Not every time but sometimes when the outlane switches are triggered , all the machine computer controlled lamps start to flash. It looks just like a lamp test mode. Once a new switch is triggered the lights all go back to normal. This is an intermittent problem and was wondering if anyone had any ideas . It seems the switches are activating the light test but they should be on different circuits. The lamp board, mpu, and solenoid board are all new aftermarket replacements. I thought it was a ground issue because the backbox ground was not secured. Fixed that but still have problem. Then I thought the issue was only present with the playfield glass and lockbar off . It was not and happens with glass and lockbar installed.
Game has full LEDs and alltek lamp board.
