Hey Everyone,
I took out my shaker motor now it has no soundeverything else works fine. Anyone have any ideas what the problem could be? Any ideas on how to fix this?
Thanks Pinsiders,
Dan
Hey Everyone,
Thanks Pinsiders,
Dan
Broken wire, wire pulled out of a connector, in the area you worked.
Or the shaker motor wiring was somehow tied to your sound ?
Here is what I have done so far……
1. Checked for tech alerts
2. Put the shaker motor back in - shaker motor works still no sound.
3. Inspected for loose wires - can’t find any
Check wiring down by the coin door, the Wiring around where the shaker was, and even the wiring up at the Spike CPU.
If you are handy with a multimeter you can try and test voltage at the Spike board and see if the CPU is outputting sound. Set multimeter to 200mv DC and see if you get any readings. Be careful not to touch or cross them.
This page was printed from https://pinside.com/pinball/forum/topic/no-sound-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
