(Topic ID: 160996)
Nucore computer won't start!
By mattster
  • 58 posts
  • 17 Pinsiders participating
  • Latest reply 16 days ago by Joe_Blasi
There have been 6 images uploaded to this topic. (View topic image gallery).
There are 58 posts in this topic. You are on page 2 of 2.
#51 3 years ago
Quoted from mattster:
Will do.
It's prompting me to enter F1 to skip warning or press DEL key to enter BIOS.
what warning is coming up? it's the no keyboard one that is easy to turn off.
#52 3 years ago
Will do.
I have the same problem and I have replaced the battery and tried changing the bios settings. very annoying
#53 3 years ago
You can disable that warning in your BIOS. Go to the "Standard CMOS Features" section 1.6 "Halt On" and change it from "all errors" to "all errors but"
Your computer needs more testing. If it were mine I would disconnect it from the pinball machine and run Linux from a USB stick to see if the computer randomly reboots while testing. If it does, you have a PC problem. If it doesn't, you have a pinball component problem.
#54 3 years ago
Quoted from YeOldPinPlayer:
Ok guys, here's what I did. Went to BIOS and it's already set to "all errors but". However, the keyboard and mouse were disabled. I enabled the mouse and keyboard and now it boots up all the way!
Played about a ten minute game and didn't reset. I'll give it a workout this weekend to see if the reset problem persists.
Thanks everybody for your time and patience. The collective knowledge base on this site is amazing and it's so cool that you guys are willing and eager to help.
#55 3 years ago
That kind of lock up can be caused by bad RAM or a bad hard drive. I would run disk check on the hard drive itself and there are tools to do a memory check of every bit. RAM is cheap enough if it keeps happening I would replace the ram chips.
Good luck and hopefully everything will work out.
#56 3 years ago
I use Memtest86 when I test RAM. http://www.memtest86.com/
3 years later
#57 16 days ago
This old thread and i have a client with nucore. Wont boot. Only 1 volt at battery on cpu board. Would this be the issue? Thanks! Will go back again soon.
#58 16 days ago
Quoted from pinballplusMN:
Some pc boards cant't boot with dead battery's or that week battery messed up the settings try with no battery at all.
$ 99.00
Pinball Sales
$ 11.95
$ 27.95
MicksPinball
