(Topic ID: 211603)
No power to any coils on Pool Sharks
By Tomass
6 years ago
  • 21 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by GRUMPY
#1 6 years ago
Hello,
I am helping a friend get a pool sharks working. He says it was working when put in storage 3 years ago but I am getting no power to any coils. In test mode no coils or flashers work and neither do the flippers. I am not getting the correct voltage across the fuses on the aux power board. They are reading very low voltage but on my cyclone I am getting 25 or 50v abouts. Any help on where to check next would be appreciated. Thanks
#2 6 years ago
Is there a coin door safety interlock that's malfunctioning?
#3 6 years ago
Correct me if I'm wrong but I do not believe this game has one.
#4 6 years ago
Quoted from Tomass:
Which fuses are you testing and how.
#5 6 years ago
Maybe try reseating all the connectors on the power supply/driver board. There might be crusty connection somewhere.
#6 6 years ago
From ground strap to the fuse. I was trying to test each side to ensure the fuse was good but I am not getting current through either side on the lower left fuses on the aux power board. The 26 and 48 volt j11 and j12 are on these lines.
#7 6 years ago
To be more specific I get about 3 v on f8 7v on f4,5and 6. F2c is eradic only about 1v though. F2a is 7v
#8 6 years ago
On my cyclone I am getting 18v on f8 and 75 v on 4 5 and 6. And 40 on f2c. F2a is bouncung around.
#9 6 years ago
Pull the fuses out and test them with a meter set to continuity. Replace the fuses that don’t beep.
#10 6 years ago
I have already done this. There is no power to the whole lower left of the aux power board.
#11 6 years ago
Do you have AC coming into the board?
#12 6 years ago
Quoted from Tomass:
This fuse is on the A/C voltage side and can't be measured to ground like you are doing. You need to measure j-8 pin 1 to 4 (26 volts a/c) and then pin 6 to pin 8 (48 volts a/c). Then remove the fuses and check for continuity.
#13 6 years ago
Testing the j8 connector I get 0v from 1 to 4 and 0 from 6 to 8. I removed the idc connector and tested the connector, not the board. Is this correct?
#14 6 years ago
You need to leave the connector on.
#15 6 years ago
Ok, gotcha. I will recheck as soon as I get home from work today. Thank you sir.
#16 6 years ago
Quoted from Tomass:
There is a molex connector in the bottom of the cabinet by the transformer, see if its loose.
#17 6 years ago
Ok I am not getting a reading across the pins while connected but it is hard to get access to a point to test.
#18 6 years ago
Quoted from GRUMPY:
Just checked all the connections to and from the transformer and they seem fine.
#19 6 years ago
Meter is set to AC volts?
#20 6 years ago
Oh my, I had a connector in the wrong spot! I compared to a picture amd I had the wrong plug on that connector. Everything seems to be working now. Stupid me!!
#21 6 years ago
Playball.
$ 27.95
$ 19.99
$ 5.95
The Pinball Scientist
$ 29.99
$ 18.95
2,500 (OBO)
Nashua, NH
$ 27.00
This page was printed from https://pinside.com/pinball/forum/topic/no-power-to-any-coils-on-pool-sharks and we tried optimising it for printing. Some page elements may have been deliberately hidden.
