Don't you hate it when you try to help someone out and end up making things worse?
Tried to help out a fellow pinsider by showing him how to adjust the leaf switches on the slingshots. Got them adjusted, but now row 8 switches aren't working right. I don't know how well they were working before -- that may be why I thought the slingshots needed to be adjusted -- but they aren't working at all now.
When I test the switches I get notice that all of the row 8 switches have a ground fault.
I disconnected the white wires from the slingshot switch and all of the other switches on that row - with the exception of the slingshot of course, and the right magnet opto work correctly. When I connect the two wires (but don't connect them to the leaf switch) the test immediately shows a groundfault, then shows that the last switch operated was the opto. (I should have tried connecting just the one power wire to the switch to see what happened, but didn't think about it. Will try this tomorrow.)
So I am thinking that the problem HAS to be with the opto, correct?
Can anyone tell me:
A) Am I on the right track with the diagnosis that the problem is with the opto?
B) If the opto is shorted, is it possible that it is the opto itself, or does it have to be a wire or connector to the opto?
C) How the heck do you get to the back of the playfield to even work on it?
Thanks for your help!!!
Chris
