Hello, i have a problem with my medieval madness..
Playfield lamps ok
Flash lamps off!! No function
Check fuse 107 ok
Can help me? Why no function flash lamps?
Playfield lamps ok
Check fuse 107 ok
In test, do they work with the high power interlock enabled on the coin door ? Do they work in game play ?
If no, next would be check the 20 volt test point on the driver board in the head. See if you lost 20 volts.
Quoted from Hunico:OK, I check TP104 and don't have 20V only 6.6V
Next step to check?
thanks a lot
ok just to be sure did you take out the fuse and test it?It's always best to take out the fuse and test.just to rule it out.if you did then power off the game and start reseating the ribbon cables and reseat the connectors.do this slowly so you wont miss any row of pins or bend them.post back your findings.
Quoted from Hunico:Replace de board and nothing
Then I check 128 and no have 10 V, finally is transformer, I don't have 10V in it
I need change...
This is AC power. Did you have meter set to AC? When checking AC you need to check winding to winding not to ground. If you still Don't have voltage then check the interlock switch at the coin door.
This page was printed from https://pinside.com/pinball/forum/topic/no-flash-lamps and we tried optimising it for printing. Some page elements may have been deliberately hidden.
