Quoted from HowardR:Does the motor run when this happens? In either case have a close look at the Credit Button wiring.
There should be a Blue&Orange wire on one terminal and a White&Orange wire on the other terminal. And nothing else.
Yes, these wires are correct.
Coin Chute 1: When you add a coin it starts a game without adding a credit/needing to press start. If you add a second coin it will add a second player; 3rd coin = 3 players; 4th coin = 4th player; 5 or more coins it does not add any more players (obviously), but it also does not add credits. It triggers the coin relay and motor however.
Coin Chute 2: No Chute 2
Coin Chute 3: Appears to function normal
Start button: Activates Coin Relay, Credit Relay and the motor. However, once 4 players are added and the start button is pressed there are no relays that activate nor does the motor, but it continues to add credits on every press until they are maxed.
