New! Dark mode!
(Topic ID: 275863)
Node Board Failure Batman 66
By Elevatorman
66 days ago
  • 13 posts
  • 6 Pinsiders participating
  • Latest reply 58 days ago by Elevatorman
#1 66 days ago
I'm getting this error of start up. I've never had any issues with my new Sterns so I'm not sure where to start.
I read thru some threads here talking about the issue but never saw anything about how to address it.
Where do I start with this?
It does not see any of the node boards, 1, 8, 9, 10, 24
Thanks.
#2 66 days ago
Call Stern or your distributor, as there is a potential for a node board is needed.
You could though first just reseat the Ethernet cables to those node boards to see if it improves. That is one thing they will ask you to do.
#3 66 days ago
I have reseated all ethernet cables and no change.
#4 66 days ago
Quoted from Elevatorman:
Thanks.[quoted image][quoted image]
Does your game have a coin door interlock switch? If so start the game up with the door closed and see what happens.
#5 66 days ago
All voltages are present on the cpu
20200823_221933 (resized).jpgScreenshot_20200823-222000_Gallery (resized).jpg
#6 66 days ago
Quoted from pinballaddicted:
That is how I start it, same error
#7 66 days ago
The good news is that it's impossible for all of the node boards to fail simultaneously ....so it's most likely a power issue.
#8 65 days ago
The Batman cpu boots when I put it in my Iron Maiden
The Batman cabinet node board works when I put it in my Iron Maiden
Can an SD card really cause these type of issues?
I guess I'll get an SD card.
#9 65 days ago
Quoted from kvan99:
All the correct power leds are on.
#10 60 days ago
Definitely looking forward to your solution. Im getting the same error messages (minus 24) starting yesterday. Bought it NIB in January with 1900 games played until now
#11 59 days ago
Did you contact Stern or your distributor yet?
#12 59 days ago
node 10 turntable pcb is notorious for vibration causing component failure.
#13 58 days ago
I've done a cpu and cabinet node board swap with my Iron Maiden and those boards work.
I'm waiting on an SD card now.
Filament Printing
$ 19.00
Chrome Candy
$ 27.25
The MOD Couple
