Quoted from CashMoney:Finally received the updated subway mech from Stern today. Thought I’d share with the group. Took a little over a month.[quoted image][quoted image]
That's a subway, not the mech
What was your issue?
Quoted from CashMoney:Mirror side blades from Cointaker installed. Pics don’t do it justice, such a great mod for the price.[quoted image][quoted image][quoted image]
Yay! Someone else did purple titans too
Quoted from Meegis:That's a subway, not the mech
Yes, you are correct, just the subway.
My issue was balls getting stuck right before the antman plunger. It only happens in MB when multiple balls go into the Antman scoop. This updated subway solves that issue.
Quoted from CashMoney:Yes, you are correct, just the subway.
Mine does the same thing, constantly. Drives me nuts! How did you get stern to send you one? I tried getting one and was shipped the walking mechanism, not the subway plastic. Took more than a month to get that. Sent it back. Stern’s customer service is very hit or miss.
Quoted from 1963BSARGS:Mine does the same thing, constantly. Drives me nuts! How did you get stern to send you one? I tried getting one and was shipped the walking mechanism, not the subway plastic. Took more than a month to get that. Sent it back. Stern’s customer service is very hit or miss.
I was told to always go through your distributor when dealing with issues. They are the ones that have the direct connection with the technicians at Stern so usually you will get a faster response. Send them a copy of the subway part I showed and that should help.
Quoted from CashMoney:I was told to always go through your distributor when dealing with issues. They are the ones that have the direct connection with the technicians at Stern so usually you will get a faster response. Send them a copy of the subway part I showed and that should help.
Thanks. Its frustrating because the problem seems to be getting worse. Played perfect out of the box, but it now seems to have a low spot in the subway.
Quoted from delt31:I tried the pass through and it didn't work like I you described so I must be missing something. Is there anything else you need to do?
I think you missed the first sentence. I removed the subway mech that stops the balls. lift the playfield, unplug subway mech and remove the two nuts holding it in place.
MY Avengers pro should be here in 5 hours! Cant wait! My cliffy shipment hasn't made it in do you think i should wait or play it?
Quoted from Rocketrob:MY Avengers pro should be here in 5 hours! Cant wait! My cliffy shipment hasn't made it in do you think i should wait or play it?
Play the shit out of it. Don't wait.
My premium is stock from the factory and I've got hundreds of games on it.
Quoted from Spaghetti73:My own Made solution, seems to be working well pending the replacement
Very nice. Oddly watching the ball advance in my subway it looks like a pinball bouncing back and forth. Was planning to pull it apart later today to see if anything could be shaved down. I find I am having to shake the cabinet to get the ball to advance in the subway, what a pain.
Make sure to turn down the ball eject power in the adjustments menu and I think you’ll be fine.
Quoted from Indusguys:Make sure to turn down the ball eject power in the adjustments menu and I think you’ll be fine.
This...
I only had 30-40 games and I had already seen the far side of the ball channel starting to chip. I turned mine down a ton.
I've started playing the Battle Royale Challenge more often. It's fun, doesn't take too long and is unique enough from the regular game (I know it's a mode in the game... been there several times) that you have to work on certain shots to do well. Wish it would show your time at the end of each game as well as your score though.
Quoted from awesome1:I've started playing the Battle Royale Challenge more often. It's fun, doesn't take too long and is unique enough from the regular game (I know it's a mode in the game... been there several times) that you have to work on certain shots to do well. Wish it would show your time at the end of each game as well as your score though.
I’m also enjoying the challenge mode, notice my regular game play getting better since I started playing these challenges
Quoted from Ericc123:soulstoner Where did these post this?
I found it in the "Next Stern Pin" thread. It looks accurate based on what I've heard from a couple distro's and second hand information about expected deliveries of other pins like Deadpool (TDB).
Thanks to this thread, I found the Battle Royale mode -- it's pretty cool, and I doubt I would've found it on my own. I've only won once out of three attempts (I suck at pinball...), but it's a nice change of pace!
Quoted from Cobra:How do you start it?
Hold both flippers down for a couple of seconds before starting a game and you'll get a menu asking if you want to play regular, competition (no randomness), or Battle Royale. Select using the flippers, then push the start button. It's awesome.
This should really be a sticky post (whoever first posted about it, anyway).
Are we ever going to get an Adam Warlock coded into the game? He's featured on the PF but there's nothing in the game that references him... very strange. A mini-wizard mode would be cool.
Quoted from CashMoney:Are we ever going to get an Adam Warlock coded into the game? He's featured on the PF but there's nothing in the game that references him... very strange. A mini-wizard mode would be cool.
Plus, no Thor on the premium translite...what’s up with that? Unless I’m missing something.
Quoted from Eightball88:Plus, no Thor on the premium translite...what’s up with that? Unless I’m missing something.
Haha yes, I was thinking about that too...super weird.
