Quoted from Sleal16:Spinning disc is great on its own...as long as the stock carrier is operating as its should. My OG carrier's copper bushing ends were both falling off and causing the disc to become uneven and not spin correctly at times, so that needed replacement. It was my first pin and wasnt sure how long Stern would take for a service request so had ordered the carrier along with the disc. Well, both carriers came in around the same time so tested both. Disc upgrade+working stock carrier was a great improvement, and using both part upgrades was even way more smoother. I only have one issue with having such long spin times and its during the mind gem. You dont deal damage till the disc stops spinning and if you're constantly shooting and hitting it, you can go a long time without progressing. Sure the points are great, but I'm still very prone on bad shots and draining. After a good return after spinning it, I end up trapping the ball till damage is done before continuing on.
Thanks! Ordered just the disc for now. 10% off this month! Thanks 1956PINHEAD
