OK lads, here we go
you will need :
1. strip of polished stainless (I used portion of a side rail that was polished & then cut short
for a SAFECRACKER restoration)
2. a "DREMEL" type rotary tool with a "cylindrical" shaped grinding bit with a flat base
3. angle grinder with stainless cutting wheel
a. first polish the stainless portion you want to use (easier on larger piece)
b. use the angle grinder & cut a 150mm length, 30mm in width (check against your ramp)
c. smooth the edges down & make sure they are square
d. using the DREMEL rotary tool with the cylindrical bit, "square off the internal
ramp radius curves against which the stainless strip must rest against so that
the strip will fit snugly in the ramp AND flat against the base*
*mine fits so well that it "snapped" into place and doesnt need any "glue" to hold it
in place but a THIN application of silicone was going to be my choice here
*if you have some nasty bumps in the base of the ramp due to the magnets
melting it, you can grind them down slightly to better accomodate the strip
*patience is the key, working the strip AND the ramp to achieve a snug fit along
the 150mm length to BOTH SIDES of your strip, if the ramp is very irregular you
are better off grinding the strip to fit rather than taking out too much plastic
my ramp melted & sunk in the area immediately in front of the midway "one way gate"
forming a ridge parallel with the gate AND at 90 degree angle across the exist to the
wireform so the ball would get stuck there
as a result I made my "stainless strip" start at the "sunken gate ridge" and run up until just
short of the last magnet and tweaked the gate flap spring to ensure a ball not making it all
the way up & over would get a good kick out on roll back & flow back down the wire form
the attached pictures speak 1000........
result : works awesome, will NEVER break and at best I'm good for 6 "jumps" around the
accelerator loop before it beats me
good luck & careful grinding....you only get one shot
DR