The one I don't get is - they couldn't hide Stan Lee somewhere ? After all no Stan Lee no Marvel World .
Great, now I can't unsee that...
Quoted from TenaciousT:The one I don't get is - they couldn't hide Stan Lee somewhere ? After all no Stan Lee no Marvel World .
That's more of a movie thing not a comic thing but I agree that would have been a nice Easter egg.
Quoted from Fezmid:Hold both flippers down for a couple of seconds before starting a game and you'll get a menu asking if you want to play regular, competition (no randomness), or Battle Royale. Select using the flippers, then push the start button. It's awesome.
Is Battle royale the same as Battle for Thanos?
Quoted from dutchi:Is Battle royale the same as Battle for Thanos?
No. It was included in early code, but they yanked it. (Presumably for a big splash of awesomeness at a later date.) There are different high scores for each.
Quoted from Broohaha:No. It was included in early code, but they yanked it. (Presumably for a big splash of awesomeness at a later date.) There are different high scores for each.
Thanks ! So i am not gonna see the end when i start with this battle in the beginning good stuff. Maybe i will never see the end lol but i certainly dont want to see it in the honeymoon fase.
JP you can start with the end game correct?
I am so happy with my pro
Battle Royale is reachable in the regular game by assembling all of the Avengers for a third time. Not sure if there are minor differences in the "regular" version and the stand-alone game version as I've only been to the in-game version a handful of times so far.
Yeah - I'm looking forward to getting Thanos back in the game since I've made it through the 6 gem quests (not all successful) a couple times now.
That would have been pretty cool to sneak him in the art somewhere. Too late for that I guess but maybe they could sneak an image of him onscreen somewhere.
And while they're at it maybe fit an image of Keith Elwin in there too like they did on JP2. That was pretty funny. It would be fun if it became a regular thing in his games.
Quoted from Ericc123:That's more of a movie thing not a comic thing but I agree that would have been a nice Easter egg.
Nah, I think it would be perfect. Stan Lee was in Marvel comics way before the movies were around. I'm not a comics buff, but I think he created the Avengers comics.
Quoted from EaglePin:And while they're at it maybe fit an image of Keith Elwin in there too like they did on JP2. That was pretty funny. It would be fun if it became a regular thing in his games.
Elwin is in IMDN too - in Fear of the Dark I believe. A ghost follows him around. It was the default graphic, now it's an easter egg and you can select how often it comes up in the settings.
Quoted from Ericc123:eaglepin He did create the Avengers. I'm just saying that the obligatory Stan Lee cameo was more of a recent thing with the MCU. He created 100's of characters for Marvel and was basically Marvel in the silver age but he didn't appear in the comics himself many times.
Except the back of every issue for over 2 decades. Also some of these spider gems
That last one would he a perfect way to go but it wont happen. Stan Lee's likeness isnt Disney (i hope)
Screenshot_20201209-204247_Google (resized).jpgScreenshot_20201209-204030_Google (resized).jpgI have an LE. In the past few days, whenever the shaker motor goes off, at the end it makes a weird sound like a wheeze. I also recently updated to 0.94. I am assuming this is some sort of mechanical issue and not a sound effect that was added. Has anyone experienced something like this?
Quoted from lockeness:I have an LE. In the past few days, whenever the shaker motor goes off, at the end it makes a weird sound like a wheeze. I also recently updated to 0.94. I am assuming this is some sort of mechanical issue and not a sound effect that was added. Has anyone experienced something like this?
I have a shaker in my Premium and am running 0.94 and have had no issues or new noises from the shaker.
It's easy top unplug the shaker connection from the board to help isolate the sound. It could be the shaker motor bearing or the shaft weight rubbing on the plastic cover or similar.
First time ive played though all 6 gems.
Collected red, orange and yellow. (power, reality and time)
Lost purple, blue and green. (space, mind and soul)
Pretty bummed i lost the Soul quest.
Third time to Black Order MB
Two Iron Man MB
Two Thor Multiball
One Three ball quest
One extra ball.
I still like Maiden more but Avengers is getting closer. Cant wait to see the final product.
It's 100% your shaker motor just squeaking. You just need to grease it up a bit. Had the same issue with mine and it was driving me nuts.
Quoted from Soulstoner:It's 100% your shaker motor just squeaking. You just need to grease it up a bit. Had the same issue with mine and it was driving me nuts.
This.
I had this issue on some of my games in the past. It is possible it may fix itself over time, but you can also just clean it up a bit if theres dirt. (dont know about grease, never did that myself)
I'm not into toppers personally, but I saw this and thought someone might be interested.
Capt 'Merica figure on woot.com $18
https://home.woot.com/offers/avengers-marvel-captain-america-figure?ref=w_cnt_wp_0_2
This page was printed from https://pinside.com/pinball/forum/topic/official-avengers-infinity-quest-owners-thread-pinsiders-assemble/page/71 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
