(Topic ID: 133621)
No Sound on Trident
By oldschoolbob
7 years ago
#1 7 years ago
I was having problems with the sound card blowing the F3 fuse (12 volts to regulator). (see this post: https://pinside.com/pinball/forum/topic/short-in-12-volt-but-where
So I replaced the sound card from another known working Trident - the fuse didn't blow but I have no sound. I checked the 5 volts and 12 volts test points on the card and they are good. I checked continuity from the J3 connector to the speaker and the volume pot and that seems good. Then I replaced the speaker and pot from the known working machine and still no sound.
What to look for next?
Bob
#2 7 years ago
This was the first time I didn't replace ALL the header pins when I worked on my MPU. I never had sound problems so I elected not to replace the 32 pin header at J5. I just finished replacing it. Tomorrow I'll check my work again and install the MPU. Hopefully this will solve my problem. I'll keep you posted.
Bob
#3 7 years ago
I installed the MPU with the new J5 header pins. Still no sound. While checking my work I noticed most of the J5 connectors go to the U9 IC. Is it possible that the U9 could allow the MPU to boot but still be bad and not make the sound?
This sound crap is driving me crazy. I now have a known working speaker with volume pot, known working sound card with known working MPU to sound card cables and still no sound.
Please tell me where to look!
Bob
#4 7 years ago
I just change the MPU with a known working MPU and now I have sound. I think I have a new U9 and will change it on the non-working MPU.
It doesn't seem possible that the MPU would boot up if the U9 is not working. I thought that what the boot process was for.
Bob
#5 7 years ago
I have a hard time coming up with a way in my head a CPU would cause no sound but still boot up, i guess it could. I would suspect the MPU J5 plug and the ribbon cables first tho. They are both really problematic.
#6 7 years ago
Thanks Andrew,
I replaced the J5 header pins last night and that didn't fix it. The cables are the same used on the MPU with sound and the MPU with no sound. It's got to be something on the MPU and the CPU is the only thing I can see.
Bob
#7 7 years ago
I replaced the U9 with a brand new (un-opened) CPU. Still no sound - The processor is scoring but I just don't get any sound. What else drives the sound on the MPU?
Bob
#8 7 years ago
Sorry I can't sleep thinking about this stupid sound problem.
Is it possible that the ROM's could be keeping my sound from working? I believe the ROM's are original.
Bob
#9 7 years ago
Logic probe the MPU J5 plug. Each pin should have a logical state (high, low) with most of them pulsing. If you find any floating or suspect, map it out to the associated CPU pin and make sure it is connected.
The traces on the MPU are unique for the most part that run up to the sound board. You could have a busted trace on the MPU that only loses continuity to the sound board. The rest of the MPU could still be connected to the u9.
#10 7 years ago
Quoted from barakandl:
I agree with Barakandl.
Then ..take a look to :
http://www.techdose.com/projects/Stern-Pinball-SB100-Sound-Board/346/page3.html
#11 7 years ago
Thanks guys.
Andrew, you know I'm not very good with a logic probe but I'll give it a shot. Can this be done on the bench? I think I'll probe each of the J5 pins on both boards and compare the difference.
lb45, thanks for the techdose link. I got a lot of chores to do today but maybe I'll read it over tonight.
Thanks guys,
Bob
#12 7 years ago
here is another way.
get the MPU layout chart. PM me if you need it. Use DMM continuity beep on your meter and follow every trace of J5 back to the CPU chip.
#13 7 years ago
Thanks Andrew, That would be a much easier way for me. When I installed the headers pins (J5) I did trace most of the lines back to the CPU but I didn't have the schematic out. I got my chores done today (nice weather) so I'll trace the lines tomorrow.
Maybe I'll pull out the MPU and the sound board with the connector cables and trace from the CPU to the chips on the sound board. It'll take me some time but I'll post my results.
Bob
#14 7 years ago
My MPU schematic shows 32 pins on J5 - all being used except 29 (key). The schematic for the sound board shows only 18 pins being used on J1. I can't find pins 9, 11, 12, 14, 18-24, 28 or 30.
What am I missing?
