(Topic ID: 231311)
Occasionally 3 balls in the shooter lane on WoZ
By otakudre5
5 years ago
#1 5 years ago
I have a problem that occurres in seemingly certain situations from what I can tell so far.
When I get into fireball frenzy there are three balls being shot into the shooter lane. The ball still in play registers as normal. Once one of the additional balls is lost, the end of ball bonus count sets in. Mostly this happens, when I’m on ball two of a standard three ball adjusted game.
When I run through the switches and functions in test mode, everything works and no errors are shown, so I was wondering, whether this is a rare bug of the most recent software, which I am running.
Any ideas? Did any of you run into something similar?
#2 5 years ago
Quoted from otakudre5:
I get Fireball frenzy almost every time I play but I've never had the issue you mention. Sorry I can't be of more help than that.
#3 5 years ago
Shooter lane switch sticking going up or down ?
Ball jam opto flaky ?
#4 5 years ago
Thanks for the quick answers.
@LTG: I checked both. They are working fine, the opto is not flaky.
I checked all the switches once more, there doesn’t seem to be a problem with them. At least in test mode.
#5 5 years ago
One more thing, I recognized: when the balls are being fed to the shooter lane, there is no auto-launch, that puts them into play. The mistake only happens, when there are three balls in the magazine left and the two others are either in play, or one is in play and one is locked.
#6 5 years ago
I wonder if you should try installing the previous software version (6.06), and see if it sorts your issue out, at least it will discard the software bug if not, then you can go back to 6.61.
#7 5 years ago
Today I finally had some time to change the code to 6.06. The problem is still there.
Somehow it seems to be connected to the monkey mech and only occurs, when a ball is locked there.
#8 5 years ago
Try installing the current code maybe?
#9 5 years ago
Had this problem with the current code also, as I wrote above.
When I get some time over the next couple of days, I will check on the opto boards once more. Somehow the balls seem to be miscounted.
1 month later
#10 5 years ago
Just wanted to update on the topic and the problem.
The problem is solved. It was an issue with the opto receiver board, where the resistor R2 had a problem and dropped out, which resulted in a malfunction of the optos 3 and 4.
Received new opto boards and switched the transmitter and receiver board, just to make sure.
All is back to normal now and I am a happy camper
#11 5 years ago
I just picked up another WOZ - beautiful, beautiful game, wow! I am also having the issue with 2 balls consistently (on every ball) being dropped into the shooter lane. The auto fire and shooter lane switch is working, as I tried to leave the second ball in the lane, but it is always launched a second later.
I am testing the trough optos and they seem to be ok - so I wonder if I could have an issue with the board? I Played the game at the sellers house and did not notice the issue there. Not sure what to test next?
I don’t see any connectors missing or offset.
#12 5 years ago
Quoted from Rdoyle1978:
Usually has to do with the shooter lane switch wire actuator not being vertical in the slot or too low, or rubbing on the wood.
Bend it up a little, put one or 2 balls on it in switch test.
Sometimes the ball will rest slightly away from the end of the shooter lane resulting in hit or miss performance. Adjust the switch in this case.
#13 5 years ago
Quoted from pinballinreno:
Thanks! Never would have thought of that
#14 5 years ago
So I re tested this, and I don’t think that is it. The optos seem like they are ok, but perhaps they are flaking out?
The second ball is sometimes not dispensed until I actually plunge the first ball. Then a second ball is immediately dispensed and then auto-fired. It is really weird!
11,300 (Firm)
Spokane Valley, WA
$ 16.95
$ 29.99
Hardware
Classic Game Rooms
$ 395.00
Pinball Mod Co.
10,500
Warner Robins, GA
$ 43.00
The MOD Couple
$ 40.00
Pinball Mod Co.
$ 45.00
Pinball Mod Co.
$ 24.50
$ 9,800.00
Pixels Arcade Games
$ 95.00
Pinball Mod Co.
$ 5.00
$ 259.99
9,300 (Firm)
Santa Maria, CA
$ 130.00
Pinball Photos LLC
$ 85.99
$ 345.00
Pinball Mod Co.
$ 91.00
$ 50.00
Duke Pinball
$ 40.00
The MOD Couple
13,000
St. Clair Shores, MI
This page was printed from https://pinside.com/pinball/forum/topic/occasionally-3-balls-in-the-shooter-lane-on-woz and we tried optimising it for printing. Some page elements may have been deliberately hidden.
