(Topic ID: 277423)
Official Avengers Infinity Quest owners thread. "Pinsiders Assemble!"
By Scribbles
1 year ago
  • 8,924 posts
  • 683 Pinsiders participating
  • Latest reply 4 hours ago by Plungerboy
  • Topic is favorited by 297 Pinsiders
Topic poll
“Of the Avengers featured on the inserts, who is your favorite?”
  • Hulk 103 votes
    20%
  • Iron Man 94 votes
    18%
  • Captain America 62 votes
    12%
  • Black Widow 38 votes
    7%
  • Thor 61 votes
    12%
  • Black Panther 26 votes
    5%
  • None of those weakling, THANOS! 135 votes
    26%
(519 votes)
19 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 8,924 posts in this topic. You are on page 31 of 179.
#1501 1 year ago
Anyone been playing with the challenge mode yet? It's pretty cool. I'm not so good at it yet. But, I was victorious a few times.
14
#1502 1 year ago
Just finished up powder coating and changing out T Molding on my pro. I was torn going with the yellowish Gold but now that its done I love it. I opted not to go lollipop rails because i love the art around the flipper buttons.
796ED108-D338-4F6A-97E4-0D6F4478A54D (resized).jpegB9FB7B16-16E5-45F7-80EA-D9D1FC3B8FFF (resized).jpeg
#1503 1 year ago
Quoted from Swoods5688:
[quoted image][quoted image]
Looks fantastic!
#1504 1 year ago
I spoke to soon... GI on the right side seems to have gone out. Any thoughts?
#1505 1 year ago
Quoted from adamross:
Don't know a ton about repairs but this happened on my High Speed one time. Turned out to be a blown fuse.
#1506 1 year ago
Quoted from BirdForce1:
No fuses on Spike2, with the game turned on lift the playfield and check all the node boards, they should all show a green led and red led, no green means it’s dead.
#1507 1 year ago
First thing I would do is lift the playfield and check your node boards down on the bottom of the playfield and around that area, each node board should have a green and red LED, one indicates power to the board (red I think) and one indicates the board is communicating/working (green) if one of those is likely the issue if the whole area is without GI.
#1508 1 year ago
I had a section of GI on my Deadpool LE that wouldn't light, turned out to be a bulb short triggering the overcurrent protection. I did get an overcurrent protection warning when I turned on the machine though.
I would remove and check each bulb in the section that is out.
#1509 1 year ago
Quoted from J85M:
Nice Vic! Very nice! Have you finalised pricing?
Not yet. I'm using a couple standoffs that slide into the back to reinforce it and metal standoffs are ridiculously expensive for what they are, and I don't want to drop down to nylon ones. So I need to settle on which kind of metal standoffs I go with (and what height - there's about a 3/8" range of difference in the various ones I'm playing with). I also need to finalize the stabilization piece for the standup with the windows so it doesn't sag (which is part of the reason the stock one is obscured, too). I should have it figured out probably over the weekend or by next week for sure, but just lots of small details are still in flux that would affect the cost. The best part of it for me is that I was able to get the Dr Strange plastic to illuminate pretty well also by bouncing the side flasher light back up. Looks cool.
#1510 1 year ago
Thanks everyone, seems my Pinstadium lights were causing the short. Strange I've used them in most of my sterns and never had such an issue.
#1511 1 year ago
my right ramp that goes around the gauntlet has stopped registering shots. I am guessing it is an opto but don't know what to do or how to verify. Any help would be appreciated.
#1512 1 year ago
Spike is extremely fussy with voltage. You may be just a hair low on this machine and adding pinstadium pushed it over (or the pinstadium strip itself may have a problem causing too much voltage draw). Check the output of the power supply to make sure it's putting out a solid 48v to the power distribution board. If it's not, there's a pot that can adjust the output.
#1513 1 year ago
Quoted from BigT:
Put the game in switch test mode (using the buttons inside the coin door). Pull out the white post inside the left of the coin door frame so the playfield is powered while the door is open and wave your finger in front of the optos to see if it triggers them.