Bob
#15 7 years ago
The not drawn lines on the sb300 are probably not used / not connected. The mpu j5 was also used as the he diagnostic connector.
Pin 33 and 34 are typically not used / connected as well.
#16 7 years ago
The PIA tests are not 100%, as they can't test for a bad output on the chip. You could have a bad PIA output and still pass the CPU boot up tests.
OP could test all the outputs on the MPU board using a logic probe. Easiest way to do that is using the Leon test chip that flashes them on and off.
http://home.scarlet.be/~fb054529/bally/ebally.htm
#17 7 years ago
Quoted from KenH:
The PIA does not control this sound board at all. Stern is using clock pulse 2, vma, and address and data lines to control the sound board. I really doubt a PIA failure could cause the OP problem. I suppose a PIA could be crapping out a data line, but then lots of stuff would not work and the MPU may not even boot.
Bad\to slow\mismatched speeds of 5101 RAMs can cause problems with this SB300 sound board, but never seen that manifest into no sounds, typically some sounds are wrong. Bob, are both of the 5101's on your MPU board the same brand of RAM?
#18 7 years ago
Question--Did you change out all of the .100 molex crimp connectors on the plugs? I have been fixing all the problems I have had on my Bally/Stern machines simply by cutting off every plug and re crimping new .100 and .156 trifurcon connectors.
#19 7 years ago
I'm working on a list of all connections from the MPU to the sound board (SB100) - once complete I'll pull both boards and the cables and check everything on the bench.
I only have one 5101 (U8). The PIA's (U10 and U11) have the same numbers and logo but they look a little different. - see photo.
L_satan, I have changed all the crimp connectors and header pins except J5 (to the sound board). I just changed the J5 header a couple of days ago. I haven't changed the J5 crimp connectors because they seem to work OK with the other MPU board. I'll find out if they're bad when I bench test.
Bob
#20 7 years ago
Oh i was mixed up. I thought trident was mpu200/sb300. MPU100 games all use sb100. The 5101 issues (besides them failing outright) do not show up as much in these games since there is only one 5101. The same basic repair theory still applies to your symptom of sound only working with one mpu working and not with another with the same sound board.
#21 7 years ago
Andrew don't feel bad - I am VERY embarrassed. I checked the first pin connection - it's supposed to go from SB - U4 pin 2 to MPU - U9 pin 26. - no continuity. Then I checked the next connection - supposed to go to U9 - pin 27 but I got a beep at pin 26 - Then the next one is also one pin off. Then I looked close at the connector. Instead of one 32 pin connector I have two 16 pin connectors. Then I noticed one pin sticking up between to two connectors. I moved the connector over one pin and put the boards back into the game and I have sound.
I apologize for all the trouble I have caused everyone for such a dumb mistake.
Now I can go back to fine out why the original sound card causes the F3 fuse to blow.
Thanks for everyone's help - Especially Andrew
Bob
#22 7 years ago
Great find--and a frustrating problem!
I had a game with a similar problem, that had two connectors on upper right header on the SDB. Over the years, and after about the 3rd time I mis-aligned the connectors and blew fuses, I finally moved them to a new, single housing. It only took about five minutes. I don't know why I put it off so long.
#23 7 years ago
Nice!
It is super easy to mix up those connectors. Some times the ribbon cables used are deceptive as to what pin one is on each end of the connector too as the termination housing it sometimes opposite on each end.
#24 7 years ago
Thanks for the tips. I thought about replacing the two connectors but I can't find a 32 pin connector - GPE only goes up to 28 pin.
I tried to make the connectors dummy proof by marking "left - up" and "right - up" but even that didn't keep this dummy from missing one pin.
Tonight I re-installed the original sound card. Everything else is the same (MPU, cables, etc.) When I turned it on I got one flash on the MPU then nothing. Tried it again and got nothing - the F3 (12 volt) fuse is blown. I pulled the sound board and gave it a very close inspection. The only thing I found was some minor corrosion (more like oxidation) on the back on the 32 pin connector header. I'll probably replace the header but I don't think that is the problem.
What components would cause the F3 fuse to blow?
