Quoted from NeilMcRae:[quoted image]
Why do you need this? Didn’t one come installed on that ramp?
Edit: Is it just to give it some more rigidity?
Oh wow, I had no idea this was even an issue.
I have no idea what you are showing here... need to add some text to your post.
If you are trying to stop the "rejects", a piece of lexan on the side to cover the large opening works great!
Quoted from Fezmid:Are there higher quality coil stops to buy? How do I know that I'm not buying a crappy one?
Quoted from PinMonk:The pinball life ones hold up really well for me.
Yeah, Pinball Life offers a good, inexpensive coil stop.
Quoted from PinMonk:SD Card. Get a good one. Make a new image on it using the images in stern's support area, try that. A very common point of failure because Stern uses crappy cards.
https://sternpinball.com/support/sd-cards/
That was it! Ironic that this was caused by me replacing Stern's SD card with my own crappy one for 0.95. New card did the trick, thank you very much. That reminds me, I need to send you an order for another fan. God do I hate the ones Stern puts in.
Quoted from Metroshica:That was it! Ironic that this was caused by me replacing Stern's SD card with my own crappy one for 0.95. New card did the trick, thank you very much. That reminds me, I need to send you an order for another fan. God do I hate the ones Stern puts in.
Glad that was it! You definitely want a good quality Class 10 SD card in there to prevent problems like the one you saw (and freezes, lockups, glitches, etc).
I hear you on the fans. Every time I get a new machine in to do mods and test temps, etc, I always tell myself I'm not going to take the time to do the fan replacement, and every time by the end of the first day, I change it out. The noise drives me crazy.
Quoted from Pinballpal:Did you make this or did it come from Stern?
I haven't had it but the person who took the photo's got it from Stern.
Quoted from awesome1:I have no idea what you are showing here... need to add some text to your post.
sorry - see further up the thread. I don't know what this does. But I knew it was a part on offer from Stern. Our parts service to the UK is pretty dire so I want to make sure our distributor knows to be asking for the things we might need, right now there is no working subway in any avengers in the UK, a few dodgy disks and some other issues but our distributer doesn't ask for things unless he knows he needs to ask for them.
Neil.
Quoted from cooked71:Smart dog with good taste.
At first I was thinking "bad dog!" But then I remembered how much our cat loves playing pinball with me (if nothing else than to avoid our 4 dogs )
20200712_172421 (resized).jpgI think I found a bug in the code on my LE. I haven't tried to recreate it yet because I'm not 100% sure how... But at a high level, here's what happened:
* Started Reality Gem mode
* Hit several combos during Reality Gem mode.
* Completed the mode, placed the gem on Hulk.
* Two portal locks were available, so locked the two balls
* After the second ball locked, I wasn't given a new ball in the trough. Had to wait for ball search, and it eventually ejected a ball from the lock for me.
* Started Power Gem mode. As expected, the one remaining ball in the lock ejected, and a third ball came from the trough - giving me three.
* Started Thor mode during Power Gem Mode.
* Had a great (for me) mode, new high scores for Thor and Power Gem (completed, not claimed). Drained two balls at once to end both modes, screen shows my scores, and the trophy room is displayed. No balls, no end of ball bonus (like I should've seen from draining).
* After a few ball searches, the screen says "missing pinballs," ends the game and gives me end of ball bonus.
After that, things seemed normal - I was able to start a new game, so it is detecting the balls just fine. Definitely seems like an issue because I locked back-to-back balls I guess? Anyone else encounter anything similar?
My hart is still pounding, what a blast of a game.
Sometimes i hear: time for the Hulkbuster suit? What does it mean
Would it be cool if they made a mode out of that.
I hope there will be some more mini modes, call outs and animations.
Watching all the Avengers movies again and there is so much material. This wil be a long time keeper for me, pure fast action.
Quoted from Fezmid:I think I found a bug in the code on my LE. I haven't tried to recreate it yet because I'm not 100% sure how... But at a high level, here's what happened:
Sounds like you would have had 4 balls on the field (if you still had your 3 from portal locks out when you started thor)?
Quoted from dutchi:My hart is still pounding, what a blast of a game.
Each character has certain random (2 or 3) phrases they say when you level them up. This is one of Iron Man's phrases when you level him up (after collecting him already). Black Panther will say "The claws of the black panther!", BW will say "Can you stand the shock of my widow's bite?", etc.
I don’t isually pay attention to the hulk tilt call outs but I heard a funny one that I don’t remember hearing before.
“Hulk didn’t tilt, It was puny Banner”. The way he said it was pretty funny.
