(Topic ID: 277423)
Official Avengers Infinity Quest owners thread. "Pinsiders Assemble!"
By Scribbles
1 year ago
  • 8,893 posts
  • 680 Pinsiders participating
  • Latest reply 19 hours ago by Jediturtle
  • Topic is favorited by 299 Pinsiders
Topic poll
“Of the Avengers featured on the inserts, who is your favorite?”
  • Hulk 102 votes
    20%
  • Iron Man 94 votes
    18%
  • Captain America 62 votes
    12%
  • Black Widow 38 votes
    7%
  • Thor 61 votes
    12%
  • Black Panther 26 votes
    5%
  • None of those weakling, THANOS! 135 votes
    26%
(518 votes)
19 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 8,893 posts in this topic. You are on page 14 of 178.
#651 1 year ago
Quoted from Apollyon:
Thanks so much for doing these streams Jack!
Yup, thanks for the streams Jack. Just wondering why you weren't going for portal locks before gem quests to turn them into multiballs? Maybe that's just another layer of the game you haven't gotten too far into yet? I didn't watch the whole stream this time, but watched the others and have been wondering about this. Thanks!
#652 1 year ago
Quoted from Scribbles:
Fingers crossed its an isolated event. Spot welds are occasionally bad. Sorry it happened to you.
This is the 3rd instance I’ve heard about. My LE is due to be delivered sometime between today and Tuesday. I’m going to go ahead and see if there’s any preventative fixes that can be done before flipping one game.
#653 1 year ago
Quoted from MUGEN_4_LIFE:
Also is it possible to turn the physical ball lock off and just play with virtual locks in the time being?
I hope there's an option or this. Seems like the kinda thing that is usually in there.
#654 1 year ago
Quoted from Lounge:
Looks awesome (paint the teeth)!
You going to tackle the gauntlet next?
Thanks! Probably going to stick to Thanos. I kind of like the gauntlet that’s in there. Looks exactly like the comics.
You think the teeth should be light grey? Or white?
#655 1 year ago
For anyone that played this, is that top left looping ramp shot not disrupted by the strange spinner often? I watched Jack playing it and it seems it kept getting in the way?
#656 1 year ago
Quoted from Potatoloco:
3rd here on pinside? I agree, it would be nice to have a preventative fix.
#657 1 year ago
Thankyou for sharing this with us all, what a bummer to have that happen after just setting the game up and playing just a few games on it... but I'm sure they will jump to the send you a full assembly asap. Did the spot weld fail causing the pin to drop? Is it something a local welder could fix for you? Not every shop has a spot welder but tig may be a possibility?
Can't wait to get my premium!
Please keep us posted on the progression with your distro or stern directly. Thanks man! Also is it possible to turn the physical ball lock off and just play with virtual locks in the time being?
Yes , the spot weld failed causing pin to drop. I was thinking same thing about getting it spot welded locally. I dont know anybody who does that here.
I am going to check today to disable portal lock/raising disc. So we can play until part gets here
#658 1 year ago
Quoted from Motorcitypinball:
Did Stern indicate if they would be sending a complete mech or just the pin?
#659 1 year ago
Also that Epoxy floor treatment is AWESOME! IM going to finish off my basement next year if all goes well and was about to price out some laminate flooring, whats the cost on this route VS buying the flooring and labor on install? Any idea?
Ours is a Metallic Epoxy and cost $5 per sq foot installed
#660 1 year ago
Everything else works good. Spot welds can go bad, and mine did. Nothing your going to do to prevent that!
#661 1 year ago
No, first I’ve seen on pinside. The issue seems to be fairly isolated at this point, but still something for everyone to be aware of just in case.
#662 1 year ago
We are waiting on the answer. It just happened last night.
My Distro thinks it would be whole assembly. I will keep you posted
#663 1 year ago
Kind of surprised to see a coil used in that mech. I would think that a motor and a cam would be a lot less shock and vibe on the mech, especially that spot welded actuator pin.
Anyway, I’m wondering if we need to be a bit careful when setting up the game, with each game being a slightly different pitch, the speed at which the balls can traverse each position of the portal lock will be slightly different. I hope there is a setting where the time between locks can be adjusted. If it’s really far off and a ball is not in the right position I could see the gate arm come up and hit the ball causing additional stress on the mech.
#664 1 year ago
Which shot collects the Extra Ball?
#665 1 year ago
Anyone with an LE put yellow t-moulding in yet?
#666 1 year ago
Quoted from J85M:
I've got the T moulding in hand, along with Titan rubber, but no dang machine. T moulding will go on first thing.
#667 1 year ago
Also keep in mind, when using a phone app for leveling purposes, when you lay your phone on the playfield. If your phone is even the slightest bit rotated clockwise or counter, your bubble app will be off. I do use the app, but it's not perfect. Still plenty of room for human error.
I need to figure out this app to fine tune my pins as outside of a regular level on the glass to make sure that bubble is in the center for left right and also the bubble on the pin itself being between the two lines I'm not real swift with this Pinguy app. One problem I have when laying my phone on the glass without any cover on it is it slides down the playfield on me. Do you guys leave a case on the phone or what works best? Are there step by steps or a video somewhere of how to do this best? Also does a digital level give you pitch as well as centering left to right? Sorry for a bunch of questions just thought I'd try to get this right for my Premium once it arrives.
#668 1 year ago
Take the glass off. Calibrate the app with the case on your phone. Leave the case on and place the phone on the playfield in the middle. The app will talk to you and tell you how to level the game.
#669 1 year ago
Quoted from TKDalumni:
There is a target behind the spinning disc, just to the right of the Avenger tower. sanctum target.
