Quoted from xsvtoys:Sounds good. 2 more questions for you. You say that after the game is started, if a 10 point score switch is hit then the 10 point relay energizes and stays energized, but the ball index relay does not energize and the score does not change. Under that same condition:
- do you hear a chime from the 10 point chime?
- does the 00-90 unit move? This is also called the match unit.
These are 2 other functions that are activated by switches on the 10 point relay. If the 10 point relay is energized then both of these should occur.
Nothing is activated when the 10, 100, or 1000 point relays pull in.
This comment of yours "There is a switch on the 10 point relay with a yellow wire and a white/brown wire that should close as soon as the 10 point relay is energized, as shown by the red line. This will energize the ball index relay as shown by the green circuit." got me thinking that maybe the white/brown wire somehow isn't getting power back to the ball index relay. So I carefully scrutinized the white/brown and found that the wire insulation was wearing away in one part where a zip tie was too tight so I thought maybe that was screwing it up. I taped it with electrical tape and when that didn't help I replaced the whole wire running from the 1000 point relay to the female end of the jones plug. Unfortunately. that didn't help either. So then I ran a jumper from the brown/white lug on the 1000 point relay to the lug on the ball index relay and then actuated the 1000 point relay and nothing happened. Then I touched the jumper to another lug on the 1000 point relay and that caused the ball index relay to pull in. So I guess I don't really understand what's going on/ I thought when the 1000 point relay(or any other) was pulled in, a connection would be made that would send a signal to the ball index relay to pull in. By that logic I assumed that putting a jumper on the lug of those switches would accomplish the same thing, but it didn't. So am I just misunderstanding how it works, or power just not ever getting to that lug/switch?
Rolf, I ran out of time and wasn't able to work through all your questions yet. When I saw the frayed wire I thought for sure that was the problem and then devoted all of my effort to that.