#1514 1 year ago
Quoted from PinMonk:
ok...just did that and it did not register. other switches did register.
#1515 1 year ago
Step one of any trouble shooting should always be removing mods to rule them out.
#1516 1 year ago
Quoted from BigT:
Look at the little lights on the opto circuit board and (while switch test mode is still on the screen) wiggle with wiring to see if the board LED goes on or off when you do, indicating a short. Also try pressing on the board in various directions. Switch test mode may trigger as you do this to tell you you're getting close to the problem.
#1517 1 year ago
Quoted from BigT:
Verify alignment of the 2 optos for that switch : transmitter/receiver. They have to be in direct line of sight with each other to work properly.
#1518 1 year ago
I definitely recommend powering any mods separately and not leeching off the pin's power.
#1519 1 year ago
Thanks...this fixed it. touched the red wire on the the right opto. Light came on the left opto and it is now registers. thank you for the help!!
#1520 1 year ago
Go with metal stand offs if you need to Vic I’m sure people would be happy to pay the extra for a couple of metal standoffs.
There’s some truly terrible mods for this game, this one is one of the very few must haves for this pin!
#1521 1 year ago
FYI for anyone having any issue on any game in the future, if you have powered mods installed, try disconnecting those first, or at least mention you have them before just saying "my GI is out."
#1522 1 year ago
Anyone else having this issue?
Ball traverses the subway, gets past the LAST set of fingers and just sits there. Seems like there is a bit of a”dip” in the subway in that spot just before it dumps the ball to the VUK, have to nudge machine every time to get it to drop to VUK or it will go into ball search
#1523 1 year ago
Quoted from Wolfmarsh:
Why? There’s plenty of power available if you know what you are doing and don’t go crazy. I’ve never ever had a power issue with a spike game, or any game really.
Haven’t experienced this. What have you tried to power and had an issue?
I’m not sure about pinstadium, but I thought they power them externally? Might be wrong on that. If they do draw power from the game, that’s adding like 60-100 leds, and that could cause issues. I do believe they do a lot of backstabbing and alligator clips. If not done securely, that can cause an issue.
#1524 1 year ago
Is anyone working on a mod for the pro for a better indicator for the sanctum lock being lit other than the light on the playfield? I always find i miss alot when it was lit and just like to have a better visual
#1525 1 year ago
Yeah, my pinstadiums have a wall wart.
#1526 1 year ago
Link to Cliffys basic protection set for AIQ:
https://www.passionforpinball.com/wip.htm
#1527 1 year ago
Quoted from Lermods:
I personally haven't experienced it, but I am very careful to check amp draw, etc before I do anything (although I will say that the fused harness for the tibetan breeze flipper coil cooling kit does exactly what it's designed to do to protect the node board, I blew a fuse on it during development when I inadvertantly shorted it).
However, I have seen a number of occasions where people have had some mod they DIY'd or bought cause issues. Alligator clips are often involved.
#1528 1 year ago
Quoted from J85M:
Well, thanks for the vote of confidence! Non-metal standoffs are out of the question. I just can't do it. The question is whether I find brass, steel, stainless steel, or aluminum at the best price. I want steel or stainless steel, but they are pricier than aluminum or brass. I'll figure it out. I've taken to calling this mod the Dr. Strange tuna can almost from the beginning, because it looks kind of like a tin of sardines before it's put together. That may be the final mod name because I've called it that so much I can't imagine it being called something else. But maybe when I write the story for the product description, something else will happen. Pinmonk DOES have a cat, so...
#1529 1 year ago
Because all spike machines have properly calculated power budgets. Leeching power from the pin can push them over that budget. These aren't the machines of old where you could just tap into power willy-nilly.
I can understand why you'd not like my statement though, given your business.
#1530 1 year ago
The best place to get power from spike is the coin door interface board, using features that are not used by most people (all those empty connectors are 5v and 12v power, depending on the connector). Those each have varying available power budgets of up to 2A depending on the connector, which is a lot. And if there's fused protection built into the mod, it's pretty low risk. But I agree that drawing from outside the spike system (service jack, for example) is the only truly foolproof way.
