(Topic ID: 160996)
Nucore computer won't start!
By mattster
6 years ago
  • 58 posts
  • 17 Pinsiders participating
  • Latest reply 3 years ago by Joe_Blasi
There are 58 posts in this topic. You are on page 1 of 2.
#1 6 years ago
I'm running RFM via Nucore and the computer appears dead: no fans, leds, nothing.
I replaced the power supply but nothing.
Jumped the power switch pins, nope.
Did the paperclip test and the PS fan runs and one led comes on on the computer.
Prior to this problem the game would often boot to a login prompt and would occasionally reset if it did boot correctly.
I have no idea where to go from here. Any suggestions? The longer this game is down the more desperate I am to play it!
#2 6 years ago
build a pinbox replacement until the Nucore guys can get their shit together and sell Nucore 2.0
#3 6 years ago
Return it for a prompt and courteous refund.
#4 6 years ago
I know Rob Anthony from lockwhenlit.com fixes original Pin2K computers-maybe he does Nucore, too? Just a thought.....
#6 6 years ago
I think the Nucore guys are on Pinside, I'm sure they could help.
The whole point of Nucore was to make your RFM reliable and not dependent on proprietary hardware. If the Nucore guys won't help then any PC repair person should be able to help get you up and running.
#7 6 years ago
Quoted from mattster:
Do you have a different PSU to try? bad ram may lead to random reboots but this sounds like some kind of PSU issue. Now a bad PSU can nuke you MB as well.
#8 6 years ago
Quoted from CubeSnake:
I tried lockwhenlit but he doesn't work on Nucore.
#9 6 years ago
Quoted from Joe_Blasi:
Yes, I bought a new power supply but no luck. Is replacing the MB a practical thing to do?
#10 6 years ago
My HTPC won't boot, it shows signs of activity but then shuts down. I've read that a dead or dying CMOS battery can cause a computer to fail to boot. I noticed that my CMOS battery was dying, but I've yet to replace it. Maybe you should check that before going swapping MBs.
#11 6 years ago
You can get one that will work with the cpu / and ram in there but try to boot with just the MB and psu plugged in and then start adding stuff like video / keyboard / mouse / drives.
a dead CMOS battery should not stop the system for booting but a weak one may mess up the nvram / bios settings to a point where you need to pull it / set reset cmos jumper.
#12 6 years ago
I fix computers. The most likely cause of a failed boot is a bad power supply. Since you've tried a new one my next suggestion is look closely at every capacitor on the motherboard. You're looking for any that are leaking or almost leaking. In the photo with the diagonal orange slot the cap on the right is leaking, the one on the left with the flat top looks good.
If your motherboard has the manufacturer and model (mine is shown in the image as GeForce 6100SM-M v1.0), post it and I can help you find a compatible replacement.
Could also be a hard drive issue but the computer should boot with an error message if that were happening.
I've never seen a bad CMOS battery do anything but not remember the BIOS settings.
P.S. The pictured motherboard was still working! We replaced the computer because it was several years old and too slow for photo editing by modern standards.
#13 6 years ago
I have fixed a few boards by pulling the battery to get them to boot now a bad hard drive with a power short can stop a system from booting.
#15 6 years ago
Yup, I've got the computer out of the game with everything unplugged and still nothing.
How do I reset the CMOS?
#16 6 years ago
Quoted from YeOldPinPlayer:
Caps all look normal.
The MB is by Foxconn A6 VMX Series.
#17 6 years ago
Take out the battery. It looks like a coin. You have a jumper covering two pins on a three pin connector (see attached picture), moving it to the other two pins momentarily, then moving it back will also clear the settings. http://foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000346
Next step is remove the memory and blow the slots with compressed air. If you have more than one stick of memory try booting with only one and try it in each slot. Could have a bad stick or bad slot.
#18 6 years ago
Quoted from TigerLaw:
Is this still coming out this year?
I think it has been coming for the last two years...
#19 6 years ago
Take out the battery. It looks like a coin. You may have a jumper covering two pins on a three pin connector, moving it to the other two pins momentarily, then moving it back will also clear the settings. http://foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000346
Took out the battery and did the jumper thing and still nothing. Also reseated the memory. You'd think at least the power supply fan would work!
#20 6 years ago
No. The atx power supply fan only comes on when the PC powers on.
This is a simple matter of rebuilding the pc. That's why you went nucore in the first place. Get a cheap used PC off eBay or such and install the nucore from scratch. Not sure why anyone suggested pinbox. You already have a nucore. You dont need pinbox.
This will work well: ebay.com link: itm
#21 6 years ago
I would test the power supply first, disconnect every cable and short pin 16 (the only green wire) to any black wire momentarily. Your PSU fan should come on. Disconnect power to turn it off.
If you have any cards in the PCI or PCI-E slots, remove them. Disconnect any USB devices. Disconnect SATA cables. Double check your power supply 24 pin power cable and your 4 pin AUX power cables. You want nothing connected to the motherboard but the CPU, CPU fan, one stick of memory, the power supply, and the power button.
Attempt power up.
If unsuccessful, try the other stick of memory in the other slot.
If still unsuccessful remove CPU fan and reseat the CPU using the ZIF socket. You'll need new heat sink compound before running it but it's ok to test with the old stuff.
If still nothing your motherboard is probably dead.
#22 6 years ago
You need to eliminate your power switch as the problem too. Find the connector where it plugs into the motherboard and short those two pins together momentarily. It's nine pins on the motherboard, 4 pins & 5 pins side by side. Your switch is probably labeled PWR on pins 6&8.