Just to share, my own fix for the ball getting stuck under the gauntlet, if you don't want to add extra bumpers.
My solution was to remove the plastic and shorten the two posts that hold it up by around 1/32 - 1/16 (using a dremel). I think the plastic posts might be slightly out of spec because the screw rod going through them doesn't fully seat in them on they top like it appears is intended, so the plastic may be sitting a bit higher than on the prototype games. Either way, once I did this it created enough clearance under the gauntlet to not have a ball get stuck.
Quoted from dbb143:Sounds like you would have had 4 balls on the field (if you still had your 3 from portal locks out when you started thor)?
No, I locked two balls in the portal, and then wasn't given the new ball to replace the newly locked second ball. Instead, one of the two locked balls ejected from the subway (after a ball search). When I put that ball in the portal to start the Power Gem mode, I should've (and did) have three balls - two from the lock, one from starting the mode (which, in this case, was one locked, one to start the mode, and one ejected new since there weren't two balls in the portal anymore). Does that make sense?
Edit: Oh, are you saying I should've had a fourth ball because of Thor multiball? Hmm, that's possible... I don't know when I started Thor, maybe I drained one first... Or maybe that's part of the bug. Not sure....
Quoted from PinMonk:That's great to hear! With the fans it's held the coils in the 100-110F range in all the testing on many machines now, so fade isn't holding anyone with these cooling kits back from seeing more of the game - it's all down to skill at that point.
Wait so normal flippers will start to fade after time? How long does this normally take?
Quoted from newpinbin:Wait so normal flippers will start to fade after time? How long does this normally take?
Yes. It's due to the fact that electricity encounters more resistance to flow as heat builds up, requiring more electricity to work, making more heat, and on and on. There's a Q&A about it and a link to an online interactive demonstration about electrical resistance on the bottom of the product page here:
It usually takes about 30-40 minutes of continuous play to start getting fade bad enough to notice. Some machines are really hot, fast, like Stranger Things and Rick and Morty (the 90 minute test temp champ so far). If you don't play continuously for 30-40 minutes, or take breaks between balls for a few minutes at a time while playing, you likely don't need to worry about it and will probably never encounter it.
I have plug and play kits for Stern Spike and Spooky machines. JJP kits are up next, then backwards to B/W machine and older Stern (LotR, I'm coming for you, and will have it out before LotR Spike hits).
Quoted from vicjw66:I don’t isually pay attention to the hulk tilt call outs but I heard a funny one that I don’t remember hearing before.
I got this one once! Except hulk not use contraction
I’d probably hear it more often if I raised the bob...
Quoted from Fezmid:Edit: Oh, are you saying I should've had a fourth ball because of Thor multiball? Hmm, that's possible... I don't know when I started Thor, maybe I drained one first... Or maybe that's part of the bug. Not sure....
This.
Quoted from PinMonk:Yes. It's due to the fact that electricity encounters more resistance to flow as heat builds up, requiring more electricity to work, making more heat, and on and on. There's a Q&A about it and a link to an online interactive demonstration about electrical resistance on the bottom of the product page here:
https://pinside.com/pinball/market/shops/1170-pin-monk/04203-tibetan-breeze-flipper-coil-cooling-kit-spike
Thanks for the info. Never heard of this before.
Quoted from Eightball88:I got this one once! Except hulk not use contraction
What made it funny was that when Hulk blamed Banner he said it in a quiet voice, like he didn’t want David Banner to hear Him throw Banner under the bus.
Quoted from vicjw66:What made it funny was that when Hulk blamed Banner he said it in a quiet voice, like he didn’t want David Banner to hear Him throw Banner under the bus.
I hadn't heard the name "David" Banner in a while... Oh yeah, that was the Hulk's alter ego on the Bill Bixby/Lou Ferigno TV show...
Bruce Banner in the comics/movies.
Quoted from awesome1:I hadn't heard the name "David" Banner in a while... Oh yeah, that was the Hulk's alter ego on the Bill Bixby/Lou Ferigno TV show...
I always watched that show every week. I haven’t watched any of the recent Marvel movies with Hulk in them. I suppose when I have 30 or 40 free hours I should.
Quoted from pascal-pinball:Question: is that hot flippercoil / weak flipper problem LE only? Or also in the premiums?
It is possible on any machine with flipper coils, but the design of the software and coils chosen by the designers seems to influence which have more problems with heat than others. On the product page, there's a chart with the Spike2 and Spooky machines tested so far and the temperatures noted after 60 or 90 minutes of play. If you play less than 30 minutes continuously at a time, you likely will never see coil fade and don't need the kit.
