(Topic ID: 138040)
Night Rider@ reset relay ?
By JKnPA
8 years ago
  • 30 posts
  • 7 Pinsiders participating
  • Latest reply 8 years ago by wizardblom
#1 8 years ago
Just got this Pin to power-up. I bought it last year.
The Reset relay stays locked on when the Credit button is hit.
The Score motor keeps running and#1 and #2 player relays keep clicking.
I checked the relay contacts in the Reset circuits, but didn't see a problem.
I thought the most likely problem would be the make/break relay contact 1D on the Score motor,
but that does open and close!
Any ideas on a likely cause ?
#2 8 years ago
Do the score reels reset to zero after the credit button is pushed? If not they need to be cleaned and make sure the swithes are cleaned and adjusted properly. If they are reseting properly report back.
#3 8 years ago
Yes.... they do reset.
After they reset I disconnect the coil wires to the #1 and #2 player relays so they stop clicking.
Did I overlook a relay contact somewhere that is staying closed?
Where is this Drum unit Zero switch / maybe that is staying closed!
#4 8 years ago
I cleaned all 16 Score reels. One of the 'Zero' sws. (#1 Player) was closed at Zero, but after I adjusted it, nothing changed.
I noticed the Bonus relay is staying closed and #2 Player Score reel keeps scoring, so I turn the power off.
I'll trying to find why the Bonus relay is staying ON. I assume that is why it keeps scoring.
I'm thinking its a switch/s on the Playing field!
John
#5 8 years ago
Just so I am clear when you turn the game on what happens and try to start a game what happens?....
the score reels reset to zero? or #2 starts counting up and scoring?
#6 8 years ago
Both were happening, because the score motor keep turning.
I cleaned all the Score reels, Player counter, Credit counter, and Ball counter assys.
It would also not Eject the ball to Play. I found the Bonus unit assy. was not resetting to Zero.
When I Reset the Bonus unit to Zero manually, the ball would eject so I could play. But it only ejected once; because the ball count lite stayed on 1.
I compared Night Rider to my Old Chicago pin (1975) and noticed that the Bonus unit on my O.C. would step down and reset to Zero before the 1st ball would eject.
I think my problem now is the Bonus unit is not Resetting to Zero to eject the first ball, and the ball counter is not advancing to eject the 2nd ball after it goes in the Outhole.
I have made some progress...... so that's Good!
* My bridge rectifier is Bad...... I have it disconnected. What should the DC output voltage be for this part ?
John
#7 8 years ago
on an EM, the working voltage is about 30 volts A.C.
on a full wave bridge, the output shud go up a few volts, but level off under load.
As long as you get a bridge rated above 50 volts, you are good
#8 8 years ago
Ok..... the transformer has outputs of 50VAC and 6VAC.
The 'Bridge' is bad, but that is a minor problem because it is used to power the 'Sling shots'.
Why are they using DC for those and AC for the Flippers ?
#9 8 years ago
So, use a bridge rated higher than 50 volts. the 6 volts is for lights.
more efficient power transfer, and snappier coils.
As with everything arcade, it took them a while to apply DC to the whole machine.
AC was cheaper, less components.
#10 8 years ago
Ok... replaced the Bridge rectifier; sling shots and two of the Bumpers work.
I only measure about 10VDc, so I guess that is all they need!
Bonus unit..... unit resets now. I cleaned and adjusted the 'Bonus' and 'Double Bonus' relay contacts.
I think one of the make/break contacts was stuck ON.
Other..... Player up and ball Count not advancing now; was working....... Ugh !
#11 8 years ago
Where is the Zero position on the Coin unit assy ?
Does the switch stayed closed all the time, or how does it function for the various positions ?
#12 8 years ago
Noone has a working 'Night Rider' EM ?
It would have been nice if Bally included diagrams of the Units like they did in the Bingos , so you could
identify the wires and the switch operation......
#13 8 years ago
I have a Night Rider EM. I will see if I can get a look tonight at the Coin Unit for you.
#14 8 years ago
Thank you........ I have worked on about 50 of these stepper units, but this one is driving me nuts!
Also note how the switch operates !
#15 8 years ago
I have one too, I'll try to take some pictures tonight.
#16 8 years ago
Quoted from insearchofspace:
Thank you........ I took off the switch and tried different settings, but the reset is not right.
I think the switch s/b closed for steps 1-3, and Open at step4.
I think that is what is showing in the schematic.
#17 8 years ago
This is the Switch at position #4 ( Opens when it hits the stop) ..... Is this correct ?IMG_2472.JPGIMG_2472.JPG
#18 8 years ago
Everything looks good there. Does the stepper advance if you hit the credit relay?
#19 8 years ago
YES.... it steps-up and seems to work Ok since I got the Player-up and Ball count to work now.
It just does not want to Reset; that is why I thought the unit was not Zeroed properly.
#20 8 years ago
I'll take another look when I get home to see what resets that unit. Did you clean the reset relay? It really is a fun group once you get it going!
#21 8 years ago
Its Resetting now...........
I had to wind the spring really tight. Normally the spring doesn't have to be that tight, but this one had to be.
I cleaned the Unit many many times, so it isn't dirty.
Once I fixed the other problem with the Player-Up and the Ball Count, I was able to trouble shoot this problem.
Ok.... now I can work on other minor issues!
Thanks to All who helped.....
I may need future help, so don't get lost!
#22 8 years ago
Glad to hear you got it working
#23 8 years ago
Quoted from smailskid:
Thanks...... there were so many problems with this Pin it was hard to kep on track.
After I fixed the 'Player-up' and ; Ball Count' problem/s, it was a little easier to focus on the 'Coin unit' reset.
Just found two broken wires the middle of the harness; what are the odds of that happening!
'Night Rider' playing very nicely now; not sure of the proper Scoring now.
What is the 'Over the Top' function on this pin ? I don't think the book explains it .
John
#24 8 years ago
Over the top is used to sound a buzzer for a while and lighting up the sign "king of the road" on the backglass.
You need to put in a blinker light (bi-metal one) in the socket for shutting the relay off.
Over the top is energized when you are scoring 100,000 points, that one stays on.
#25 8 years ago
Ok............ Thank You
#26 8 years ago
Im having some issues with my EM nIGHT RIDER pin. It will say game over after first play When resetting a new game it will say game over 2 or 3 times. It doesn't do it all time. Sometimes doesn't start on ball 1 all the time. My bonus unit is damaged but works. I looked at the the other units everything seems to look fine. Any ideas.
#27 8 years ago
I would verify the 'stepper' units are working properly!
'Ball Count', Coin unit, and Player-up units.
Manually step-up and reset the units to verify they work smoothly; if not clean them.
John
#28 8 years ago
When ball goes put of play the games doesn't recognize the ball is over. Does not award bonus points. Doesn't advance player to next ball. Ball will not eject for next player. Any ideas. Cleaned and adjusted all relays.
#29 8 years ago
Sounds like the out hole switch is not registering
#30 8 years ago
Does the score motor stop at index position?
That's the contactset nearest to the scoremotor, if not adjust the top switch.
A lot of contacts will work only if the motor is in the right position.
$ 5.00
$ 199.95
$ 69.00
Pinball Pimp
$ 100.00
Playfield - Plastics
$ 18.95
Third Coast Pinball
$ 5.00
This page was printed from https://pinside.com/pinball/forum/topic/night-rider-reset-relay and we tried optimising it for printing. Some page elements may have been deliberately hidden.
