BBH Pro to World games:
Replacement Motherboard options:
Must be AM3/AM2 dual core AMD processor, prior to FX chips
Minimum 512mb of ram
Serial port
3 or more USB ports (if you update to World, need at least 3)
Dell Optiplex 740
CPU: AMD Phenom 3-4core or Ahtlon 64x2
North Bridge: Nvidia Quadro NVS 210S
South Bridge: nForce 430
Video: Nvidia NVS 210S graphics3
Audio: Sigmatel 9200 HAD Codec
Dell Optiplex 580 (on Betson’s site)
CPU: AMD Phenom II X2 or Athlon II X2
RAM: 1GB DDR3
North Bridge: AMD 785G
South Bridge: AMD 785G
Video (integrated): ATI Radeon HD 4200
Audio: RealTek ALC269 High Definition Audio
Biostar N68S+ chipset
CPU: AM2+/AM3 socket
Chipset: Nvidia MCP68S
Ram: DDR2
Video: Nvidia GeForce 7025
Audio: Realtek ALC662
Asrock N68C-GS4 FX – Does this work? (on betson’s site as well)
CPU: AM2/AM3
North Bridge: Nvidia GeForce 7025
South Bridge: nForce 630a
Ram: DDR2/3
Audio: Realtek ALC662 / VIA VT1705
Hard drive replacement:
You can use SATA or IDE hdd. Recommend 40GB or bigger.
Must have restore DVD OR block copy the original to new hdd
Order from Raw Thrills for $10
Install HDD w/ proper jumper
Verify in BIOS the HDD is recognized
Make sure cd/dvd-rom is set to boot first
Put restore DVD in drive
Reboot PC
Restore will happen automatically
Remove disc’s and reboot
Faster RAM or SSD HDD can help with some lag
How software versions work:
Software versions can be updated while using the same USB security key for that specific game. If you convert a Pro to Safari, you’d need the safari USB key and restore disc’s.
How upgrade kits work:
There are a few similar games
Pro, Pro Open Season, Safari and World
They all run similar hardware in the standup 27” unit
Pro, Pro open season and safari can be “upgraded” to run World.
World is just Pro open season and Safari together. So in theory you get 2 big games in one BBH unit.
Each version of the game requires a USB security key and Restore dvd.
For instance if you have a Pro and want the world update. You will have installed a pro usb, open season usb, and world usb. Along with the World restore dvd.
Restore dvd’s can be purchased from Raw Thrills to get a DVD or download iso image to burn yourself at $10 and $5 respectively.
USB Security keys need to be purchased from Betson or found used from a Operator, used market or distributor.
Added over 5 years ago:
BBH HD Software
Purchase from raw thrills
https://rawthrills.com/media/software/bbhd/
