So first things first, I do not have confirmation this was a working game originally, so all parts must be treated as suspect!
Re-import AFM. Correctly converted voltage to 120.
Original boards were pretty trashed, so rottendog power driver and CPU.
Originally power on game and I get LEDa 201 and 202 on solid. Also as soon as I closed the high voltage interlock the flippers locked on.
Game does not boot at all, but I do hear the power-on bong.
I have back-tracked and done the following:
Checked voltages on the power driver board. As expected, all are spot-on.
Checked voltages running to the power driver board. Nice clean 5 and 12v.
Replaced game ROM with a freshly burned one.
No change.
Swapped all ribbon cables for kicks. No change.
Tried booting with no ribbon cables. No change.
Next step was to try a different CPU. I pulled a WPC95 off the bench. Moved over everything to it. This was an original (not a rottendog).
I even replaced the U4. No change.
So the only constants are the rottendog power driver and the ASIC.
I'm going to run to the shop tomorrow and try the CPUs in a junkyard we have to see if that helps.
I'm really just a bit stumped and got frustrated to the point I walked away for a bit.
