(Topic ID: 238255)
No Fear DMD Not Working
By loren3233
5 years ago
#1 5 years ago
I am having an issue with a NF dmd not working. I have checked the dmd in another game and the dmd does light up and work properly. I pulled the fuses on the dmd board and they tested fine, reseated all connectors including the ribbon cable.
I tested voltages at the plug that attaches to the dmd and they appear to be correct.
Plug/Wires:
Orange 122.2 V
Blue 121.3 V
Pin
Black 0 V
Black 0 V
Grey 5.1 V
Grey/Yellow 12.4 V
Brown 14.1 V
I also installed a different ribbon cable from a different machine and that did not help. I am not sure what else I can check as I have power to the plug that attaches to the dmd. I have also tried using a spare dmd and that would not light up as well.
Any ideas or what I should look at next? Any assistance would be greatly appreciated.
#2 5 years ago
Quoted from loren3233:
Can you try a different DMD driver board ?
Try different ribbon cable from CPU to DMD driver board ?
#4 5 years ago
Should be 62 volts.
#5 5 years ago
Thank you all for the responses. This gives me a good starting point and I will research on why I am not getting the correct voltage. Thank you fellows for the quick response.
#6 5 years ago
FYI. If you go with a ColorDMD, you would not have to worry about repairing the -110v,-100v, or 62v as it will not need those voltages. And the display looks awesome in color.
http://shop.colordmd.com/colordmd-replacement-display-for-no-fear-dangerous-sports-pinball-machine/
#7 5 years ago
Or you can send out the DMD controller board for repair. If you want to repair it, there is a list of parts you would need to replace. https://www.greatplainselectronics.com/proddetail.asp?prod=WPC-HVP-KIT
#8 5 years ago
If you find that the board has been overheated beyond repair then you can use this.
https://www.pinballlife.com/williamsbally-dmd-high-power-replacement-board.html
#9 5 years ago
There is also this board which replaces a burnt up HV section:
https://www.marcospecialties.com/pinball-parts/A-14039-SAT
#10 5 years ago
Thanks guys for all of the options, I had no idea so much was available.
Update, I have access to a rottendog dmd board that I can borrow from a friend so I am going too install that to see if it takes care of the problem. If so, I may just get the board repaired depending on the cost or purchase a new board. I will have access to the game tomorrow so I will update you all on what I find out.
Thank you again for the responses.
#11 5 years ago
Rottendog was installed and dmd is now working, I plan on having the board that was removed looked at by Rob Anthony at GSPF to find out if it is repairable. Thank you again for the information provided.
#12 5 years ago
You can post pictures of the front and back of the DMD controller board. It is rare these are not repairable.
KAHR.US Circuits
$ 59.99
Playfields
NO GOUGE PINBALL™
$ 5.00
5,000 (OBO)
Caldwell, ID
$ 19.95
Mitchell Lighting
$ 11.95
$ 18.99
Tools
FlipMods
$ 15.95
$ 125.00
NO GOUGE PINBALL™
$ 22.50
bdash's bits
$ 9.95
11,500
Cumming, GA
Filament Printing
$ 329.99
$ 63.95
$ 23.95
Mitchell Lighting
PinSound
4,800
La Porte, TX
This page was printed from https://pinside.com/pinball/forum/topic/no-fear-dmd-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