#23 6 years ago
chessiv i think was part of nucore and i was going to suggest looking in the elaut lawsuit jjp thread because he was trolling alot in there but i see hes inactive member status now.
#24 6 years ago
Attempt power up.
Ok, did all this including checking the power switch and still nothing. I guess the motherboard is officially dead.
#25 6 years ago
Quoted from markmon:
This looks like the answer but I'm going to get a refurbished MB so I can use the Nucore case. The board is 54.00 plus shipping from China.
Thanks everybody! I'll followup when I get the new board installed.
#26 6 years ago
I bet you could even take the PC I pasted and put your hdd directy to it and be done.
#27 6 years ago
That would be cool but then I'd have to find some alternate way to mount the case in the backbox.
#28 6 years ago
I think I took the stock PC out and slide the new one in and used some metal from Home Depot to make a bracket to hold it in place. Was super easy.
#29 6 years ago
Quoted from ls1chris:
I didn't know he deactivated. I wonder if the Nucor 2.0 release has stalled for whatever reason.
#30 6 years ago
Any micro ATX motherboard should fit in the case and mount the same way. The issue is finding one compatible with your other existing components.
If you can find a cheap modern pc with a micro ATX motherboard in it you can swap everything into your old case.
Simplest to replace just the motherboard if you can get an identical one. Don't forget new thermal paste to mount your CPU fan/heatsink to the CPU.
#31 6 years ago
That is an usb header not the front panel
#32 6 years ago
Just an FYI, those Optiplex's are great PC's at rock-bottom prices--I have several I use for virtual game cabinets, etc., but be aware the MB is a BTX form factor and will not fit in an ATX form factor case (I don't know if this matters for RFM--if the MB is free floating in the cabinet, then maybe not). The card slots and the I/O block are swapped as compared to an ATX, ie the cards are where the I/O block is, and the I/O block is where the cards are--if that makes sense.
#33 6 years ago
Staples has many refurbished computers in the $50 range.
#34 6 years ago
Ok guys, I got the new motherboard(amazing it only took a week from China).
I transferred the CPU From the old board, reconnected everything, put the Nucore CD in the drive, booted it and it works!
The only problem is thereis no power to the playfield. The game boots to the screen where I choose game platform using flipper buttons but I can't because everything is dead.
I figure something isn't connected somewhere.
Anybody ideas on tracking this down?
#35 6 years ago
Sounds like your parallel port isn't working. It is what connects the PC to the main driver board that powers the switches / lights / everything.
Make sure the cable is connected correctly. If the PC has a parallel port it is possible it isn't enabled in the BIOS. Usually Del, F1 or something when the computer first boots to go into the bios and make sure the parallel port is enabled.
#36 6 years ago
Quoted from MythMaker:
Thanks dude, I'll check it out.
#37 6 years ago
Didn't see anything in BIOS that indicates the port is disabled.
The port connection looks good.
Don't know if it matters but on the driver board the leds for fuses 109 - 112 are red. 108 is green and the rest are unlit.
#38 6 years ago
I found this on the support forum:
If nothing changes make sure the parallel port is properly connected and that the parallel port is set to port 378 in bios.
The LEDS look correct. They will all turn on only when the computer is properly communicating with the driver board.
#39 6 years ago
Also maybe turn "plug and play" OS to OFF or legacy port mode on if any of those kinds of settings exist in the BIOS
#40 6 years ago
Do you have the USB board with the security dongle connected?
#41 6 years ago
Thanks, this is all good.
Legacy port mode is on.
Quoted from scott_freeman:
Not sure what you mean. Please elaborate. Thanks
#42 6 years ago
See the attached image. Do you have the green circuit board attached?
#43 6 years ago
Yes, I have it plugged into one of the usb ports on the computer.
#44 6 years ago
How did you verify that the parallel port is connected to the motherboard? Many of these plug in via board headers. Did you toggle standard vs enhanced parallel port options in the bios?
#45 6 years ago
Well I changed it to what I believe is enhanced parallel port and it worked! Power to the playfield now.
New problems: no sound, and system reset during play.
I just hope whatever problem damaged the original MB doesn't kill this one too.
#46 6 years ago
Can you plug in a pair of headphones into the computer rear speaker output jack, (usually the green one) and hear sound? If so problem is between the pc and the amp or speakers. If not, problem is in PC side. Perhaps as simple as sound being muted.
As for system reset. Are you taking about the pin2k game resets like a Williams reset type issue? Or the whole PC resets and you see the bios POST and the machine reboots?
#47 6 years ago
Sound problem fixed. I had the jack plug in the wrong place.
When it resets, the screen freezes and pf goes dark, then reboots back to a startup screen that says american megatrends at top. At this point I have to connect a keyboard to continue the bootup process.
#48 6 years ago
Try reseating your RAM and/or swapping slots on the RAM.
#49 6 years ago
Why do you have to connect a keyboard to continue the boot process?
#50 6 years ago
Quoted from DocRotCod:
Will do.
It's prompting me to enter F1 to skip warning or press DEL key to enter BIOS.
$ 11.95
Toys/Add-ons
$ 649.95
Pin Stadium Pinball Mods
Led
Other
$ 46.99
Lee's Parts
Interactive
4,888 (OBO)
Fort Wayne, IN
4,400 (OBO)
New Brighton, PA
Gweem's Mods
Sound/Speakers
Men
$ 5.95
The Pinball Scientist
Protection
$ 84.99
FlyLand Designs
Decals
This page was printed from https://pinside.com/pinball/forum/topic/nucore-computer-wont-start and we tried optimising it for printing. Some page elements may have been deliberately hidden.
