New! Dark mode!
(Topic ID: 218168)
Official "HARDTOPS" thread
By Skypilot
2 years ago
  • 1,747 posts
  • 342 Pinsiders participating
  • Latest reply 4 days ago by dyopp21
  • Topic is favorited by 209 Pinsiders
Topic poll
“If we produce a Hardtop for this game would yo purchase it?”
  • High Speed 146 votes
    14%
  • Firepower 106 votes
    10%
  • Silverball Mania 53 votes
    5%
  • Time Warp 25 votes
    2%
  • Mata Hari 47 votes
    4%
  • Blackout 86 votes
    8%
  • Tri-Zone 20 votes
    2%
  • Swords of Fury 65 votes
    6%
  • Space Station 54 votes
    5%
  • Fathom 48 votes
    4%
  • Pinbot 118 votes
    11%
  • Eight Ball Deluxe 110 votes
    10%
  • Strikes and Spares 40 votes
    4%
  • Kiss (Bally) 49 votes
    5%
  • Supersonic 37 votes
    3%
  • Grand Lizard 69 votes
    6%
(Multiple choice - 1073 votes by 626 Pinsiders)
There have been 370 images uploaded to this topic. (View topic image gallery).
5 key posts have been marked in this topic (Show topic index)
There are 1747 posts in this topic. You are on page 35 of 35.
#1701 23 days ago
I was talking about the scoop holes.
The holes of the hardtop are the same size as the inner diameter of the scoop holes.
#1702 22 days ago
Quoted from Toine79:
The holes of the hardtop are the same size as the inner diameter of the scoop holes.[quoted image][quoted image][quoted image]
Okay then, that being said I would do any adjusting you needed to do after the hardtop is in place. Most importantly align with your inserts if you still feel the need that you need to trim the scoop holes you can use a Dremel bit once it's in place.
#1703 21 days ago
Project in waiting...
#1704 21 days ago
Quoted from Apinjunkie:
ABSOLUTELY only align with the inserts! Once the HT is in place go to harbor freight with a coupon and get the trim router, its about $20-$30. Then get a trim router bit, used for laminate or something similar, its pretty cheap, about $10 bucks. Ive used this set up twice and its flawless. Plus you can do all the other holes too for kicks, lights, etc and don't forget the outter edge too, you can make it completely free and clear of any obstruction.
https://www.harborfreight.com/14-in-24-Amp-Trim-Router-62659.html?ccdenc=eyJjb2RlIjoiMTg0ODg3MzQiLCJza3UiOiI2MjY1OSIsImlzIjoiMTkuOTkiLCJwcm9kdWN0X2lk%0D%0AIjoiMTE5MzcifQ%3D%3D%0D%0A&cid=paid_google%7C%7C%7C62659&utm_source=google&utm_medium=cpc&utm_campaign=&utm_content=&gclid=EAIaIQobChMI5_W7v42N7AIVBopaBR00MgieEAQYAiABEgLMBPD_BwE
https://www.homedepot.com/p/DIABLO-3-8-in-x-1-4-in-Carbide-Flush-Trimmer-Router-Bit-DR64100/100660703?source=shoppingads&locale=en-US&mtc=Shopping-B-F_D25T-G-D25T-25_7_POWER_TOOL_ACCESSORIES-Multi-NA-Feed-LIA-NA-NA-PowerToolAccessories_LIA&cm_mmc=Shopping-B-F_D25T-G-D25T-25_7_POWER_TOOL_ACCESSORIES-Multi-NA-Feed-LIA-NA-NA-PowerToolAccessories_LIA-71700000043746545-58700004596952413-92700049573927185&gclid=EAIaIQobChMIicak3I2N7AIV0YpaBR2jOQX4EAQYBCABEgJqofD_BwE&gclsrc=aw.ds
#1705 21 days ago
My next video with SDTM will be installing Swords of Fury. Don't know the release date for it yet, but when it goes up I'll let you guys know.
#1706 21 days ago
Isn't a full router way overkill for this job? I'd be afraid of taking out more wood from the hole.
What's wrong with using something smaller and more precise like a dremel?