Bob
#25 7 years ago
I’ve been studying the schematic for the sound board. It has 12 volts coming in at J2 pins 5 and 6. And 5 volts coming in at J1 pin 30. Because I got one flash on the MPU before the fuse blew, I don’t think the problem in on the 12 volt line. Seems to me if the 12 volt line was shorted then the fuse would blow before the MPU got a chance to flash.
Would a short on the 5 volt line cause the 12 volt fuse to blow? The 5 volts are made from the 12 volts at the regulator. I don’t see any fuse protection for the 5 volt line anywhere.
Bob
#26 7 years ago
So the fuse did not blow until you introduced the sound card? Then i would suspect the amplification section of your sound board. Like those zener diodes(dmm diode voltage drop test) or maybe a really high ESR C51(is it leaking or puffed up?).
A few things use +12v unregulated. The LM323K on the driver board to make +5vdc. The amplification on the sound board.
#27 7 years ago
The capacitors look OK. Not leaking or puffed up.
I'm sure the problem is in the 5 volt line. Today I plugged in the 12 volt J2 connector and the J3 speaker connector and turned on the machine and it booted.
Then I connected the left plug of the J1 that has the 5 volt line. When I turned it on I got one flash and the fuse blew.
I have no idea what to look for or how to test it for a short.
Bob
#28 7 years ago
Using my DMM I get a beep between TP1 (5 volts) to TP4 (ground). The schematic shows 5 volts supply for IC U1 thru U5. Is that the only place the 5 volts goes? I don't see anything else on the schematic that uses 5 volts.
I've looked over the board very close for any trace or solder connection that might be shorted but I didn't find anything that looks suspect. Could one of those IC's be shorted?
Bob
#29 7 years ago
Ho ,
Did you try to use a AT-PC Power supply to have your 5, and 12V without machines ?
I used this method to fix my bally MPU.
Build a circuit with a fuse-holder (used in cars) , find an old pC power supply and work stand alone.
I would change the capacitors due to low cost, and the zener diodes.
Don't remember how to do to check the Zeners
I had this case on system1 power supply . The zener diodes short cut, and the voltage wasn't right.
Just my idea.
Lionel
#30 7 years ago
Thanks for the idea Lionel. I used a PC power supply before and found it unreliable. I don't think the capacitors or zener diodes are my problem. I'm pretty sure I have a short in the 5 volt line somewhere. The only thing I can find powered by the 5 volt line are IC's U1 - U4. I guess I'll be changing them unless someone has another idea.
Bob
#31 7 years ago
Oh yeah... The SB-100 does make it's own five volt for some of the ICs. Find the 5v rail for those isolated ICs. DMM resistance across it looking for short. You can also probe around the regulator (looks like small transistor package).
#32 7 years ago
I've traced out the 5 volt line that I think is shorted - see first photo. The red lines are the 5 volt - the broken red lines are the jumpers on the front of the board. Looks like the only things connected are U1 - U4 and C1 - C4.
Are any of those items subject to shorting out to ground?
Bob
#33 7 years ago
Start with components that go across from 5v to ground. Like cap c1. You can pull just one leg of the ICs on 5v to see if the short goes away. Check the regulator too. Maybe something got damaged when the connector was mixed up earlier.
At least the shorted area is pretty small.
#34 7 years ago
Quoted from oldschoolbob:
I have connected differents connectors on the red, yellow wires
It's easier than alligator clip .
#35 7 years ago
Thanks Lionel, I'll try that.
This isn't the board I was using when the connectors got mixed up. That board is working now.
Where is the regulator?
Can I cut the jumper wires on the component side to reduce the search area? The jumpers would be easy to replace.
Bob
#36 7 years ago
-->Take a look at U22 - near J2
Yes , you can .
#37 7 years ago
Thanks Lionel, I found the regulator - it looks OK but I don't know how to test it. And I don't think that's the problem because it's on the 12 volt side. My short seems to be on the 5 volts from the MPU.
I cut the jumpers as shown by the "X"'s in the photos. I still show a short between TP1 and TP4. (no short on the side after the cuts). Looks to me like a bad C1 or a bad U1.
Tomorrow I pull one leg of C1 and see if that's my problem, else it's U1.
