Is it possible to have 3 balls locked in the portal and starting a gem quest with a 4th ball?
It seems that I can only get 2 portal locks on out Premium.
When "earning" a 3th, it seems like I only get that one after playing a gem quest.
Quoted from Pinballnewb01:Is it possible to have 3 balls locked in the portal and starting a gem quest with a 4th ball?
No, two portal locks per quest only, for a 3 ball multi max (unless you stack on IM or Thor).
Quoted from jandrea95:Having issues with my new topper. Didn’t come with instructions. [quoted image]
Congrats and good luck!!! ( they don't really have a rulesheet or schematic)
Welcome to your pinball skills tanking !
Congratulations! Not a very deep game though. Really only two modes: 1) I'm tired, and 2) I'm hungry
Wizard mode is you trying to get enough rest to semi-function.
Quoted from xyntec:Switched my LE on today and this showed up, grabbed my phone and took a picture, put my phone away and wanted to shut the game off, then it restarted and after that no more error, doesn't look too promising....
If you have added any lighted mods, especially if they connect with aligator clips, check them first to make sure they aren't shorting on something.
Quoted from awesome1:If you have added any lighted mods, especially if they connect with aligator clips, check them first to make sure they aren't shorting on something.
Nope, I haven't put in any extra stuff...
Quoted from xyntec:Nope, I haven't put in any extra stuff...
Go into the service menus and look up the node board test and run that. It should tell you what is causing the over current. Then go to that area and check it. It will be very specific. See this thread below for more help.
Ok, not sure if this is a silly question or not but what do the numbers on some of the gems mean? I’ve seen zeros, ones and twos. Can’t recall which gems. Any insight helpful!
Quoted from ApplePie:Ok, not sure if this is a silly question or not but what do the numbers on some of the gems mean? I’ve seen zeros, ones and twos. Can’t recall which gems. Any insight helpful!
Its how many times you can activate/use them
Quoted from TheLaw:Its how many times you can activate/use them
And then recharge them back up to their max with a bunch of hits to the shot with the gem? I haven’t been able to keep track of this during a game very well apparently...
Quoted from ApplePie:And then recharge them back up to their max with a bunch of hits to the shot with the gem? I haven’t been able to keep track of this during a game very well apparently...
Change gem or space gem to move or replace them to recharge.
Quoted from Thomas3184:Change gem or space gem to move or replace them to recharge.
Leveling up the Avenger they are on also works, and usually "upgrades" the power of the gem as well. So ApplePie is kind of right there too.
For anyone having issues with rejections on their CM ramp, try taking the ramp out slightly, and then re-centering it.
I did this, and saw huge improvements.
Seems mine was ever so slightly off to one side, and the tiny change made a big difference.
I now feel like the shot is fair. Not every shot makes it, but a nice fast, clean shot will.
Hope this helps.
Quoted from WizardsCastle:For anyone having issues with rejections on their CM ramp, try taking the ramp out slightly, and then re-centering it.
Hope this helps.
Great thanks, I'll give her a go
Quoted from chuckwurt:What about the tdiddy mod for the ramp? I thought that solved the rejects?
Classy product, but didn't fix mine.
Quoted from TheLaw:Classy product, but didn't fix mine.
Well dammit. I assumed that was a fix for all. Haha
Quoted from chuckwurt:Well dammit. I assumed that was a fix for all. Haha
It doesn't magically turn it into a gimme shot. It's a hard shot that needs to be strong and precise, like the good old days, LOL. It definitely isn't a Steve Ritchie ramp where any sloppy shot near the opening will find it's way up. This mod (either the fancy one being sold, or the DIY chunk of plastic), will help a slightly sloppier shot stay aligned, and will keep a very stray ball from flying out the side, but that's about it. This isn't a slam on the product...there is only so much that can be done, and it helps as much as possible. If your ramp is tweaked or bent funny, like some seem to be, that will still need to be addressed.
Quoted from Jediturtle:It doesn't magically turn it into a gimme shot. It's a hard shot that needs to be strong and precise, like the good old days, LOL. It definitely isn't a Steve Ritchie ramp where any sloppy shot near the opening will find it's way up. This mod (either the fancy one being sold, or the DIY chunk of plastic), will help a slightly sloppier shot stay aligned, and will keep a very stray ball from flying out the side, but that's about it. This isn't a slam on the product...there is only so much that can be done, and it helps as much as possible. If your ramp is tweaked or bent funny, like some seem to be, that will still need to be addressed.