#670 1 year ago
Quoted from Deyanks98:
Never measure anything on the glass. Measure directly on the playfield. I do not use the phone app levels, but if you calibrate with the case on, you would leave the case on. A real digital level will measure both. Place it side-to-side to measure level, flip it to front-to-back to measure pitch. Measure at multiple places around your playfield. Nearly all playfields have minor warp, slightly raised inserts, etc that will lead to different measurements at different spots. I usually measure as far up the pf as I can, near the middle, and right above the flippers then use a rough average between them.
10
#671 1 year ago
Wellp the streams got to me...Put a deposit down on a premium. I have a Turtles pro coming, so that will certainly hold my attention until I get Avengers (next year, it seems?)!
#672 1 year ago
My personal experience with the pinguy app is that it is an inconsistent waste of time (no offense if the creator is present on these threads). Do yourself a favor and pick this up if you want real, repeatable, and accurate results:
amazon.com link »
#673 1 year ago
Quoted from mcvetyty:
amazon.com link »
Thanks I had one in my cart after I read a few of the replies so I'll give one of these a shot. Appreciate the feedback.
17
#674 1 year ago
They are sending complete mech which is GOOD!
#675 1 year ago
Sounds like LE’s will be arriving in Canada sometime next week! Can’t wait to get mine!
#676 1 year ago
Then, you can repair the old one and have a spare on hand
#677 1 year ago
Stern usually requires to send def mechs back
#678 1 year ago
Adding my best wishes to those who are having problems and hoping they get resolved quickly.
As soon as anyone has a "best practices for coils setting" etc we would love to see them.
My premium is on order and tempted to turn on nothing until ensuring I can minimize any damage from my end.
Thanks everyone.
#679 1 year ago
Final payment made with confirmation it should reach my distributor next week and then hop on a truck to me. Let's go! I get more and more excited with every stream I watch.
17
#680 1 year ago
LE #75 has arrived safely! Unboxing stream coming up. Just gotta move a couple pins first.
#681 1 year ago
Quoted from Joe-Ker:
Ok see that, but pretty big miss to not have an indicator that it is the EB target...
#682 1 year ago
May not be obvious from top down shots (hell may not be obvious in person, I haven't played it yet) but the sanctum target does have indicators on it.
#683 1 year ago
Extra ball is indicated on the plastic above isn’t it? Sure I’ve seen it in and old promo shot.
Edit: as proven above by timmmmyboy
#684 1 year ago
Where else was this brought up? Was it all the same single weld? Doesn't seem like this would be a big issue. Although spot welds do sometimes have issues with fully penetrating the surfaces.
#685 1 year ago
Quoted from Indusguys:
Already one listed in Ontario for $22,500 cdn (about 17k usd)
Seller deserves Covid.
#686 1 year ago
KnockerPTSD, I don’t think P1 have received their shipment of Avengers LE yet.
I’m also in for an LE and haven’t yet received an update.
It’s likely that one you saw listed for $22.5k on Kijiji (in Barrie) was a flipper who hasn’t yet received his game. It’s brutal regardless.
#687 1 year ago
My LE in not being flipped either. Canadian Avengers assemble!
#688 1 year ago
Quoted from KnockerPTSD:
Good luck selling that one. Theres one here on pinside currently listed at 12k and it's been available for days without selling.
#689 1 year ago
For the record, this is the view from the player’s perspective. I actually can’t even see add-a-ball, let alone Extra Ball...
#690 1 year ago
Looks like pinballs.com still has some LEs.
#691 1 year ago
Not the first time..
#692 1 year ago
Yeah that needs a small sculp or something.
Love the custom Thanos
Mine is still a couple days out
#693 1 year ago
People contacting me directly. I’m sure they’ll be taken care of or probably have already taken care of it. I don’t think it’ll be a big deal and is probably very isolated (3 out of 500) so far. I think this is more of a “take a look before playing” situation than a “expect something wrong” issue.
I tend to really go over all the mechs when I first get a pin and make sure everything is tightened up. I learned my lesson with Maiden LE when the center ramp came apart during game 1 lol.
#694 1 year ago
I was thinking that. they asked for the old one back so they can inspect quality
23
#695 1 year ago
My LE has arrived. Wow what fun. Really enjoy how accessible the shots are and there is somewhat of a sense of acheivability for someone like me (NOT a pinball pro).
20201002_135528 (resized).jpg20201002_135532 (resized).jpg20201002_143532 (resized).jpg20201002_145852 (resized).jpg20201002_151130 (resized).jpg
#696 1 year ago
Quoted from AJB4:
[quoted image][quoted image][quoted image][quoted image][quoted image]
Guys, you’re killing me. How does the right ramp shoot?edit That’s the Captain Marvel Inverse gravity ramp. Is it really satisfying? A lot of rejects or smooth?
This is why I went with the premium. Hopefully all the little hiccups get fixed by then. TWD LE had a bunch of little problems that were fixed by the time my premium was built.
#697 1 year ago
Quoted from AJB4:
Awesome! That's great news for me (also not a pro player to say the least). And theres that close up high res sparkle pic I was after! Looks like a base standard yellow with gold glitter on top almost. I like it !
#698 1 year ago
I feel a lot of rejects. I have to get a little more play time though to dial it in and then I will know for sure!
14
#699 1 year ago
LE showing up Tuesday
Will give full review!
12
#700 1 year ago
If anyone's interested, here is my unboxing VOD. It includes close-up of armor (just for Scribbles ) and playfield. Gonna get it levelled and play for the first time on stream tonight. (www.twitch.tv/pridepinball @ 9pm cdt)
https://www.twitch.tv/videos/758769844
Thanks for hanging out!
