allright, it seems all good so far
firstly again a huge thanks to those of you back east who kindly went out of your way to help a west coast pin stranger get his Abra here - very very much appreciated!!!
and I must say that I was very impressed with Day & Ross shipping - Pin went out Thurs or Friday of last week and arrived approx. 4-5 days later - nice and speedy (and affordable too in my opinion)
pin was very well wrapped and palette by one of the pin Samaritans back east - I took a photo so I know how to do it well if/when the favor need be returned the other way
once at my place and set up I gave the Abra a good initial inspection - very much as described with no big surprises - that is always nice
when I loaded it into my car I peeked down the head box 'throat' into cabinet and noticed what appeared to be another 'transformer' mounted to the back of cabinet ... my guess is that someone along the way added a 'ground' plug set up ??? not sure what I am seeing here, but the original thin power cord is nicely bound and plugs into the side of this rear one, with a longer 3 prong cord coming out of it to power up .. all looks 'period' but curious??
insides look very nice and clean with no signs of modding or monkeying other than the above ... funny when I pulled off the playfield glass - then went to put it back, it would not fit - I noticed that it had a 'sag' in it and so if put in with 'crown' on top it wouldn't go under the metal guide at back!!
playfield is very very nice and will clean up wonderfully - the 'flipper burn' is hardly noticeable at all - it almost seems like a very fine coat of shellac or old wax of some type is covering the field - a couple of areas I test cleaned with novus and rubbing alcohol / magic eraser cleaned off this older 'coat' - I will carefully go across the whole playfield with a good clean, and on this one with several layers of good wax - in a few areas the paint appears to be close to 'rising' and I want to make sure I protect against that as best I can !! it really is beautiful though
my crooked 3000 insert was loose and rolling around playfield when I picked it up - so that will be an easy realignment too!
anyhow very very excited with this one - will post more as I clean it up and get it ready with some new plastics and back glass when they arrive as well
plugged in, it all seems to work properly (was very late so couldn't play a proper game or two) except the pop bumpers didn't seem to light up - will have to go to youtube to see what activates them to light up???
cheers, Ron