Ministry of Pinball carries the kits now (Here's the Spike2 one: (https://www.ministryofpinball.com/en/tibetan-breeze-spike-2-flipper-coil-cooling-kit.html) to save European customers on shipping and taxes. The base cost is more, but all things considered, it should be slightly cheaper and faster delivery to order from them if you're in Europe. The only thing they don't have yet is the 3 flipper kits, but add on-expansions for the 2 flipper kits are coming so if you have a 2 flipper kit, you can expand it to a third flipper later.
Quoted from PinMonk:It is possible on any machine with flipper coils, but the design of the software and coils chosen by the designers seems to influence which have more problems with heat than others. On the product page, there's a chart with the Spike2 and Spooky machines tested so far and the temperatures noted after 60 or 90 minutes of play. If you play less than 30 minutes continuously at a time, you likely will never see coil fade and don't need the kit.
Can vouch for these. Bought them before my machine even came. Installed day one. Had several people playing it for a Twitch online stream (PinballwithFear) and never had any fade whatsoever. The couple times ive checked the coils have been at room temperature. Very nice!
Quoted from dutchi:What do you guys prefer mirror or the stern artblades
On this game i like the Stern art blades.
Tiltgraphics without the characters for me, blends perfectly and looks great!
D92DC858-2807-450D-AFA7-E155B8EA1EC7 (resized).jpegQuoted from AUKraut:Tiltgraphics without the characters for me, blends perfectly and looks great!
I agree with Tilt Graphics no characters.
Would anyone be interested in this mezel mods tower? It doesn’t have the led strips in the top and it looks like the prior owner used a soldering iron to remove material to make the tower fit better before the Mezel fix.
Looking to get what I paid back for it $75 shipped in the US.
This is the old ad for it:
https://pinside.com/pinball/forum/topic/mezel-tower-mod#post-5984942
Quoted from jdoz2:Would anyone be interested in this mezel mods tower? It doesn’t have the led strips in the top and it looks like the prior owner used a soldering iron to remove material to make the tower fit better before the Mezel fix.
PM sent.
First the Bills win their first playoff game in a quarter of a century, and then I get a new GC score! It is low compared to many, but I had a blast. Even got 11 trophies! I should read up on how the gems work and what they do.... but in my free time, I would rather play than read!
20210109_172103 (resized).jpgQuoted from dutchi:What do you guys prefer mirror or the stern artblades
I cancelled my Stern blades as they were too much of the same art on a premium. I went with some generic space ones from pingraffix that were originally intended for a Star Trek.
Im not home to take a pic but they work really well.
Wasted Screen info.
I love my AIQ, Combo shots are very satisfying.. The game is set up for combos, so if instead of showing a "trophy room" why not tell you how many combos you are up to? The graphics and info on the game can be updated big time. The game is awesome, but they need to put more info on the screen.
Quoted from mwthatch:Wasted Screen info.
you should watch this:
That trophy room as the screen we see most of the time just has to go! so boring!.
Quoted from Kevlar:That trophy room as the screen we see most of the time just has to go! so boring!.
agree.
omg I just got through 10 pages of it took me several hours, read a lot of info...
I just bought this game ( I am in Canada ) and I am getting it next month, I read about coil fading, coil fans (???), shooter lane protectors, mylar, shakers....
Can anyone from Canada direct me to the right place to get the parts that I will need to be prepared. I do not like waiting for parts and would like to have a nice arsenal of parts that would/could need replacement...
Quoted from KnockerPTSD:What do you guys prefer mirror or the stern artblades
Mirror blades look really sharp!
AIQ Pinstadium (resized).jpgQuoted from Mtg381:Mirror blades look really sharp!
I second mirror blades, they look amazing on this machine.49FCD03D-BD98-4C81-BDD6-F3928B5BAC46 (resized).jpeg07972E86-B49A-48C3-88C6-5132A006BBFF (resized).jpeg15F394E8-216D-4284-BB7E-0128C413B02A (resized).jpeg15F394E8-216D-4284-BB7E-0128C413B02A (resized).jpeg
That looks also realy sharp !!
Oh men.. first world problems
I’m kinda bummed they took out the widow to panther combo. I loved trying to set up that shot.
I realize it might have to do with the major amount of points you can get, but I wish it would come back. It was one area I would focus on if the game wasn’t going so well.
Quoted from spandol:I’m kinda bummed they took out the widow to panther combo. I loved trying to set up that shot.
Yes I called that the “RayDay Combo”. He exploited that combo for 7 billion and in the next code update it was gone
This page was printed from https://pinside.com/pinball/forum/topic/official-avengers-infinity-quest-owners-thread-pinsiders-assemble/page/85 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
