
So you have no evidence to support your claims then?
#2541 1 year ago
That is not even remotely the same thing! I had a playfield protector on my F-14. It sucked so bad, I cut it off. Dirt got under it constantly and looked like hell! Also, if it moves at all, it scratches the underside and then you're screwed which happened as well!
#2542 1 year ago
That is not even remotely the same thing! I had a playfield protector on my F-14. It sucked so bad, I cut it off. Dirt got under it constantly and looked like hell! Also, if it moves at all, it scratches the underside and then you're screwed. Which happened as well!
I didn't say it was the same thing. Just that it could accomplish the same thing. As with any of these your mileage may vary. Some people have have good results with playfield protectors and some not. Many people have had good experiences with hardtops and a few on here have not. Use whatever works best for you.
#2543 1 year ago
LOL!
diamond plate was thin and worked well. when posts were driven thought it, the clear would simply break. It was thin, it didn't peel up, it didn't spiderweb. Look at old WPC games you'll see the art and topcoat fully separated in a ring where the posts pressed into the wood. People started "restoring" games by adding stupidly thick clear in order to get super shiny, wet look fields. Doing this isn't an issue when its an individual, not many people will play that one machine, or handful of machines, so they don't get much wear. Stern started to run stupid thick clear in response to this demand, you can find accounts of it all over this site. Then you were looking at a high number of machines in high traffic locations with lots of eyes on them. Flaws turn up and get seen. This was done in direct response to people looking for wet look thick clear. Did stern know it would fail, doubtful. It's not really relevant though since the failure mode is the art to the substrate not the clear to the art. Thick clear acts like a rubbery plastic film you press it, it won't break easily-it will stretch. when well bound to the art the weakest link breaks, which was and still is the art to substrate bond. This is exactly why taking art away from the posts "fixed" the issue. You removed the weak point. Guess what though, get hold of a field to sacrifice and drive home posts into the art covered areas, you'll get the same movement with the art attached to the clear. You won't see it on the posts where the art was removed. They seems to have thinned the clear back worn a bit which is also making the clear less likely to stretch rather than crack. None of this new unknown in painting. Film thickness is important. No Matter how well you prep, if the application is done too thick for the medium it will fall. You think stern and JJP are pumping out games so fast that the clear can't sure if applied by the manufactures guidelines? Williams put out more in a day than those companies do in a week. There was no "waiting" to let things cure, and with the exception of insert ghosting on some titles no issues wit the clear separating. Holding parts in inventory is expensive. it takes space and is taxed considerably. That ghosting was the same issues as now, poor bonding to the substrate. in that case to plastic which is notoriously difficult to paint with normal paints.Ghosting generally did not occur on printed inserts as the screening inks did bond to plastic well and the clear bonded to those inks well.
Curing has zero to do with plastic playfields, which were a failure.
#2544 1 year ago
Hard Tops have not proven to be a failure as of yet and they have been tested in the field for a few years now. No dimples either.
As far as this product goes, it never existed before.
#2545 1 year ago
I never said it did!
Hard Tops FTW!!!!
#2546 1 year ago
Hey so how bout them hardtops eh? Hoo rah go team, when's the next teaser, can we get a space station? Or like anything other than this argument?
#2547 1 year ago
Electra was just released.
No teaser announced yet.
-3
#2548 1 year ago
You stated you wouldn't be surprised if plastic fields became the norm. It was already tried, it failed. Both as a polybarb back-printed top slab over a substrate, very similar to a hardtop, but one that actually fits right since it was cut with the PF, to a full plastic field. Both were discontinued. Both were failures from the manufacturing aspect. It's not disputable that they stopped making them that way.
#2549 1 year ago
"to a full plastic field"
Apples to oranges. Not what a Hard Top is. I suggested plastic over wood like the Hard Top. My apologies, I should have been more clear.
-5
#2550 1 year ago
That was done, it also failed. I mentioned it, you didn't pay attention. There is also a pic of one in this very thread.
$ 29.00
arcade-cabinets.com
$ 40.00
NorthStar Mods
Denver, CO
$ 4,600.00
Yellow River Pinball
$ 50.00
Slipstream Mod Shop
$ 899.00
$ 44.00
PinballReplacementParts
2,800
Nashville, TENNESSEE
$ 1.00
Pinball Alley
$ 69.00
Pinball Pimp
$ 18.98
$ 12.00
$ 18.95
Third Coast Pinball
$ 160.00
Sparky Pinball
$ 399.00
4,000 (OBO)
Queen Creek, AZ
Troxel Repair
$ 27.95
$ 18.95
4,000 (OBO)
Bay Shore, NY
Hardware
Volcano Pinball
$ 69.00
Pinball Pimp
This page was printed from https://pinside.com/pinball/forum/topic/official-hardtops-thread/page/51 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
