Just for giggles I bought a few lots of these cheap DIP nvrams from Aliexpress and what I received, I'm not very impressed with. I do think caution in ordering this stuff is DEFINITELY needed. You'll probably get some working chips, but for sure what's being sold is mostly remarked/recycled scrap that doesn't seem like it's even being tested after the chips are "refurbished". Depending on pure luck you may have quite a few non-working chips in the lot. My interest was seeing what was being purchased by others & whether the lots came working & appeared genuine at all. These were sellers other people had ordered from in this thread.
RAMTRON DIP PARTS
The first lot of 30x chips -- 8x of them completely failed. I tried with the Neoloch, I tried using the GQ-4X.. I pressed down on the chips and re-positioned them in the ZIF several times. Even tried putting them in their own sockets. The legs looked fine. 2x chips also had legs that were so bent they were unusable. All chips were very obviously sanded/remarked as they all had the same lot/date codes and the print was crap.. very inconsistently heavy and light on a single chip. Some chips, the circle indents had been nearly completely sanded away.
Example of one of the worst with the inconsistent print/remark:
Example of indents being nearly sanded off on a few chips:
The 2nd lot of 32x chips was a bit better.. only a few failed. Same exact lot/date codes on the chips. Apparently I purchased from the same seller that was using 2 different usernames (probably more) to sell these chips.
I'm disputing both orders and found out the seller is the same business/person because I was asked to ship the lots back to the exact same name and address.
RAMTRON SMD PARTS
I also bought a lot of RAMTRON SMD parts earlier this year for use with testing some other assembly/build methods (easier to waste cheap chips than it is $7-8 genuine chips). Most of the lot was BAD right out of the package. Normally these chips come on tape-and-reel packaging, and instead they were shipped in soic ic tubes, vacuum sealed in an anti-static bag. If they weren't vacuum sealed I'd have gotten into testing them sooner, but I left them sit for a while and eventually got around to testing them. More than half of the chips failed testing when using a ZIF socket in the Neoloch. Luckily I got a refund on those even though I was out of the dispute period, only by telling the seller I would be leaving bad feedback if I did not receive a refund.
Everyone's opinion will differ here, but knowing that a number of these failed right out of the gate along with seeing they were remarked, I would not be trusting at all in using these in a product I was selling & I would hesitate putting them into anything I cared about even for personal use.
It's Not Just Expensive Chips..
Something else worth noting, some of the very cheap generic chips that you wouldn't think would be worth anyone's time to counterfeit or sell junk chips are also possibly suspect. I ordered some 74hc595 chips, 10x of 30x failed. I attempted to use them in something and they were causing issues because data was not shifting thru the bad ones correctly.. it was as if the output pins were mapped slightly wrong or one of the shifts wasn't happening. Swapping chips out from the same lot until I hit a working one did the trick.
They are even counterfeiting "rice" using resin: http://althealthworks.com/7761/plastic-rice-from-china-is-real-and-it-can-cause-serious-health-problemsyelena/ -- something that seems so incredibly cheap that it would never be target for counterfeiting.
USE CAUTION
I'm going to stand by my previous reservations about ordering expensive chips from sites like Aliexpress or eBay from China/HK sellers. Be VERY cautious and learn what to look out for. There are plenty of counterfeit examples on Pinside or a quick Google search. They have obviously perfected the art of faking things because it's worth their time to fake cheap chips or products that amount to fractions of a cent that when sold in volume amount to big bucks.. even if it's rice!!! Products that we would never think anyone would fake because it'd cost just the same (if not more) as creating the real deal.
Sometimes you don't have a choice when building products but to source certain parts from overseas sellers to remain competitive with pricing, but for things you can't see inside of, you can be sure if there's profit in faking them then there will be a high percentage of fakes out there. 3M ZIF sockets are faked, voltage regulators are faked, capacitors are faked, cheap logic chips are faked. In some cases that's okay (ie. you need a cheap ZIF socket and the cheaper ones on eBay/Aliexpress are "faked" 3M sockets.. and you know you're buying a fake for a cheaper price). But if it's a matter of saving a few cents over buying from an authorized distributor, your money is likely better spent buying from a distributor. There could still be a chance of receiving fake parts from some distributors, but if you buy from the larger reputable dealers (ie. Mouser) or trusted vendors like GPE that do their product sourcing on the up-and-up, you at least know they did their best sourcing only genuine parts.
