I've noticed on completion of a game the match number regularly ends with a one rather than a zero.
This does not stop the match from working though for example if my score ends with '90' and the match displays '91' it still pays a credit.
Now my original VFD score display showed this issue and I didn't bother much with it as I was planning on replacing the display.
I have now installed the RetroElectro Colour Classic displays and the problem still happens.
So I can rule out it being a display issue as the problem stayed when I swapped to a different VFD and when I installed my new displays.
I don't see how it could be a problem with the pins in the connector on the MPU else it would impact all displays not just the credit and match display.
It also can't be the D0 to D3 or blanking pin on the display plug else it would cause issues with the other digits on the credit display, likewise I don't think it can be the digit display pins.
Also when you first turn on the machine before a game is played it displays a zero in the ball count and some of the time it displays the match correctly with a zero in the right digit.
All I can think is there is something odd happening within the MPU, but I'm at a loss as to what that could be.
Does anyone else have an idea?
Below are a few photos showing '91' in the match when I had the VFDs installed, then a '31' on the match with my new display and it working correctly showing a '40' in the match.
Has anyone ever seen this before?
20230523_184656 (resized).jpg20230523_185002 (resized).jpgmatch 91 (resized).jpg
