Hi heiber
lets use a Test-Lite for testing. You have 110 VAC in Your house. You have a simple bedroom-Lite (two prongs) - Bally-pins uses 48VAC for the relays / steppers etc. The "Bedroom-TEST-Lite" will not shine VERY bright - but it will light-up.
Whenever You just look into the pin, when You just fumble around / work: UNPLUG the 110VAC Main-Cord (Safety Reason).
Unplug the 110 VAC cord -> look at the transformer -> Do You see a wire-RED-White running from a "Lug on transformer" to the 48VAC-10-Ampere-Fuse ? The other side of the fuse has one or two wires-color-BLACK soldered-on. Do You see that ? If not: do NOT proceed - report -> we will look at ...
On the same level at the transformer - a bit to the side - "Transformer-Lug-YELLOW": Two Yellowish-light-brownish wires are soldered-on. Do You see that ? If not: Do NOT proceed - report -> we will look at ...
Look at my JPG: "Violet": IT IS TABOU !!! ONLY the "Red-Dot" and the "Yellow-brown CIRCLE" are allowed - YOU ALWAYS MUST HAVE THE FUSE IN THE CIRCUITRY (WHEN JUMPERING).
Connect one side of Your Bedroom-Lite (a oldfashioned Edison-type 20 / 40 / 60 Watt bulb - NO NEON-Type, NO LED-Type) - connect one side to transformer-Yellow (permanent, solid connection). With the other side (using a wire) -> TIP ON THE FUSE "side-wire-color-BLACK". Practice a bit. Lay the open end NEAR the fuse - NOT touching anything.
Plug-in the 110VAC-Main-cord, turn-on, start a game. CAREFULLY take the end of the wire and (again) touch onto "Fuse-side-wire-color-BLACK" -> does the Test-Lite lites up ? If not: Do NOT proceed - report -> we will look at ...
Turn off, unplug 110 VAC and prepare "Test-green-1": You mount one side of the test-lite to the middle blade of Score-Motor-6D - where Wire-Yellow is soldered-on. The other end of wire of the Test-Lite (again) lay NEAR the fuse.
Plug-in 110 VAC, turn on, start a game -> Reset is done -> pin idles -> CAREFULLY take the end of the wire and (again) touch onto "Fuse-side-wire-color-BLACK" -> does the Test-Lite lites up ? If not: Do NOT proceed - report -> we will look at ...
Turn off, unplug 110 VAC and prepare "Test-green-2": You mount one side of the test-lite to the lower blade of Score-Motor-6D - where Wire-Black-Red is soldered-on. The other end of wire of the Test-Lite (again) lay NEAR the fuse.
Unplug 110VAC again - have a look at Your Score-Motor (and my JPG) - Dou You have a Service-Jack to UNPLUG the Score-Motor ? sometimes we want to turn the score.Motor BY HAND. If You do not have such a Service-Jack: Do NOT proceed - report -> we will look at ...
OK - unplug the Service-Jack (Score-Motor) - Can you turn (grabbing a wheel) the wheels - moving -> grabbing again -> moving -> "a half round = 180 degrees" ? If not: Do NOT proceed - report -> we will look at ...
PLUG-IN THE SERVICE-JACK (SCORE-MOTOR), plug-in 110 VAC -> turn-on and start a game -> reset -> idle -> NOW unplug the Service-Jack (Score-Motor) -> Establish "Test-green-2" -> the test-Lite lights-up. NOW turn the Score-Motor by hand -> when Switchstack-6 is activated: DOES THE TESTLITE QUIT LIGHTEN ? If not: Do NOT proceed - report -> we will look at ...
You have just tested "Does Switch-6D open the part-that-shall-open".
Unplug 110 VAC and prepare "Test-Green-3": You clip-on at Upper blade (color-Orange-Green). Plug-in 110 VAC (and Score-Motor-Service-Jack), turn-on, start a game -> reset -> idle -> NOW unplug the Service-Jack (Score-Motor) -> Establish "Test-green-3" -> the test-Lite does NOT lights-up. NOW turn the Score-Motor by hand -> when Switchstack-6 is activated: DOES THE TESTLITE LIGHTs-UP ? If not: Do NOT proceed - report -> we will look at ...
You have just tested "Does Switch-6D close the part-that-shall-close" = THE Part You suspect.
PLEASE: BE VERY CAREFUL: 48VAC can kill YOU !!!
Greetings Rolf
