On my TriZone with a rottendog MPU, im having an issue where all the switches on a single lead (green wire, yellow tracer, all the left side playfield switches)
When any of the switches in that column, it also "hits" every switch in the respective row.
IE.. outlane switch when activated also activates the coin drop switch, spinner scores and resets game. inlane switch also causes the drop targets to reset. the Z drop activates the other coin drop. the sling score switch also activates the tilt.
Did further checking, getting continuity to ground through the green/yellow wire. pulled the connector at the board, to check wire end to pf. nothing. check for ground at terminal, bingo.
Anyone have a schematic for a Rottendog MPU 326 board?
