Bought a replacement beacon assembly, installed it, activated multi-ball and nothing. Go into adjustments menu to make sure beacon setting is on and while scrolling thru the menu the beacon starts working without making any adjustments. At first I thought "cool, it works!". But it wouldn't turn off. I turned the pin off and back on, played a game and it just keeps going (when power is on).
I go back into the menu and turn the "police light" setting OFF and it continues running.
Now I'm used to things NOT working, but here I have something that wont STOP working. Is this similar to a stuck-on coil? It's odd that it still runs after turning the setting off. Should I start with checking the transistor or is this a cpu problem? This light connects directly to the power supply (which is new) and the cpu.
Don't know if it matters but the old beacon was smashed off by a punk with a hockey stick on location, possible short?