Agree 100% and I was one of the very early adopters of the Lexan DIY version. Helps quite a bit, but the shot is not a "gimme"... there's a reason such a steep ramp has never been done before... it's a hard shot most of the time, but very satisfying!
Quoted from Jediturtle:It definitely isn't a Steve Ritchie ramp where any sloppy shot near the opening will find it's way up.
This pretty much guarantees me getting a pro unfortunately. I’ve had enough of dialing in a ramp shot for 10 lifetimes. Haha
Who else really enjoys the AIQ Battle Royale Challenge Mini Game?
Every once in a while I still fail to complete it, but I have also whooped up on the Black Order a few times and put up some big scores and/or fast completion times! My best score and fastest time were done on different games.
IMG_E0396 (resized).JPGQuoted from chuckwurt:This pretty much guarantees me getting a pro unfortunately. I’ve had enough of dialing in a ramp shot for 10 lifetimes. Haha
If you have a chance to play a machine with the loop Captain Marvel ramp maybe try it out before deciding, but if you're main concern in the decision is reliability of that ramp and whether or not you'll have to tinker with it then I'd say go for it. I still smile every time I hit that shot because I think it's such a fun and unique shot. Mine hasn't taken any dialing in. Some people have had issues with it but I'd guess there are also many who haven't or who have only had to make small tweaks. And any issues seem to be mainly alignment related. There isn't a mech that you're trying to get to work along with it (*cough*TK Lock*cough). If I had to bet on it I'd say someone getting it shouldn't have much trouble with it though.
Quoted from EaglePin:If you have a chance to play a machine with the loop Captain Marvel ramp maybe try it out before deciding,
My time on the game is pretty much exclusively a premium. Sounds like the ramp won’t be able to get to a point where I won’t be disappointed with it. Definitely disappointed with it as it is right now. Maybe a mod and a couple tweaks will change my mind. We shall see.
Quoted from chuckwurt:My time on the game is pretty much exclusively a premium. Sounds like the ramp won’t be able to get to a point where I won’t be disappointed with it. Definitely disappointed with it as it is right now. Maybe a mod and a couple tweaks will change my mind. We shall see.
The plastic helps a great deal and it takes 5 mins to make one,as long as the it’s a clean shot it will zoom
Quoted from chuckwurt:But man, when that ball zips around that ramp it is so cool.
IMO the ramp is not an issue for most games - it’s just a shot that has to be accurate.
My son is just an average player, and he has always complained about that shot rejecting yet I’ve never had an issue with it.
The fix just means the shot can it be slightly less accurate since if it hits the side it won’t rattle as much and reject.
It’s nothing like the ST Demi if that’s what you’re referring to.
To be clear. The premium I've been playing rejects a lot. It has a factory plastic cover on the outside of it. I’m going to try the mod and maybe one other thing. But if I can’t figure this one out really easily, I’ll probably go pro when I get one.
The STH demo is child’s play compared to the TK lock.
If I hit a shot clean, it should go. This one isn’t always going if the shot is clean.
Quoted from chuckwurt:To be clear. The premium I've been playing rejects a lot. It has a factory plastic cover on the outside of it. I’m going to try the mod and maybe one other thing. But if I can’t figure this one out really easily, I’ll probably go pro when I get one.
If it helps, my machine rejected less than 10% of CLEAN shots right out of the box. Adding the DIY mod cut from an old plastic protector put that at 5%, maybe less. Almost every time mine rejects, I know it was my own fault.
I'm sure the pro is still a damn fine machine, but the premium upgrades on this one are HUGE, and having lived with them awhile, I really can't imagine not having them. It isn't eye-candy like Stranger Things...these are real game changers for the better.
Yeah. I like the added features too. It’s also nice that the rubber on the right ball guide kicks to the left flipper so you don’t have bump it off the rail every time.
Even IF the ramp has issues I'd still go premium, and I've been Pro my whole life.
