(Topic ID: 274884)
No Fear Ball Launch Delay
By Lindab3773
  • 14 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by Coyote
#1 3 years ago
Hey guys, I have a Williams No Fear that when I press the ball launch button there is a delay in the launch by maybe a second or 2, also on auto fire when the ball drains during ball save, its probably a 5 or 6 second delay. On multiball I can't tell if there is a delay, or how long a delay, but I'm sure its because it's less noticeable during gameplay, (I'm trying to score jackpots damn it!) Is this a board issue or maybe an opto? What can I test for? Thanks in advance for any help and guidance.
#2 3 years ago
Likely your shooter lane switch is not registering properly. Go into switch test and make sure that switch is working properly.
#3 3 years ago
Quoted from Coyote:
I tested the shooter lane switch its working fine, I made sure to test with a ball, not just pressing it with my finger to make sure the ball is triggering it properly. Its registering, however I did by chance find the right outlane was not registering, bad switch, so I replaced it.
#4 3 years ago
Quoted from Lindab3773:
UPDATE !!!!!! I checked shooter lane switch again, rolling a ball over the switch it registered, however the ball at rest in the position it launches from, the switch went back open. The angle/slope of the switch wireform was just a tad shallow at the shooter end, so after bending it up slightly so the switch would stay made, its fixed! Thanks Coyote!
#5 3 years ago
Good good! Glad you got it!
#6 3 years ago
Quoted from Coyote:
I have ANOTHER weird thing if you're interested same game, Williams No Fear, when I put up a high score, the left flipper will scroll its one direction through the alphabet, but the right will not. I cleaned all the fliptronics photo eyes when I replaced the flipper buttons and interupters. The flippers are great besides this one dumb thing. This game is a learning experience for sure. SO FILTHY WHEN I GOT IT! I'm also getting a ball missing error but I'm still testing to see if I can figure it out.
#7 3 years ago
Tests - Switch Edge - push flipper button in slowly. Do both optos register on the screen, one at a time ? First one is for lower flippers, second one is for other stuff in the machine.
#8 3 years ago
Quoted from LTG:
What LTG says - only one 'switch' (opto) is read for the initials entry - the top one. So, check that both register.
#9 3 years ago
Quoted from LTG:
LTG, thanks. I tried it, I get two squares on the test display for the EOS on the left flipper, and then on the flipper opto switch itself I get two squares and the little Williams "bloop" switch test tone . . . on the right one, the EOS shows up as one square and then on the flipper switch test I get one square on the display and no "bloop" test sound. Is it as simple as a failed fliptronic opto board? Everything else will be new after I do all 3 new flipper rebuild kits so why not right? if one is gone is the other not far behind?
#10 3 years ago
I'd replace the opto that doesn't work rather than a whole new board.
I doubt it.
#11 3 years ago
I appreciate the help, I'm thinking this is the problem for sure. Bulb bases, micro switches, coils, I can unsolder/solder all day but tiny stuff on boards not so much.
#12 3 years ago
You may have a hard time finding replacement flipper opto boards. While I haven't looked in a while, I've seen folks post here that they had issues finding replacements.
#13 3 years ago
Looks like Marco has them, good price too imo. Repros, i guess? Appears they beefed them up a bit with stronger components according to the description.
https://www.marcospecialties.com/pinball-parts/A-20207-P
#14 3 years ago
That looks good!
Filament Printing
$ 63.95
$ 5.00
$ 95.00
Pinball Mod Co.
$ 11.95
$ 22.50
bdash's bits
$ 15.95
4,800
La Porte, TX
11,500
Cumming, GA
$ 9.95
$ 23.95
Mitchell Lighting
$ 329.99
$ 19.95
Mitchell Lighting
$ 59.99
Playfields
NO GOUGE PINBALL™
Livonia, MI
$ 18.99
Tools
FlipMods
This page was printed from https://pinside.com/pinball/forum/topic/no-fear-ball-launch-delay and we tried optimising it for printing. Some page elements may have been deliberately hidden.
