I was trying to fix my poorly done flipper rebuild (they drooped afterwards), and I tightened everything up.
Started playing a game and midway through ball 1, the left flipper no longer responds. Getting out my multimeter, between the blades on the right flipper switch there is 30 volts AC. On the left side there is 5 volts AC.
Looking at the schematic it is only the left flipper switch that is between power and the left flipper coil. I have looked at the jones plug where the flippers connect, and there too between the "pins" for the left flipper there is only 5 volts.
Does this mean I have some sort of ground issue somewhere, or possibly a broken wire?
