Quoted from flynnibus:can you elaborate on that a bit more? I noticed ours was registering 1200+ where our pro used to top out at like 600ish. I thought maybe it was a premium vs pro difference, but your description fits. Can you elaborate on what you saw?
So in this photo, the bearing popped off and caused the rod to go from slightly to badly slanted. When the rod would slant, the bottom tip would not be centered and perpendicular to the sensor. The sensor would rely on that precision to count correctly. If the magnetic poles end up being funky, it picks up triggers when it shouldnt. At its worst, the whole table would be at rest with the ball cradled, and the disc would be adding to the score and filling up the STRANGE letters.
The other photo was before I adjusted it last month, so the pole is pretty far from the sensor, but shows how its supposed to be centered. Whenever I get under it again I'll check with the calipers and probably close the current gap a little anyway...probably get an extra "oomph" in speed if the current setup is farther than it should.
I think that with the Pros, since it doesnt have that extra mechanism to lift it, they're more commonly configured the same without it falling out of place.
