edit: I'm trying to undo this hack, but the molex/harness headed into J114 and the Z connector have been cut in such a way I'm not sure what is supposed to go where. The manual supposedly has errors. Does anyone have a picture of what the cable connector should look like?
Thanks!!
Hi All,
I picked up a nice Roadshow from a super nice seller locally. When we were going over the machine, I found something that I didn't expect to see, and I was puzzled for a little while there.
The short version is that someone added a "Happ Power Pro" power supply to the cabinet and spliced it into the power box molex for power and ran its +5v lines directly into the CPU/WPC-89/Fliptronics board interconnect (using wire nuts). I played a few games on it while I was there and it did work just fine. I haven't powered it on since I brought it home because I just feel funny about it.
In my usual "once over" I found lots of over-fused fuses (5A where 3A should be). The most insane was the 3/4A SB fuse for the switch matrix which had an 8A fuse in it (!!). The area around that fuse almost looks scorched, too...
Anyway, I have oodles of questions about this hack that I haven't seen anywhere else before. Pictures are attached for the curious.
1. has anyone seen this before? I'm guessing this was done because the +5V leaving the driver board was bad, but... is this as rare of a hack as I think it is?
2. Is it safe? The power pro's 5v 15amp connection is connected to the driver board, and those lines run like 3 or 5amps if I'm not mistaken... perhaps the over-fusing was intentional?
3. If I were to undo this (which I'm eager to do, and really have to before I ever try to sell this thing), I have a currently untested WPC-89 -1 (populated flipper relay) to drop in, what should I do to make sure that replacement board is good, and how likely am I to kill that board with this machine
2013-01-27T15-42-55_39.jpg 2013-01-27T15-42-55_23.jpg 2013-01-27T15-42-55_29.jpg
