Lost lights on playfield, back box, front door coin slots , lights under the inserts still work wich connector and pin on the rectifier board control the gen lights on the playfield
Any help would be great Raff
Quoted from Raff:Yep fuses are still good, if i move the connectors abiit lights come back on but then go out again
Repin connectors
http://www.pinrepair.com/connect/
Probably need to repin all connectors on rectifier board as well as replace connectors and header pins if needed.
There's also GI bus lines on J3 for the backbox, which you said you also lost - in fact, both GI bus and returns on J3. You'll want to repin that one as well. If you are wiggling connectors, suspect those but also any other loose or broken connections somewhere on the rectifier board. Fuse holder F5, check for cracked holder or cracked cold solder on the holder itself. Pull the fuse itself out and replace it, sometimes the end caps separate from the glass - best just to replace it anyway.
Quoted from wayout440:Pull the fuse itself out and replace it, sometimes the end caps separate from the glass - best just to replace it anyway.
Problem solved it was the end cap that had separated from the glass on f5 fuse, thanks wayout440 and pinkid for helping out.
Just want to make sure is the 20 amp fuse a fast or slo-blow.
This page was printed from https://pinside.com/pinball/forum/topic/nugentplayfield-lights-out and we tried optimising it for printing. Some page elements may have been deliberately hidden.
