I hadn't powered my Fire! on for a few months, then I tried it and it didn't boot at all, no diagnostic LED. I swapped in a different 6802, and then it boots fine. There are no callouts but there is music. Seems strange that both the main 6802 and sound would go out simultaneously. Is there something that would cause that?
The speech comes from the main board audio circuitry. I swapped in a sound board from another machine to verify that. I also verified the sound CPU on the main board works fine - swapped with the main CPU.
I've gone over the U9 6821 with my logic probe. It's getting the sound selects, and it is also getting data from the 6802, can also see it is changing based on the sound being cycled in diagnostics. But it is not forwarding any data to the DAC, all the outputs are low. The other strange thing is P21 RW is not pulsing, stays high. I thought the 6821 must be bad, but I swapped in a new one, and same thing. I burned new sound ROMs, but no change either.
I also verified there's no audio signal coming out of the DAC, to verify the problem must be before that. Any ideas what I should do now?