#1707 21 days ago
Quoted from xamindar:
I've had great success adjusting hardtop holes with a dremel. Very precise with a steady hand and a multitude of inexpensive bits to choose.
#1708 20 days ago
If you use plunge router; other then its big and bulky, you should be using a flush bit which has an edge guide on it and will follow the existing wood hole without cutting into the substrate.
11
#1709 20 days ago
Quoted from TheCapn:
Sorry Cary ,couldn’t wait for the video LOL
#1710 20 days ago
Quoted from Mathazar:
That's what I used, with this attachment to keep the bit in control.
amazon.com link »
#1711 20 days ago
A Dremel with a carving bit and drill with a small bit resolved my hole alignment issues.
#1712 20 days ago
Quoted from Skypilot:
/Shakes fist
#1713 20 days ago
Quoted from NinJaBooT:
But any kickout holes I have seen are flared out on top. I don't have a router so haven't looked too much in to it yet. But wont a flush bit be the incorrect bit for any out-holes?
#1714 20 days ago
Your correct. You’d have have to match to the radius of the wood to the correct router bit which wouldn’t be difficult. I definitely think a dremel is the way to go and either make circle jigs out of wood to use as a guide or put painters tape over the hardtop and mark your circle and try your luck freehanding it with a dremel.
#1715 19 days ago
This is a trim router, it fits in your palm. Secondly the trim bit I linked runs under the hole, it cuts the laminate flush with the wood edge. Its absolutely the best two things to use when cleaning up holes, edges, and anything else on the Hardtop.
#1716 19 days ago
Which white leds did you use as GI?
Beautiful playfield.
Thank you! Those are #47 incandescents
#1717 19 days ago
Quoted from ibis:
Yep, exactly this. I used a flush trim bit for cutting out my HS rollover holes. I made a video to show what this looks like in action.
#1718 19 days ago
The problem I had was the similar bit I used drops into the hole for the insert but the upper hole near the playfield is just a tiny bit larger so the insert goes in but doesn't fall through.
I used a dremel to free hand and open up that upper opening. That tool that you had to remove the swarf was slick. That might have done the trick. Where did you get that?
#1719 19 days ago
Quoted from hd60609:
The duburring tool?
amazon.com link »
#1720 19 days ago
Perfect! Thank you! In my cart...
17
#1721 18 days ago
My Grand Lizard is complete.
07B92FA5-D8C0-4177-AE56-106F77CC9B03 (resized).jpeg417D81CE-E696-4F57-90F1-010EA2B3FB2A (resized).jpeg523253E0-FD9A-4120-A277-EA1BED3DD60F (resized).jpeg57B369AF-3DEB-4FCF-AF86-BFD117CF8914 (resized).jpeg64E79C22-FDC2-4709-B747-06CD69984A41 (resized).jpeg931BE856-7329-4FE8-8105-6C216C9F5B3A (resized).jpeg93F578A3-9021-45EB-8EDD-8F137BBE5006 (resized).jpeg9790B0A2-DB6A-4CA6-BD18-6D2746CA59F2 (resized).jpegC08633E9-A109-481F-8E3D-57105D66AB06 (resized).jpegD3250621-E0E7-4844-874A-61FA5FCE5BAF (resized).jpegDA2C57BA-0C52-402F-A2EE-F64F4CC458F7 (resized).jpegDF4C613A-1B40-4917-99D7-272A0B697A8C (resized).jpegEF02D600-861F-4EFA-8191-1E35EA83EABB (resized).jpeg
#1722 18 days ago
Quoted from djreddog:
My Grand Lizard is complete. [quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Great job! Love the flipper and rubber color choices.
#1723 18 days ago
Quoted from La4s:
+1
#1724 18 days ago
That Grand Lizard looks nice.
On inserts, what are the options when they are 40 years old and faded?
My BK has those jeweled inserts that I am pretty sure are unavailable.
Do you just stick colored LEDs under them and call it a day?
Or is there some colored overlay that can be used?
#1725 18 days ago
It's live, everyone. For those looking to install on SoF. Much easier than BK for sure.
