Hoping for some help with my Nitro Ground Shaker. Pin was working 100% until recently when it refused to boot! My initial thought was to replace the rectifier. This decision was not based on any great repair or troubleshooting skills I possess but rather simply the poor condition of the original board. It appears tho have been repaired (rather sloppily) many times and actually appeared burned. Figured I needed a new one anyway so I replaced it with a new X-Pin Rectifier-2518-18 purchased from Pinball Wizard. This did not change anything! At this point,my great troubleshooting skills convinced me that I probably needed a new MPU. Once again this decision was based on overall condition/appearance of the original board. There was significant battery acid damage that had been somewhat mitigated at some point but the board still looks to be in poor condition. Since this is my favorite machine, i did not hesitate to order a new Ultimate MPU from Pinball Wizard. It was during the pre-installation checks for this board that I found some voltages that lead me to believe the problem may actually be with the solenoid driver board. I have not connected the new board and now believe my old board may actually be ok. I am hoping someone can make some sense out of the numbers listed below and help guide me in the correct direction.
Rectifier X-PIN-2518-18
TP1 = 6.35 vdc
TP2 = 228 vdc
TP3 = 10.72 vdc
TP5 = 45.2 vdc
Original Bally solenoid driver board AS 2518-22
TP1 = 4.07 vdc
TP2 =166.4 vdc
TP3 = 3.87 vdc
TP4 = 251 vdc
TP5 = 10.59 vdc
Thanks in advance for any help received!
George
