(Topic ID: 114402)
Novel Approach to Lighted Flipper Buttons
By xfassa
9 years ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 9 years ago by Wolfmarsh
    #1 9 years ago
    I have seen many techniques for installing lighted flipper buttons. Although they all produce excellent results, I decided to try something different tonight. I'm not saying this novel approach is better or worse, just wanted to share my results. Note, this is just a draft document. I can include more detail if there is any interest. All in all, it worked really well.
    Step 1: Cut/Dremel a small slot into the bottom of a transparent flipper button (note: I purchased mine from Pinball Life).
    Step 2: Insert a mini led into the bottom of the flipper button (note: I used 3mm leds that I purchased from RadioShack)
    Step 3: Insert some heat shrink tubing to cover the longest lead (trim to fit) and bend the leads into the grooves you cut in Step 1
    Step 4: Solder speaker wire to each lead and cover with heat shrink tubing. Repeat for both flipper buttons (note: make sure to cut speaker wires to correct lengths for each button)
    Step 5: Install flipper into each side of machine.
    Step 6: Make a Molex connector that can connect into the coin door board (+12V/Ground). (note: make sure to put in the proper in-line resistor for the leds)
    Step 7: Enjoy your new lighted flipper buttons.
    #2 9 years ago
    Nice write up thanks for sharing.
    #3 9 years ago
    I like- simple, easy, works... probably 2.50 cost.. if you have a dremel tool....
    Would you estimate about 30-45 minutes to do this? Probably a lot more for your first try.. but with a map- that you provided... what would you guess.
    #4 9 years ago
    It took me a couple hours but i was figuring it out as I went along. My guess would be an hour if you are proficient at modding stuff.
    #5 9 years ago
    Clean and simple, very nice. Cheap too.
    #6 9 years ago
    Cool mod, I might try this in the future.
    Do you put the little o-ring around your flipper button plunger piece? I didn't see it in the pic. I'm not sure where I first saw it, but I've been doing it to all the aftermarket flipper buttons I've bought, I think it makes them feel so much smoother with the shorter travel.
    It's hard to describe, but it's like the right one in this pic: (you can barely see the black o-ring, ignore the button sizes, its a pic I found on google)
    Maybe vid or someone can chime in on the o-ring on the plunger piece.
    #7 9 years ago
    Quoted from Wolfmarsh:
    Hmmmmmm.....never knew there where rubber rings around the plunger piece. Just make sure you run the led wire through the rubber ring before hooking it all up.
    #8 9 years ago
    Quoted from xfassa:
    I'm not sure if they are supposed to be there or not, I'm hoping someone who knows will chime in.
    This page was printed from https://pinside.com/pinball/forum/topic/novel-approach-to-lighted-flipper-buttons and we tried optimising it for printing. Some page elements may have been deliberately hidden.
