(Topic ID: 150280)
No ball count on Jungle Queen?
By DK
8 years ago
#1 8 years ago
Game goes though the ball count just fine, but the numbers do not come up on the backglass. I was thinking that it had to do with the Q relay but no luck. What else should I be looking at? I included a pic of the wiper in the back because I have a feeling it has to do with the issue... Thanks for any help!
#2 8 years ago
With game on pull up on the spring loaded shoe that controls ball count light and see if you can get a ball count bulb to light. I think you need to do the following.
I would cleane the rivets on that unit...alcohol and scotch brite pad. Then very sparingly lube(I use Superlube)a few of the rivets and manually work the unit up/down to spread the lube. The shoe bottoms(contacts w/springs that rotate around unit) should also be cleaned(I use a flexstone file)and make sure they move freely...no gunk from keeping them moving up and down as they rotate.
Make sure the shoes are centered in the middle of rivets at each movement, if not you can loosen the 3 screws on the Bakelite piece in that rotates around and rotate right/left to make sure centered. Good luck.
#3 8 years ago
I appreciate the response. I have done that and no change. Any other suggestions? Thanks for any help
#4 8 years ago
Quoted from DK:
you've checked the bulbs I assume
#5 8 years ago
Check the player unit. What you're looking for should be on the left side of the schematic in the 6V section - find your ball number lights and check wiring and everything associated.
#6 8 years ago
Check the make/break switch on the Game Over relay (typically the 'Q' relay).
#7 8 years ago
And make sure those copper-braided wires are attached well to the wiper disc fingers on the Player Unit you've pictured.
#8 8 years ago
Found it! Thanks for the suggestions guys!
1 month later
#9 8 years ago
Where was the problem located?
$ 12.00
$ 130.00
Beehive Pinball Co.
Lighting
Space Coast Pinball