Bob
#38 7 years ago
http://www.techdose.com/projects/Stern-Pinball-SB100-Sound-Board/346/page2.html
In fact i don't understand because they are two circuits . One by J1 (TP1) , one by j2 and regulator (TP6)
@Barakandl - an idea ?
"Tomorrow I pull one leg of C1 and see if that's my problem, else it's U1' --> right
#39 7 years ago
I pulled up one leg of C1 and my short went away. I removed it and tested it with my DMM and it beeps.
The schematic shows C1 as 4.7 mfd. GPE has "Capacitor, Radial Tantalum, 4.7uF, 16V" - is that the same?
Is mfd the same as uF?
Sometimes this electronics stuff is really strange.
Bob
#40 7 years ago
Good thing that tantalum cap didnt violently die. I have had them explode with a fireball on me. It was probably would have if the fuse wasn't the correct value.
Tantalum or Electrolytic cap will work fine here. Pick your poison. They both have issues.
uF = mfd. CTR-4.7uF-25V on GPE.
Same part used on the MPU bottom left corner. You might have some already from doing your MPUs.
#41 7 years ago
Wow, Thanks Andrew, I didn't know that - That would be C5. I'll check after dinner. It would be great to get it going tonight.
Bob
#42 7 years ago
I do have a C5. But which side is positive?
Bob
#43 7 years ago
the leg that is longer is the positive leg. Also i think it is on the right leg as orientated in your picture based on the markings that i can make out.
#44 7 years ago
On these both legs are the same length. I do see a small + 25 on the right side.
I just don't need an explosion - that would ruin my day.
Bob
#45 7 years ago
The side with the line should be positive. I can't make out a "+" sign, but whatever leg the + sign and line with a 90 degree bend in it is the positive leg.
#46 7 years ago
Quick update - sound card works and no explosion!
Last week when I was trying to diagnose the problem I had plugged in the speaker and volume control from the other machine. Once I had sound I plugged in the original speaker and volume control. No sound.
It's got to be a connection problem, bad speaker or bad pot. I can't believe I'm making a career out of this sound thing. I've had less problems getting the MPU to boot.
More work to do tonight.
Thanks for your help.
Bob
#47 7 years ago
Sound boards are often very complex in comparison to computer boards. Sound boards often have fancy digital and analogue circuits. A power supply / regulation. Often its own CPU. The amount of stuff going on in a stern SB-300 sound board is pretty impressive when comparing to the rest of the boards. Bally Squawk and Talk is very complex as well.
#48 7 years ago
Andrew, I want to thank you for all your help and for sticking with me through all this. Together WE now have working sound. I don't know what I did but tonight I checked the continuity from the connector to the speaker and pot - it checked out fine. Then I turned it back on and it worked! I didn't fix anything and it worked. I even played a few games (old dried out rubbers and all) and it still worked.
I still have a few items that need work (stuck on feature light and a sling-shot don't work) but I really feel proud of myself for getting through this sound problem. I couldn't have done it without all your help.
Bob
2 months later
#49 7 years ago
hey.... oldschoolbob... want to come and look at mine.... I haven't had sound in probably 10+ years. LOL sad, my kids don't even know what it sounds like.
#50 7 years ago
Hi cutlass,
If you read all the problems I had with my sound you know I'm not the "go to" guy to fix your sound card. I would suggest you contact Andrew (barakandl) - I'm sure he could fix it. Just remove the card and send it to him. You can still play the game while it's gone.
By the way I love your part of the country. When I grew up I had an aunt in Kenosha. I spent many summers there - just a few blocks from the lake.
Bob
Displays
PinballSolutions.eu
Displays
Lighting
Yoppsicle
Lighting
$ 5.95
The Pinball Scientist
Protection
$ 149.95
Allteksystems
$ 55.00
Displays
PinballSolutions.eu
Displays
$ 199.95
Cabinet Parts
Cabinet parts
Men
Troxel Repair
$ 29.00
RoyGBev Pinball
$ 29.00
RoyGBev Pinball
Protection
This page was printed from https://pinside.com/pinball/forum/topic/no-sound-on-trident and we tried optimising it for printing. Some page elements may have been deliberately hidden.
