Which size would be compatible with pinball bolts?
https://www.amazon.com/Pieces-Plastic-Spacer-Washer-Thickness/dp/B07CRBVDF3/ref=asc_df_B07CR5PMLM/
Quoted from Jjsmooth:They squish and tear apart way before u can tighten enough. Kinda dumb product.
The idea is to protect the leg's finish/paint from the leg bolts. I've used them a couple times, but haven't encountered the issue you're describing.
How tight are you cranking those bolts down? I put these on all my restored games and have never had an issue. I use a metal Stern style leg protector, felt pad, power coated leg, nylon washer followed by a new leg bolt. It looks nice and sharp when done correctly.
This page was printed from https://pinside.com/pinball/forum/topic/nylon-washers-for-leg-bolt-protection-size- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
