Hi, I managed to buy a Gilligan's Island, and have cleaned it and had it working but unfortunately I managed to screw it too
Nooby of me, I tried to adjust some switches of the playfield WITH THE MACHINE TURNED ON and one column of switches stopped working. I changed U20 on the CPU Board and the column is working again but I noticed that although the flippers are working, they won´t change lane and also won't allow to change initials when entering a highscore.
I rode somewhere that U7 and U8 on the Drivers Board were to blame so I changed them too, but the problem is still there. So far I've checked that J211-3 and J211-5 are connected to J209-1 and J209-2, I´ve checked that shortcircuiting J207-1 and J209-1 reads as switch 11 on the switch test and J207-1 and J209-2 reads as switch 12 as I guess it should be, so I guess the CPU Board is not to blame... or maybe it is because, funny thing (and one I don´t understand) is that shortcircuiting J211-2 with J211-3 and J211-5 (one at a time) reads on switch test as R1 and R2... I don´t know how the CPU handles the flipper activation and switch activation, so I don´t know it both R1 and 11 should activate at the same time for one flipper or what else is going on... What I've found is that disconnecting the data wire from CPU to Driver Board will make flippers stop working, strange for me since all cables from flipper buttons are running to the Driver Board.
Also, the last thing I´ve checked is the voltage between J211-2 and J211-3 (where is connected one of the 4N25 at U7 or U8 on the Driver Board) and that voltage is near 12 V whether is the flipper button pushed or not.
Any ideas? Thanks for your attention.