#1726 18 days ago
Honestly the options are few. First clean the underside of the insert. I can't tell you how many times I see people complain how 'dim' an incandescent bulb is so they put in LED's to brighten the insert, but the insert itself is completely filthy underneath. Second, you can clear coat the insert to eliminate cracks and fissures that dampen the brightness. Faded inserts, not sure that is fixable, but cooled LEDs could be the answer. I would resource your inserts though, most inserts can be found. In fact, because BK has been done by CPR there could be all of them floating out there. You'll just need to check with all the common sources.
10
#1727 17 days ago
Finally completed my Firepower. So thankful for the Hardtop. I previously replaced all inserts except for the hotdogs, and got new plastics and Reese Rails.
PXL_20201003_033525026 (resized).jpgPXL_20201003_033533394 (resized).jpgPXL_20201003_033552764 (resized).jpg
#1728 15 days ago
#1729 15 days ago
I'm still on the fence with this for my Black Knight. Does the hard top really look like it was just printed out (much lower quality than original art) like they are showing in this post?
https://pinside.com/pinball/forum/topic/black-knight-clubmembers-only/page/38#post-5043854
#1730 13 days ago
No. I think they cull the ones that don't look perfect but a few slip out. I have done a EK and a Wizard and they both look perfect.
#1731 13 days ago
Pinbot and Taxi also perfect.
#1732 13 days ago
Alright, you guys convinced me. When I do my BK, I will get the Hard Top.
I was studying the Mirco BK playfield from what little pictures they had on their website and already found 3 spots where they significantly changed the artwork. Why you would go through the trouble of reproducing an entire playfield and then mess with the original artwork design is completely beyond me.
#1733 10 days ago
Terrible picture but beutiful hardtop install.
#1734 5 days ago
Is that an original Lizard's head? I have a hardtop that I'll be installing eventually, but the head on mine is beat to shit! Hoping to find a better example out there somewere.
#1735 5 days ago
Now that Gorgar has been announced, my prediction for the next release: Supersonic." (I'm going to keep doing this until it's true).
#1736 5 days ago
Myself and many others are still hoping that the upper and lower playfields of the Bally Elektra will be on the list soon. I'd be up for one or two sets of those.
#1737 5 days ago
Quoted from dyopp21:
Yep, original.
#1738 5 days ago
Quoted from Graysonsdad:
I have been asked by a friend to cast my vote for a Black Hole Hardtop. It's his only game and the Mirco playfield costs a first born child. (Also he'd likely have me do the work and I dont want to do a playfield swap lol)
What would you charge for a strip down, hardtop install and rebuild for a HS ? I know you're in the process... and being next door in burlington with one that would definitely benefit from a Hardtop... I'm curious.
(side note: check your PM's... sent you a message a while ago)
#1739 5 days ago
Quoted from Canuck_pinhead:
I wouldn't know where to begin. I just fix my own games. Ive never charged anyone for work. I work at a relaxed pace. Not a lot of free time these days for pinball repair. My HS has been stripped since July. Ill let you know how it goes.
#1740 5 days ago
Fair enough. Time is my issue too.
#1741 5 days ago
I'm hoping and waiting for a hardtop for:
Police Force
Earthshaker
Diner
#1742 5 days ago
I agree. Every time I play my Supersonic, I cringe that more damage is happening to my playfield. I know it is not the most popular game, but still popular and 10K units produced.
#1743 4 days ago
Quoted from Skidave:
I did a time lapse of all the work I did to my SS, but the crappy vinyl sticker I put down is completely jacked (my fault most likely because I sprayed it with poly). So I can’t wait to be able to “get it right!”
#1744 4 days ago
Awesome video and work!! Sorry it developed issues.
#1745 4 days ago
Indeed, that's a very cool video. Nicely produced!
#1746 4 days ago
What bit do use use to cut lexan holes? Make my own protectors and a little less manual work would make it go quicker. Thanks.
#1747 4 days ago
Quoted from Beemus:
Drywall bit. Then I'll do the cleanup/finish with xacto knife.
$ 50.00
