Interesting developments with using FM1608 and FM1808
I have found FM1608s on a 5101 dual CE dip adapter setup will not work properly in WMS system 3-4 games if you power cycle willy nilly. If you are writing to the RAM when you power down (say adding credits and turn the game off) the next time you power up the RAM will clear to default settings. FM16W08 on a surface mount adapter does not have this problem. I suspect the wide voltage rating has something to do with it. Perhaps reset timing and the fact the +5v that powers the RAM in system 4 stages through the reset delay.
As stated a few posts above. Early date code FM1608s do not work properly in system 6 either. Rapid power cycling will clear the ram. FM1608 with 0435 ish or later date code, this issue goes away.
In my latest batch of FM1608(8k x 8)s i also found a a couple FM1808(32k x 8)s mixed in. FM1808 is drop in replacement for 6264/FM1608. It works fine every system i have tested it in so far with no worries about changing jumpers. AND!!! FM1808 on the 5101 dual ce dip adapter does not corrupt the RAM in a system 3-4 game if you power cycle during a ram write event.
I also found some FM1608s labeled FM1608M. The dye revision on these is "A", FM1608s pretty much all have dye revision "M". So far these behave exactly like FM1608. Perhaps a military graded part???
That being said. I believe FM1808 may be an equal or possibly superior part number over FM1608. Just make sure it is NOT FM18L08 as that is a 3.3v part and will not work.
