(Topic ID: 132581)
No audio on Indiana Jones (Stern)
By vindic8r
8 years ago
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 8 years ago by vindic8r
#1 8 years ago
Fired up a new acquisition - a Stern IJ, only to find the audio completely missing, in addition to a number of lamps that will need replacing, per usual.
I can't figure out what's going on here. No errors are coming up in Diagnostics that indicate what the issue might be. The wiring seems fine on visual inspection, although I haven't traced it completely. Any suggestions as to what I might check to try and diagnose this?
Perhaps unrelated, perhaps not - but there are a couple of wires under the plunger that appear to be inappropriately disconnected.
They are clearly different colors (GRN-BRN and GRY-VIO?) so I haven't attempted to connect them together. Some reference photos are attached.
Any ideas as to what's causing the audio issue? Or what I should do with these loose wires?
#2 8 years ago
Download the manual here:
http://www.sternpinball.com/upload/games/indiana-jones/indiana-jones/690/Stern_Indiana_Jones_Manual.pdf
The Grn-Brn is Switch Matrix ROW 01
I-N-D-Y and J-O-N-E-S and Start Button and a few others
the GRY-VIO is Upper Right Flipper
#3 8 years ago
Does the volume control in the door raise and lower the volume indicator on the DMD display?
Check connectors on the main board and see if anything is not plugged in.
Use manual as reference as to what plugs are involved in the audio.
#4 8 years ago
I have had the same issue with an Avatar, it was U16 on the CPU/Audio board.
Put in an another board from a pin you have to check whether it is the board or not.
#5 8 years ago
Quoted from Mrjamma:
Thanks for the tips! Yes, the volume buttons bring up the volume indicator on the DMD. Maximum setting still produces no audio, though. Let me take another look at the CPU/Audio board again and see if I see anything. I didn't when I went over it last night, but I could have missed something.
Quoted from wellarmed:
Alas, this is my only Stern pin. So I don't have any working boards to swap in for testing.
#6 8 years ago
I checked connectivity on all of the speaker lines and they are sound, going all the way from the speakers to J10. Then I tested the voltage output on U50 and U51. It was reading 12.7V on P5 and -13V on P3. Those seem within range. Following wellarmed's tip, I then checked voltage on P6 of U16. It was a paltry 3V. It does appear that U16 is faulty, which is the 24Bit Audio DAC. If that went south, I can totally see how the game would go silent.
Sounds like my CPU/Sound board needs to go in for repair. I'm not nearly skilled enough to replace a component the size of U16 on my own.
Those disconnected wires are a red herring, and are probably causing minor mischief that I haven't played/troubleshot the game long enough to discover.
#7 8 years ago
There are people on pinside who can do that smd repair.
Did it myself, but it was difficult.
There is one shop mentioned in the thread Big Yuck Hunter, just search.
2 months later
#8 8 years ago
FWIW - This was the 24bit Audio DAC chip at U16. That was replaced and the audio on this game works fine now. But now I have a far more troubling issue with some damage to the playfield around the Ark...
$ 44.99
Pinball Shark
$ 16.00
$ 59.95
pinballmod
Professor Pinball
$ 38.00
PinballReplacementParts
6,900
Plainfield, IL
$ 59.95
pinballmod
$ 17.00
Nordic Pinball Supply
arcade-cabinets.com
$ 70.00
Creekside Hideaway, LLC
$ 59.95
pinballmod
This page was printed from https://pinside.com/pinball/forum/topic/no-audio-on-indiana-jones-stern and we tried optimising it for printing. Some page elements may have been deliberately hidden.
