Have a client with an AC/DC Premium with no GI at all, and the rollover lanes not working. It is definitely in line with the Grinder LED lamp extension board, but have ruled out the board itself by swapping it.
The voltage is supplied through a fused Bridge rectifier in the backbox head on the left side. The fuse is 5amp slow blow and it’s fine and the bridge tests fine. The manual doesn’t state what DC voltage should come off of this bridge for that board, so if anyone knows, that’d be helpful information to double check.
There is also a RJ11 4P6C data cable from the MPU to this board. I’ve tried finding it, but can’t seem to find the exact part. Or, would any RJ11 4P6C data cable that is long enough work OK? Any help on that would be appreciated.
Lastly, this game is wrought with mods. My biggest concern is whoever put these on (not the current owner) did something in a mod install that potentially is going to make it a needle in a haystack find. Anyway, any pointers to a part that would work for that data cable, the voltage I should have to that board or anything else would be helpful. Seems this was the only game to use this board and run GI like this.
