I’m looking to buy avengers infinity quest le number 005 if anyone has it or knows who does
Quoted from awesome1:Woohoo! Another game over 4 Billion! That gives me 5 and counting... [quoted image][quoted image]
You need to challenge Keith to a head to head game. My bet would be on you to take him down
Quoted from awesome1:This shows the Hawkeye timing I do sometimes.
Didn't make a full loop this time, but it worked out just fine!
Thanks, that video helps!
Quoted from ykcor1138:Hi, looks awesome! could you send a picture of the full cabinet? I am thinking about changing my pros translight to a premium translight. Curious to see how well it will match?
Thank you! Sorry not the best pics. I can get better ones in the morning.
20A8CBF1-68D6-4EB2-B22F-948758281356 (resized).jpeg75E1D4BB-71A6-4293-9572-3B568F669AD2 (resized).jpegEFE8BD59-5B9B-49A4-8D06-B9F92817B06C (resized).jpeg
Hello pinsiders - I have a help request. I was installing plastic protectors on my game, and in doing so when removing the nut atop the left slingshot where the wireform connects, when using my socket wrench on the nut, about 1/4" of the whole post broke off with the nut still attached. I can't find in the manual what that part is to order a replacement post screw. Can anyone help me out with where I can buy another?
Quoted from BallyKISS1978:Thank you! Sorry not the best pics. I can get better ones in the morning.
Looks amazing! I picked up the translight. Thanks again.
Quoted from PinRat:Hello pinsiders - I have a help request. I was installing plastic protectors on my game, and in doing so when removing the nut atop the left slingshot where the wireform connects, when using my socket wrench on the nut, about 1/4" of the whole post broke off with the nut still attached. I can't find in the manual what that part is to order a replacement post screw. Can anyone help me out with where I can buy another?
Marco specialties, search bumper post and find one with the same specs as yours……they should have you covered.
Quoted from PinballHaven:Marco specialties, search bumper post and find one with the same specs as yours……they should have you covered.
I've been struggling to find the right one there but I'll keep at it
It's funny, we did the exact opposite. We have the premium, and my wife really liked the pro translite better. So we swapped it out.
Quoted from Mrstern:I’m looking to buy avengers infinity quest le number 005 if anyone has it or knows who does
Why that specific number if you don't mind me asking?
Quoted from ykcor1138:Looks amazing! I picked up the translight. Thanks again.
Oh awesome! Your welcome. You won’t be disappointed
Quoted from 1956PINHEAD:You need to challenge Keith to a head to head game. My bet would be on you to take him down
That would be awesome!
Quoted from PinRat:I've been struggling to find the right one there but I'll keep at it
Look at Pinball Life post.
Hope this helps.
Quoted from Damonator:Just bought an AIQ and found this in the bottom - any idea what this is from? It looks like it sheared off of something.
Might be from the subway teeth mech
Quoted from Sleal16:Might be from the subway teeth mech
If it's an AIQ Premium, I think Sleal16 is correct.
Distributor or Stern should be able to help with replacement, I believe some people have used a bolt in the meantime or you can disable the subway in the settings.
Quoted from awesome1:If it's an AIQ Premium, I think Sleal16 is correct.
Yep, found it - thanks guys. I may see if JBWeld will hold it until I get a replacement.
Quoted from Damonator:Yep, found it - thanks guys. I may see if JBWeld will hold it until I get a replacement.
It's most likely the piece that joins the coil plunger to the mechanism... I don't think any of the studs actually go through the cutouts in the plate for whatever reason.
IMG_1300 (resized).JPGIMG_1304 (resized).JPGI've got about 400 games on my premium and I found what looked like a bit of clearcoat and some artwork on it floating around the playfield. After searching everywhere I finally found the chip behind the rail leading into the antman scoop. It's a pretty large loss of clear and artwork but it's all under the plastics at the moment. Gonna send stern an email about it and have sent Cliff an email looking to get the protector for that spot but wow. There is no sign of pooling anywhere on the playfield. It was perfect but for this
IMG_20211123_094039392 (resized).jpgQuoted from C0untDeM0net:I've got about 400 games on my premium and I found what looked like a bit of clearcoat and some artwork on it floating around the playfield. After searching everywhere I finally found the chip behind the rail leading into the antman scoop. It's a pretty large loss of clear and artwork but it's all under the plastics at the moment. Gonna send stern an email about it and have sent Cliff an email looking to get the protector for that spot but wow. There is no sign of pooling anywhere on the playfield. It was perfect but for this
That’s similar to what happens on the Deadpool Katana ramp. You might be able to use the cliffy designed for that application.