#1531 1 year ago
Pinstadiums get their power from the service outlet. No issues there. The GI tap from the game to the Pinstadiums simply triggers a relay to tell the pinstadiums to turn on/off with the machine. Shouldn't have any issues at all. Maybe one of the GI taps got shorted?
#1532 1 year ago
Has nothing to do with my business. We are careful to not overload the system. You have 2a from the backbox, that's plenty to run several small mods. many people make it sound like you'll blow up your machine. I'd be more worried about improper install than a power issue. Ps is a good example. I saw a guy post on a Wonka install, backstabbing connectors, loose hanging alligator clips, etc.
#1533 1 year ago
Quoted from MT45:
Haven't seen that complaint, but I'd add a washer to the subway end or the VUK, depending on which side needed to go up or down, so there's a smooth transition or a drop from the subway into the VUK so the ball can get into it freely.
#1534 1 year ago
Quoted from Flippersaurus:
5:12 is my best so far. It’s great practice.
#1535 1 year ago
Whoa...definitely w Wolfmarsh and PinMonk on this one. A couple of blinky, 3D toys is one thing, but I've seen power sag and game resets on many games from underglow or any LED strings of substance. ColorDMD pulls it's share too. CFTBL was notoriously "on the edge" as was TZ and others.
Seperate power for the mods = happy game....
#1536 1 year ago
Quoted from MK6PIN:
Whoa...definitely w wolfmarsh and vireland on this one. A couple of blinky, 3D toys is one thing, but I've seen power sag and game resets on many games from underglow or any LED strings of substance. ColorDMD pulls it's share too. CFTBL was notoriously "on the edge" as was TZ and others.
Yep, under cabinet led strip and ColorDMD on my Dredd was too much = blown fuse
#1537 1 year ago
yea my wonka wouldnt work properly with pinstadiums installed. Gobstopper stopped working and turned out to be a fuse or something. Without pinstadiums its fine. So I guess its common across different platforms.
#1538 1 year ago
Quoted from MK6PIN:
I Think maybe we need a separate thread on this. It’s an interesting issue for sure. Let’s keep it to AIQ here. Sorry for the diversion.
#1539 1 year ago
This will be my first pin with a magnet. Certain balls to avoid? I know I've seen a thread on this before somewhere.
#1540 1 year ago
Don’t buy the chrome shiny balls like ninja balls or from Marco the silver jet balls. They have warning notes when buying them, but they are susceptible to magnetization. I had put silver jet balls in my stern spiderman and within a couple games, the balls were magnetized and stuck to the ramps and shooter lane!
#1541 1 year ago
Agreed....it's been discussed elsewhere....apologies....Avengers Assemble!!! having a blast playing this thing!!
#1542 1 year ago
I played the AIQ pro at game galaxy In Smyrna TN. This particular game played terrible, but I could tell it’s going to shoot great and I’m excited to get mine.
This game had lightning flippers and the right one wouldn’t travel all the way and was super weak. Super tight tilt and no ball save made it pretty infuriating to play, but at least it was on free play.
#1543 1 year ago
Carbon Steel balls for any game with a magnet
#1544 1 year ago
Quoted from jdoz2:
Why would anyone do this? What a stupid thing to do to a new pin.
#1545 1 year ago
Quoted from MT45:
What pitch is your game at ? Mine did this too, before i raised to about 7 degrees.. It still slows down there, and a couple times with a shot into the vuk, ill find the ball resting at that spot, a ball search wont kick it out even as the fingers dont seem to reach there..
#1546 1 year ago
Quoted from jdoz2:
Deleted. Self censored
#1547 1 year ago
Might try that - thx
#1548 1 year ago
This game is amazing. Love it! Did have a ball get stuck here twice...anyone else?
Under the glove both times.
#1549 1 year ago
Quoted from JonCBrand:
Ball Baron Polaris balls here no issues
#1550 1 year ago
Quoted from tbutler6:
what pitch and is it level side to side? Usually that happens to me on other games is when setup isnt perfect
