Does anyone have a clearer schematic than the one available on IPMD? I am trying to diagnose a couple of issues and can't quite make out the switch configurations.
If you describe the problem someone here should be able to help you diagnose it. Otherwise you can order a schematic from pbresource.com or other online vendors.
/Mark
The first problem is that when the tilt bob is in place the game starts up but moves to game over as soon as a point is scored. When the bob is removed, the game plays normally. The bob is not making contact with anything other than where you hang it.
Does it go to game over or does it tilt? Usually the TB/Tilt relay trips if it tilts and the XB/Game Over relay trips if the game ends. The Tilt and Game Over lights are driven by these two relays.
There are three parallel tilt switches in this game, each connects a yellow+green wire to a maroon-yellow wire. The tilt bob is one. Another may be a rolling ball or mercury switch near the tilt bob. The third is probably mounted below the playfield or in the backbox. If the game is tilting it could be any of those three are closing due to vibrations. Does it do the same thing if you gently pound on the playfield or backbox? Does it do it for any score value (1, 10 or 100 points)?
There is no separate tilt light or function that I have seen. It just displays game over.
I do not see a rolling ball or mercury tilt mechanism. There are two weighted tilt switches in the base in addition to the bob. Both of them appear to have space between the contacts. Does anyone have a picture of the appropriate spacing for the tilt switch next to the bob?
There are several weighted switches in the game. Not all of them are tilt switches. Use the wire colors I mentioned to identify the tilt switches.
The TB/Tilt relay and XB/Game Over relay are two different things. The tilt bob and tilt switches should trip the TB relay and turn on the Tilt light. The XB/Game Over relay (and the O/Match relay) should trip when the 5th ball drains into the trough and it should turn on the Game Over light.
Both relays are in the trip relay bank in the bottom of the cabinet as shown on IPDB: https://www.ipdb.org/showpic.pl?id=1683&picno=35043&zoom=1 Note that there are two trip relay banks in this game. The one with TB and XB relays has 10 relays. The other bank has 11 relays.
The TB/Tilt relay is on the left end in the photo. The XB/Game Over relay is 3rd from the left end.
When you push the tilt bob into its ring does the TB/Tilt relay trip? Is that the same thing that happens when you score points or does the XB/Game Over relay trip instead?
Interesting development. I started the game without the bob, scored some points, put the bob back in, and manually moved the bob to tilt the machine. The tilt actually lit up and ended the game, no game over displayed. I then started another game with the tilt bob still in place, it played normally, and did not display game over as soon as a point scored. Not sure how or why that happened, but I'll take it, because I just picked up a Bally Pool Shark project. I truly appreciate your help MarkG