For those that haven’t had extensive damage yet, a small washer will prevent the ramp edge from digging. Here is my Deadpool Katana ramp after washer addition:
Yep, pretty common spot for that going back to the early days of this thread. It’s not related to pooling. It’s caused by the bottom of the ball guide scraping the playfield. Need to lift the edge of that ball guide so it doesn’t scrape.
Cliffy already has a protector for the antman rail. http://passionforpinball.com/WIP/Pym-guide-yesh.jpg
I added cliffy's antman rail protector and did the washer plus rubber washer on the hawkeye loop.
I've emailed Cliff but I have not heard back. I've been watching that rail as I did read about it early on in the thread. Seems to have come out of nowhere as there was no sign an issue was about to occur.
Just got the email from Stern for the new code v1.03.0. Anyone know what’s in it? Any new gameplay features?
Quoted from ScoobaDoo:Just got the email from Stern for the new code v1.03.0. Anyone know what’s in it? Any new gameplay features?
The couple of games I'lve looked up the new codes for, including this one, seems to be just for Insider Connected for when they end up fulfilling those kits to retrofit the games.
Quoted from Sleal16:The couple of games I'lve looked up the new codes for, including this one, seems to be just for Insider Connected for when they end up fulfilling those kits to retrofit the games.
Are those orderable yet?
Quoted from JRBBRJ:Are those orderable yet?
Some distributors started selling pre-orders. Got mine from Flip N Out
https://www.flipnoutpinball.com/product-page/stern-insider-connected-retrofit-kit-for-prem-le-models
https://www.flipnoutpinball.com/product-page/stern-insider-connected-retrofit-kit-for-pro-models
I wish they would add co-op.
But i won't get my hopes up
Quoted from potgar96:Does anyone know where I can download code for AIQ Premium V1.02.0 Dated: 04/13/21 Thanks
02 had super minor fixes for Battle Royale, but this should work:
https://f002.backblazeb2.com/file/gamecode/avengers_infinity_le-1_02_0.spk
filename says LE, but its the same code for both Prem/LE. Thats from the fileserver stern uses for their downloads.
Quoted from awesome1:It's most likely the piece that joins the coil plunger to the mechanism... I don't think any of the studs actually go through the cutouts in the plate for whatever reason.
It was the second stud tooth:
I tapped it back in and put a glob of JBWeld on each of those spot welds. They seem like they could be fragile as this happened in less than 200 plays.
Thanks for the help figuring out where to look.
Quoted from Magicmike0:Anybody have a problem with the ball bouncing to the left when it comes down from black panther? Mine started doing that all the sudden. It used to roll straight down to the right flipper but now it bounces toward the middle of the playfield when it rolls back down. Frustrating. I can’t tell yet if it’s somehow hitting the rubber rings all the sudden? I felt the guide and it doesn’t feel loose. Anybody else getting this? I did see it during gameplay for avengers guide for dummies that Allen did, but not sure what was going on with it.
I had the same issue but I replaced that rubber ring with a thinner one and now no issues.
Quoted from Damonator:It was the second stud tooth:
Interesting, haven't seen anyone else have one of those break. Hope the JB weld gets you playing until you can get a replacement!
Quoted from awesome1:Interesting, haven't seen anyone else have one of those break. Hope the JB weld gets you playing until you can get a replacement!
I’ve got a replacement ordered but I’ll probably never have to use it - JBWeld is amazing stuff. I put it back in the game and ran the subway test several times and it works like a charm.
It’s not super easy to see the balls in the subway though - I saw the mirror idea, but has anyone tried some dim illumination in there?
