(Topic ID: 220170)
OBS & Logitech c920's
By Spyderturbo007
1 year ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by Spraynard
    #1 1 year ago
    Anyone using multiple c920's with OBS? I'm running into an issue where the OBS camera property interface isn't working on the cameras. It's almost like the software gets confused and won't turn off the Auto Focus, change the Gain, etc. I have to open the logitech software, adjust the settings and then go back into OBS.
    Anyone know of a fix for this?
    #2 1 year ago
    I recognize this too. Have several c920s and in OBS it’s always the same that’s adjusted. Luckily the playfield is a c930 but for the other 3 c920 I can only adjust one via OBS
    2 months later
    #3 1 year ago
    Solved my problem.
    Solution is, with windows 10 at least, to remove via the windows control panel all Logitech drivers and use only the native windows drivers.
    Now I control from OBS all 3 C920s without any issue.
    #4 1 year ago
    I forgot I posted this here and never updated the thread. I found that solution a little while back. Now I’m trying to figure out how to get the software to save the edits I make to each camera.
    It always sets things back at defaults.
    #5 1 year ago
    Right, the native drivers won’t store your settings which is super annoying. Also, I had a really hard time adjusting the resolution and other settings in obs. It would just turn the output black most of time.
    If you use the Logitech drivers, you can control multiple by exploiting the “chain of command” Jack danger talks about it in the tilt forums streaming thread. Garrett Hays also has a write up on tilt forums as well. It’s a pain in the ass, and involves unplugging the cameras in a specific order. But it works. I’ve ran 21 c920s at one time using this method.
    $ 74.00
    Id Rather Play Pinball
    $ 235.00
    RS Technologies
    $ 19.00
    Tilted Pinball
    $ 1,099.00
    $ 29.95
    Pinball Photos
    Apron Envy
    $ 60.00
    Whitewater pinball mods
    Metal-Mods
    $ 299.00
    Displays
    Boston Pinball Company
    Yorktown Parts and Equip
    £ 45.00
    PinballToys
    $ 150.00
    Professor Pinball
    $ 90.00
    Lighting - Under Cabinet
    $ 69.99
    $ 24.99
    Lee's Parts
    $ 3.00
    Doc's Pinball Shop
    $ 48.00
    $ 199.99
    Pin Monk
    $ 999.00
    $ 999.00
    $ 42.00
