(Topic ID: 280627)
NOS WPC boards or new repro’s?
By Pinsrgrt
2 years ago
    Topic poll
    “NOS WPC boards or new repro’s?”
    • Go with the original NOS WMS boards. 13 votes
      65%
    • Go with the new repro boards. 6 votes
      30%
    • By whichever are cheaper, either is fine. 1 vote
      5%
    (20 votes)
    #1 2 years ago
    I am looking for a set of WPC89 & WPC95 boards and was wondering which way to go? I have the opportunity to get orginal NOS Williams boards or I can buy new repro sets which cost less than the original ones so is it worth the price just to have original WMS or are the repro’s perfectly fine?
    #2 2 years ago
    Wms hands down fully repairable
    #3 2 years ago
    Quoted from Pinsrgrt:
    Which repro are you referring to?
    #4 2 years ago
    Quoted from john17a:
    My thoughts exactly ... however, if the reproductions are coming from DumbAss it's a more difficult decision but you cant go wrong either way.
    #5 2 years ago
    Would depend on cost, but i would take original boards over repros any day if given the opportunity.
    #6 2 years ago
    NOS boards are good, also there are some remake boards from pinball basement that are based on the original schematics and with approval from PPS
    https://pinballbasement.com/
    #7 2 years ago
    Ok. I'll bite (or put my foot in it).
    I think it depends on what your definition of reproduction is. A reproduction or a re-design (re-engineering)?
    A "verbatim" reproduction will produce 100% compatibility. It will also inherit 100% of the deficits, defects and potential problems.
    A re-design will work but may also not be 100% compatible.
    I think it's important to understand that some of the available replacement boards are not electrically identical (or mostly electrically identical). For example (and I'm not picking on them - just using them as an example) ... Rottendog uses power MOSFETs for solenoid drive instead of BJT (bipolar junction) transistors. The effect is the same but the electrical component is different and may hide some compatibility. Another example is the Rottendog MPU9211 that (presumably) uses an emulator for the Harris CVSD (HC-55536). It may work but isn't the same electrically.
    My boards are not "verbatim" reproductions. They are 95%+ electrically identical (use all the same components that the original boards use to implement functionality). They offer improvements from known problems as well as improvements for safety, diagnostics or thermal characteristics (heat reduction). They can also be easily serviced as they are through hole designs. All the boards I build have sockets for ICs.
    It is also important to note that any offered "verbatim" reproduction of a power (supply) board is likely not "verbatim". The linear regulator is probably replaced with a switching regulator. Some of the older linear regulators are obsolete and NLA (no longer available). They are also extremely inefficient and generate heat like it's trying to survive the arctic winter.
    #8 2 years ago
    I don’t understand all the jargon, and I can’t put a board together. Matter of fact, I can barely solder a wire onto a lug. So when my STTNG 16 opto board started having problems, I sent it out via USPS to a Pinsider who was gracious enough to attempt to repair it. Unfortunately the Postal Service lost it and he never received it. So in comes DumbAss to save the day. He put together a board for me that is better than the original in that the components are raised off the board a bit to help dissipate heat [(I think), remember I told you I don’t know squat about these transistors, resistors, incapacitators...] All I know is the board looks great, professionally done, was cheaper and less riskier than getting a board that only seems to be available outside the US, and the game works 100% again. I would absolutely buy from DumbAss again without hesitation. I just refuse to call him by his Pinside handle in private messages to him though
    #9 2 years ago
    The modern boards have fatter traces and better ground planes. In some cases the new boards are thicker and have "keyhole" slots for quicker mounting/dismounting of the boards in the machine.
    #10 2 years ago
    With my boards, there are 1 : 1 original designs. I can do upgrades to trace sizes and through hole pad sizing where needed.
    Any option to get your game going is a good one.
    https://pinballbasement.com/collections/all
    Check out my parts list, it grows weekly and will explode here in the coming months/new year.
    #11 2 years ago
    #12 2 years ago
    I didn't see the option, but do you think an unassembled kit could be an option for us who like to save bucks and like to solder?
    #13 2 years ago
    Bummed I missed these. Was waiting on confirmation they work in WH2O. Hope they restock soon!
    #14 2 years ago
    Quoted from pinfarmer:
    I have a different reproduction WPC-89 power board that works in White Water (I tested it in a friend's machine) if you're looking for an alternative.
    https://pinside.com/pinball/forum/topic/dumbass-test-and-reproduction-pcbs/page/3#post-5715833
    Feel free to contact me if you're interested in one or for more information.
    You have a choice ... and that's a good thing.
    #15 2 years ago
    Will be in stock in about a couple weeks. 200 CPU's and 50 drivers will be in stock before the end of the year. Will be gradually releasing them as they finish testing.
    #16 2 years ago
    Quoted from Pinball_Basement:
    Wow, this is great!
    #17 2 years ago
    Quoted from Rondogg:
    Wow, this is great!
    Scaling up is pretty hard, but i'm learning a lot and its going well all things considered.
    I have a few more surprise part additions that will hit the site in the next year. Hoping it will drive a lot of people to the site and make the brand well known amongst the community.
    This page was printed from https://pinside.com/pinball/forum/topic/nos-wpc-boards-or-new-repros and we tried optimising it for printing. Some page elements may have been deliberately hidden.