But it can be fucking frustrating. I had no battles left and had to keep hitting Dr Strange to spot me an Avenger instead trusting that ramp
Yeah this game has way to much going on that I’d be so pissed that a ramp reject killed me. Haha. This game is good in that there aren’t any cheap drains at all. Even if that ramp rejects. But for now I’m completely avoiding that ramp. Hopefully we can make it a lot better.
I love the CM ramp on my Premium. On mine a clean shot will loop nicely, but I feel your pain if you hit it clean and it don't loop. Its a shot that still don't get old shooting.
Quoted from chuckwurt:Yeah this game has way to much going on that I’d be so pissed that a ramp reject killed me. Haha. This game is good in that there aren’t any cheap drains at all. Even if that ramp rejects. But for now I’m completely avoiding that ramp. Hopefully we can make it a lot better.
The Captain Marvel ramp is awesome! Such a fun shot it's a shame you are avoiding it. The Lexan or aftermarket fix just make the shot smoother with no more falling through the back and also getting a fair amount of rejects. The design of the ramp will still result in rejects if the shot isn't strong enough... the ball is going straight up!
Sounds like the premium you play could use the ramp fix to improve the play. May not be possible to add the fix if it's a location game. The images/video of the Pre/LE on Stern's site show a different wireform design for the Captain Marvel ramp. It's this change on production models with the one wire stopping well short of the ramp that creates a hole and causes many rejects or the ball to actually fall through and the fix closes the hole.
Now the cheap drains actually can be an issue... the outlanes are known to be very hungry on any AIQ model. The positioning of the outlane post lower than the sling post can create an easy drain.
I haven't had an opportunity to play the Pro model yet, so I can't directly comment on it.
Quoted from awesome1:The Captain Marvel ramp is awesome! Such a fun shot it's a shame you are avoiding it. The Lexan or aftermarket fix just make the shot smoother with no more falling through the back and also getting a fair amount of rejects. The design of the ramp will still result in rejects if the shot isn't strong enough... the ball is going straight up!
I've got a Premium - early on someone said to keep the playfield clean and waxed. It really is a big deal. Even that simply step alone leads to many more clean CM ramp shots...
Quoted from awesome1:Now the cheap drains actually can be an issue... the outlanes are known to be very hungry on any AIQ model.
Not the case on the one I play at all. The design around the outlanes are very friendly for nudging. And rarely do misses drain you if you’re on it.
My cm ramp has zero rejects if the shot is accurate. Only when the shot is slightly off does it rattle and reject.
Quoted from chuckwurt:Not the case on the one I play at all. The design around the outlanes are very friendly for nudging. And rarely do misses drain you if you’re on it.
that’s how i would describe mine too. it’s very fair at the outlanes and after misses.
I bought the mod, but didn't end up installing it because I was happy with the way it played after I removed and reinstalled the ramp.
The awesome EaglePin helped me with some photos of his, since he wasn't complaining about his, and I was definitely not happy with mine.
I went from hating the game and thinking about selling it, to finishing the whole game and saying it might end up being bolted to the floor!
The ramp is a very important part of the game, and when rejects go SDTM as was the case with my game, it quickly sucks the fun out of it.
Fix the ramp, new game!
What exactly did you adjust when reinstalling the ramp? Did you make sure certain aspects were aligned a certain way?
I know you said recenter it, but can you be more specific?
the code in my opinion is better in the premium, the combos are more fun, better flow... you really have to play to see it... this game is a premium game in my opinion.
Quoted from chuckwurt:What exactly did you adjust when reinstalling the ramp? Did you make sure certain aspects were aligned a certain way?
I recently took all my ramps out to install mylar under the flaps. I did not notice anything weird on this ramp, so unless his was not bolted down properly there is not much to 'adjust' the ramp is held down to the PF with 2 or 3 bolts/nuts under the pf and there are also 2 screws that held the ball guides for Thor.
Quoted from Pin_Fandango:the code in my opinion is better in the premium, the combos are more fun, better flow... you really have to play to see it... this game is a premium game in my opinion.
Pretty sure the code is the same on both games, but I could be wrong.
This page was printed from https://pinside.com/pinball/forum/topic/official-avengers-infinity-quest-owners-thread-pinsiders-assemble/page/126 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
