Quoted from VDrums2112:Did part of the trace come off on that board when you yanked the battery? It's hard to tell because the pics don't load well here on the computer at work... Looks like you have some corrosion to get rid of and some resistors to replace as well.
-Steve Ridge
Louisville, KY
Part 2:
Yes. It was really dumb but I didn't even know what solder was at the time. I did some reading and ordered a soldering iron and the System 80 repair kit from great plains electronics [http://www.greatplainselectronics.com/proddetail.asp?prod=GTLB80-BA-KIT]. I washed the board in vinegar and alcohol using a toothbrush and cotton balls then sanded it down with 220 sandpaper.
I think I managed to get rid of the corrosion, but I'm confused when it comes to fixing up these traces and pads. At this point I don't think I even want to replace the battery and the pad it was on because it seems overwhelming. Will this actually affect gameplay? I don't really care about high scores.
The pictures below show where I'm currently at and I have a lot of questions.
I plan on soldering on replacing the vertical trace by soldering the lead from the new resistor onto the other end of the trace(Pitiful amateur hack maneuver??).
Do I then run jumper wires from each component to the ending pad?
Is 22 gauge OK?
I also noticed another pad that was either eaten through by corrosion or damaged by my amateur desoldering.
How can I tell if all three of those pads were originally connected?