Quoted from Damonator:I’ve got a replacement ordered but I’ll probably never have to use it - JBWeld is amazing stuff. I put it back in the game and ran the subway test several times and it works like a charm.
Great! I've had some good success with JBWeld in some cases as well.
Not sure if it's along the lines of what you are looking for, but I did add a second set of (3) RGB lights in the subway. Drilled holes and mounted a LED below each original and then piggy backed the wiring. I like it, it definitely added a lot more color and brightness.
It's hard to get a good pic of it, but this is a still from one of my gameplay videos.
IMG_9560 (resized).JPGIMG_9562 (resized).JPGScreenshot 2021-11-24 234730 (resized).jpgQuoted from awesome1:Great! I've had some good success with JBWeld in some cases as well.
Yes! That’s exactly what I meant. That looks great and super clean installation too - nicely done! Next time I have it off I’ll do something similar. Thank you for the pics!
Quoted from Lermods:Go into switch test mode and see if anything is active that shouldn’t. Is the game randomly awarding any points? This would indicate a flaky switch that needs adjustment. Also check your connectors to the trough board underneath the playfield. Unplug and plug them back in.
Was a connector! Gotta remember that simple troubleshooting step too. Thanks.
Quoted from Munsters:Some mods are to bright, is there some kind of colormarker for this?[quoted image]
That's a lot of mods!
Try some resistors inline with the LED wiring. Comet offers a "dimmer" which is essentially a variable resistor for their Matrix add on LEDs you could add inline (series) with each mod and adjust to your liking.
https://www.cometpinball.com/products/brightness-adjusters?variant=12493660618796
Hey guys. Newb here. Help please. My lock down bar button to launch ball doesn't work at the beginning of the game. But if a guy has the mind gem or such and uses the action button, it works.
It also seems my secret skill shots are unable to be accomplished, - back door, avengers tower, middle pop up.
I went under the maintenence menu and made sure skills shots were on and they are.
Anyone have any similar issues? Thank you for any guidance.
Quoted from awesome1:That's a lot of mods!
Great tip, thanks! And yes, put almost all available mods in it
Quoted from LS98:Hey guys. Newb here. Help please. My lock down bar button to launch ball doesn't work at the beginning of the game. But if a guy has the mind gem or such and uses the action button, it works.
It sounds like you have a switch either stuck or oversensitive that is triggering when the ball kicks out of the trough to the shooter lane. That would cancel your skill shot and also stop the button from launching the ball. The other possibility would be the shooter lane switch itself not working. Then the game wouldn't know the ball is there and therefore not launch from the button and not have the skill shots active. Go to your switch test in the menu and see if anything is triggered that shouldn't be. If not, smack your playfield a few times with your hand and see if anything triggers just from that vibration. Then adjust whatever isn't working right.
Such a long game to just miss my high score by 46 Million... 6.3 Billion!
Beat Thanos with all 6 Gems. Got past second Black Order Multiball. Trophy Mania Wizard mode.
Second game over 6 Billion and sixth over 4 Billion! 3 Balls, factory settings, Extra Balls on.
Quoted from awesome1:Such a long game to just miss my high score by 46 Million... 6.3 Billion!
These really are some insane, next level scores - my highest is 850 million, and I had to have a lie down and a breather after that.
Are you human?
Next time, try it with the glass on, it's more difficult that way.!
I really like your gameplays ... I just want you to record one vertically so that you can see it on YouTube in full screen. what a great game !!!!
Quoted from mannymasy:I really like your gameplays ... I just want you to record one vertically so that you can see it on YouTube in full screen. what a great game !!!!
Thank you!
You should be able to make the video go full screen vertically top to bottom. Completely full screen on a phone or tablet, but will have sidebars on a PC widescreen. Not sure if YouTube itself will allow rotation when viewing?
Quoted from awesome1:Thank you!
it can be rotated but not full screen.
Screenshot_20211201-233137_Chrome (resized).jpgWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/official-avengers-infinity-quest-owners-thread-pinsiders-assemble/page/178 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
